The CD drive in my twinhead notebook will not read or write to discs. The drive has power, it loads the disk and the lite on the drive comes on. What ibeleive is the indicator LED on the keyboard turns on and flashes but the message "insert disc" comes up. The device manager says the drive is "ok". What do you think? can I get a replacement drive? This is a model p88TF. thanks, john
  • 43 Answers
Actually ur cd-drive's lens is not working properly,it fails to read the disk.so as per me u should replace ur cd-drive or take it to the service center.
Posted on Oct 05, 2009
Dvd reading error
Try using a known-good (for instance, a movie you just watched on your TV). If it doesn't read that disc, make certain you have seated the disk in the drive properly (Laptop drives have a *CLICK!* when you have seated the disc properly). If that doesn't work- if the laptop is in warranty, get it fixed. If not, use an external drive to fulfill your media needs
Sep 22, 2012 | HP Pavilion dv6775us Notebook
Installed new hard drive p105 s6064 now cd drive wont work dont have recovery discs
Dell recovery will not work in a Toshiba Laptop. Just make sure the boot order is set to CD/DVD driver first that will automatically start the CD/DVD driver when disc is loaded.
Apr 22, 2012 | Toshiba Satellite P105-S6104 Notebook
My aspire ax3400 wont load disks
Are you saying your CD/DvD drive does not read any disks? If so, are you using disks that a friend made (put music on it) or are you using store bought disks (purchased a music cd from a store)? Most computers have problems with disks made by someone else at one time or another.
Click Start/My Computer and look to see if your CD/DvD drive is showing up in the list. If not, that's the problem. Remove the Power Cord, Remove the Case, then remove the two cables that plug into the CD/DvD drive then put them back in securely. Sometimes the drive just needs to be reseated. Now see if the computer see it in My Computer and if it will Read your Disks.
When you boot your machine, look and listen for the CD drive to make a click and the light on the cd drawer comes on for a second or two. That means the drive is recognized by the computer.
If all fails, Maybe your drive is broken and needs to be replaced.
Mar 31, 2012 | Acer Aspire AX3400-U2022 PT.SE202.007...
Hello .. I have a laptop and the 7520G Aceraspire HDDWD2500BEVS .. Disc HDD does not occur in the BIOS says it NONE .. .. I do not know how to reinstall from the CD, when the disc does not load .....
> HDD does not occur in the BIOS ... says it NONE
This is the first problem that you need to fix, before doing anything else.
Check that the disk-drive is properly "connected" (both "data" and "power" connections).
Enter "BIOS SETUP", and see if the disk-drive is correctly "detected".
Probably, you need to replace the disk-drive, and then reinstall Windows.
Is the current disk-drive still under the manufacturer's warranty?
Dec 22, 2010 | Western Digital WD2500BEVSRTL Scorpio...
I have thinkpad T61 it was loaded with vista. It
what kind of media are you loading? is this a DVD or a program disc? If this is a DVD disc, try loading a music CD or other type of disc to see if it is recognized. If so, its possible your PC DVD is unable to recognize that specifc type of DVD. Try other DVD's which you know worked before using Vista. Even though your machine says the device is working properly, check the Lenovo website for updated drivers for the DVD and the board chipset. Let me know if updating the drivers does not work. Meanwhile, I'll see if I can find out any more information from Lenovo.
Apr 08, 2010 | Lenovo ThinkPad T61 Notebook
Says disc error will not start and no disc are in
In your case 'Disk Error' (with a _k_) is a problem with the hard drive disk not a disk in the CD (or floppy) disk drive..
Insert the operating system disk and bring up The Windows Recovery Console. Windows will interrogate the disk before trying to re-load windows. When Scan Disk comes up, select 'Thorough' which also checks the sectors of the hard drive for damage.
Doesn't sound good I'm afraid,
Nov 28, 2009 | Acer Aspire 6920 Notebook PC
PC won't read disk
try a master cd like a store bought cd if it works the u got a cheap drive if not replace drive any way get a lite on there cheap and work good but burn out in like a year or so with heavy useage
May 18, 2009 | Dell Inspiron E1505 Notebook
I want install driver from net for lite on 5236v
YOU DON'T NEED DRIVER FOR CD ROM DRIVE BEFOR YOU CAN USE IT BUT IF YOUR CD ROM DRIVE IS WRITER FOR BURNING CD THEN YOU CAN DOWNLOAD NERO SOFTWARE FROM NET ANY NERO SOFTWARE YOU CAN SEARCH FROM GOOGLE TYPE IN THE SEARCH BAR THAT YOU NEED DOWNLOADABLE NERO SOFTWARE. SO YOU CAN LOAD IT ON YOUR PC
Dec 24, 2008 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
Lite-on Combo SOHC-5236v
You may be using the wrong type of DVD format. Some DVD-ROMs and players will only read certain discs. i.e. DVD+R, DVD-R, DVD-RAM. If you are trying to read a DVD-R disc that was bought blank, and then had things burned to it, it may be that the disc wasn't finalised after burning. You could always try updating the Firmware version by downloading it from the website.
Nov 08, 2008 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
Disc Unreadable
simple format compatability issue.
you either don,t have the software on your computer.
Or the disks are unfinished or unfinalised, which means that there are no table-of-contents ( directory structure ) for windows to be able to understand the disks format.
Mike @ Compurepair.
Also the drive ( CD/DVD Rom ) may not be compatable with these disks. check your software read/write program, to see if the disks are supported.
Feb 14, 2008 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
