Question about Maytag PYE2300AY Electric Dryer
Maytag dryer runs but doesn't heat up - Maytag PYE2300AY Electric Dryer
    President:
  • 1,187 Answers
1. Open the small access door in front of the dryer and start the heat cycle. The ignitor must glow a bright orange so that it is hot enough to light the gas. If there is no orange glow, then the ignior needs replacement.
2. If it glows then cuts off, then glows, again and cuts off, the thermocouple sensor wire is out of position. It needs to be very, very close to the ignitor. This thermocouple sends a temperature signal when it senses that the ignitor is hot enough to ignite the gas. Unplug the dryer. Re-position the thermocouple wire mount so that the thermocouple wire is almost touching the ignitor. You may also "bend" the wire. Plug power back on and heat.
3. If it still does not heat, then the automatic gas valve that is controlled by the thermocouple sending unit is broken. The automatic gas valve cannot be safely "fixed" and must be replaced.
Hope it's just the thermocouple wire.
Posted on Oct 05, 2009
  • Karen Lange
    Karen Lange Nov 13, 2013
    How do you access the thermocouple wire? We have the dryer open, have replaced coils, have checked the sensors and are now going to try this .
Electric dryer runs but no heat. all thermal and motor and heater element have continuity.
Dryer Diagnostic - Not Heating up - Repair ... - YouTube
? 11:16
https://www.youtube.com/watch?v=3Vns05qIjGs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your trusty Maytag Electric Dryer suffering from some of the ... However, in REGULAR mode, it runs normal too, but theheat stops ...
Maytag Dryer Not Heating - How to Test the Heater and ...
? 4:12
https://www.youtube.com/watch?v=_zjiZ0sbCgI
Oct 12, 2013 - Uploaded by Bill Newberry
How to test the heating element on a Maytag Dryer. If you Maytagdryer is running but not heating these are what you need to check. ... The dryer runs but does not heat. .... Not heating Maytag electric dryer - Duration: 19:38.
Not heating Maytag electric dryer - YouTube
Jan 13, 2016 | Maytag Dryers
Dryer not hating up after changing heat sensor
Check this site out------http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-4-630749-/Maytag-Dryer-doesn-t-heat-MDG6800AWW-------------
Oct 09, 2014 | Maytag Dryers
My maytag bravo dryer turns on and tumbles but doesn't heat
There may still be a warranty left on it. the thermistor or the heating element may be at fault.
Dec 20, 2012 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My Maytag gas dryer, Model No, LDG7500AAW will run but not heat. The igniter glows red, but the gas will not flow. What might be wrong?
Replace the 2 burner coils ,if the igniter keeps cycling trying to start the flame. If it doesn't replace the flame sensor mounted on the side of the burner tube.
Nov 06, 2012 | Dryers
My Maytag gas dryer won't heat
Hello Todd,
Their are several things that could cause the dryer to not heat, i have posted a tip i wrote what to check whena gas dryer doesn't heat
http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Nov 12, 2011 | Maytag Dryers
I have a Maytag Neptune gas dryer, model #MDG4000AWW, Serial #10793672WF. The unti is operating but doesn't heat up. Do you think it is the igniter and/or the heating element? Also, can I replace...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 11, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag dryer MDG7600AWW doesn't dry at all anymore.
heatman101
Aug 25, 2011 | Maytag MDG7600AW Gas Dryer
My dryer doesn't dry! it runs, but with no heat, so nothing's dryer. fixable? how? thanks!
heatman101
Aug 18, 2011 | Maytag LSE7806A Top Load Stacked...
Dryer runs but doesn't get hot, not even warm. It will also just turn its self off???
heatman101
Aug 11, 2011 | Maytag Dryers
Maytag PYE2300AY Electric Dryer Logo
659 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
