Question about Ariens 34 In. Zoom Series Riding Mower
Replaced coil keeps breaking down when it gets hot.
  • charjack1 Oct 05, 2009
    The motor is a 14 horsepower Koeler Engine.
  • 472 Answers
What moter do you have
Posted on Oct 05, 2009
  • mickey813
    mickey813 Oct 07, 2009
    CAN YOU GET THE MODEL NUBERS AND SPC #
Hot water keeps running hot and old
Fastjet,
I can't understand what you are asking...
Please clarify via a comment.
perhaps a leak?
Jan 09, 2015 | Water Water Heaters
Ignition break down under load
This can happen when the saw gets hot. If the coil is breaking down under heat /load it must be replaced. There is no repair.
Mar 28, 2014 | Husqvarna Garden
Eng. breaks down when hot like a cyl cuts out. Could this be a coil module breaking down when hot . The bike other then this runs fine
You need need to check the pulsar pick up ( like points for a cdi style ignition) , the coils,and the spark plug caps. If any of these are bad replace them. If all test good then your problem is a bad cdi box.
Jun 01, 2010 | 1984 Honda VT 500 C Shadow
Coil problems getting hot and shutting of the van.1985 dodge 318
If the coil has never been changed then replace it and the problem should go away. As the coil gets older it starts to cause power failure, they tend to break down more common during the hot summer like a battery. Also check your wiring to coil for any frayed or cracked insulation on wiring. Hope this will help you.
May 21, 2010 | 1985 Dodge Ram 3500
My nrg keeps booging out when i ride it
change the coil its breaking down under pressure dont be fooled by it giving a good spark its only when its hot that it breaks down
May 19, 2010 | RTO 50cc Moped Scooter
Replaced coil breaks down when it gets hot. spits & sputters. have changed coil 2 or 3 times . keeps breaking down.
Does this machine have an electric fuel solenoid on the carburetor bowl?
If so, shutoff fuel supply to the carb and remove solenoid. Check for sticky operation using your finger pressure olny. If sticky, spray and spray and work with finger to free it up. Then spray once more!
Blow it completely dry and bench test it with a 12vdc source AWAY FROM FLAMMABLES!
It should snap down quick, nice & firm with power on and rise back in the same manner when power is interrupted.
Hope this helps.
Oct 05, 2009 | Garden
Coil breaks down when it gets hot. it spits & sputters. have changed coil 2 or 3 times. keeps breaking down.
I think you MIGHT have the cart before the horse ... what is the problem? you think the solution is replace the coil. Whats happening?
are you points or breakerless ignition? Is it set correctly?
You running off the fly wheel or from the battery?
Your plug wires are in good shape?
Stops firing on middle 2 cylinders when it gets to running temp
The coil is probably breaking down internally when the heat rises. The only other possibility is the electronic ignition going bad. Have a dealer check the bike before spending bucks on a new coil when the old one may actually be good.
Please rate this solution. Thanks! :)
May 21, 2009 | 1999 Bimota YB 11 Superleggera
92 Olds 98-kills when warm-restarts after cool down
the coil could be breaking down when it gets hot, if it starts after it cools off replace the coil
May 21, 2009 | 1992 Oldsmobile Ninety Eight
Ariens 34 In. Zoom Series Riding Mower Logo
88 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
