Question about Ovens
Model # RBD305PDB14 - can't read the display panel - the light is out or something but can't figure out how to change it.
  • 725 Answers
You can not change the light on this panel, but you can change out the whole display panel to work properly. Thanksgiving is just around the corner, so if you'll give me a call as soon as you get a chance, we can ship the part out to you right away. 972-859-0929. We look forward to hearing from you and getting your oven working right again.
Posted on Oct 05, 2009
Rbd305pdb14,have error ( F5-E1) replaced controlled board, replaced touchpad, replaced sister board, replaced thermal fuse lower oven, replaced lower oven heat sensor, top oven works ok, lower oven still...
that's a bad door latch,if you use the self clean don't use it anymore,the oven gets up to 1000 degrees and damages the electronics in the oven,takes out the clock assy. the door latch things like that.part number WPW10195934 go here to see parts go here put model number in and look up parts,also you can check all the error codes down in bottom right hand side
https://www.searspartsdirect.com/model-number/RBD305PDB14/1198/0125300.html?searchType=modelSearch&q=Rbd305pdb14&searchTerm=Rbd305pdb14
go to upper oven and look at part number 22,you should have googled the error code before you changed out all those parts.
Feb 06, 2018 | GE JTP48SFSS Electric Double Oven
Error codes for Whirlpool double oven Model RBD305PDB14
You will most likely need to replace the Whirlpool Keypad aka Touchpad Membrane Switch Assembly.
Replacement units are available here:
Introducing the Ledgestone Technologies Touchpad
Original Part Number may be one of: 4448467 4448468 4451965 4451966 4451967 4451968 4451973 4451974 8300427 8300428 8300429 8300430 8300435 8300436 8300516 8300531 8300533
Jul 05, 2013 | Ovens
Rbd305pdb14 error code F5
Dear Valued Consumer, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Dear Valued Consumer), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 23, 2017 | Whirlpool RBD305PD Electric Double Oven
My Whirlpool doudle oven #RBD305PDB14 was working fine and now the display is blank and it only would beep at you. the interior lights would come on but no use of controlls. It has been powered off at...
There is a thermal fuse at the connection for the control board.
Had the same problem. I repaired the board myself and ordered a replacement from sears parts direct. It is a repaired board not a new one but has the same warranty. You can get this board a lot faster. Here is the link. http://www.searspartsdirect.com/partsdirect/part-number/8302319R/0022/664. If you would like to repair your own board leave a post and I will help you.
Nov 20, 2011 | Whirlpool RBD305PD Electric Double Oven
No heat! Lights work, timer etc - everything "appears" to be working but there is no heat!
Probably your heating element has failed, dependant on appliance the element can be found in the oven itself at the back behind a panel that normally has a couple of screws holding the panel in place. reasonably easy to fit yourself and not very costly.
Hope this helps
Apr 01, 2010 | Whirlpool RBD305PD Electric Double Oven
Whirpool GBD307 - Display not working
We had the same error codes F2 E6. We were told to turn off the breaker to the oven for 5 minutes and then turn it back on and it will reset itself. We tried it and it worked! Whirpool wanted to send someone out on a service call. Thank goodness we didn't!
Mar 28, 2008 | Whirlpool RBS245PDS Electric Single Oven
Oven Problem
Check power going to the electronic module in back of the display. If power there you have a blown module. If no power check for a blown thermal fuze.
Apr 08, 2007 | Frigidaire FGB24T3A Gas Single Oven
Display Panel Light
There is a replacement display assembly, i think its around $150-$200. Its pretty easy to change if you are at all mechanically inclined. Good Luck!
Oct 29, 2006 | Jenn-Air W30400P Stainless Steel Electric...
The electrical panel does not light up
I'm afraid you are going to need a new display board. Not very hard to change but a pricey item. Have seen this problem a few times. Good Luck!
Oct 05, 2006 | Jenn-Air WW30430P Stainless Steel Electric...
Ovens Logo
152 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
