Question about Singer Sewing Machines
I have a leather sewing machine that is a singer and when i am sewing the bottom thread will not catch what do i do?
How to plane overseas trip for a famous singer/group.(perhaps with a focas on thier contry of brith?)
Posted on Oct 05, 2009
I have a Singer sewing machine#7258 what setting and needle and thread do I use to sew leather
Hope it is light weight leather. It should not be used on heavy leather.
Use a brand new heavy needle (leather). Avoid using upholstery or thicker thread as that sometimes does not feed well through the needle eye. Set it for a longer stitch. And you might want to adjust the presser foot pressure to accommodate the thicker fabric under the presser foot. Also, a leather foot, roller foot, or walking foot may be helpful--if if not available, try using parchment paper (or something similar) on the surface of the leather to help it slide under the presser foot..
Jan 06, 2018 | Singer Sewing Machines
Singer 99 not feeding heavy thread.
Unfortunately, your domestic machine was not made to sew leather. It can probably sew lighter weight leather with a lighter weight thread. Your thread is most likely too heavy for the machine you are using so it is not able to pick it up properly.
Apr 19, 2017 | Singer Sewing Machines
Singer 401a. Sews material fine. Using a leather needle/machine goes thru material with ease but threads do not stitch together. Just pokes a row of holes. What needs to be adjusted??
Since I can't examine your machine, I'll give you some suggestions. You may find some of them obvious, but these are things I have found when repairing various machines.
First and most obvious, make sure the needle inserted correctly. The 401a uses a flat shank needle such as a 15x1, 130h/705. The shank needs to face to the rear with the groove in the shaft running all the way down the front of the needle to the eye. In backwards (yes, it is possible to do), it won't form a loop and the hook won't pick up the top thread.
Second, you will need to check both hook to needle timing and needle distance. You can visually check if the timing is close by turning the wheel until the needle is in the bottom of it's travel. Then raise it until the very front of the hook is behind the needle and not sticking out. The hook should be above the needle eye. If it isn't or very close, your timing is probably out.
The needle distance is the horizontal distance between the needle and the hook. The hook should be very close (usually .01mm).
With leather the loop may be smaller and the hook just can't catch it due to one of the above conditions.
Aug 11, 2015 | Singer Sewing Machines
Bottom thread not catching with top thread
The first thing you need to do is change needles, then check to make sure that the end of the needle is all the way up in the needle clamp, with the flat part against the BACK of the machine. The needle you're using may be bent or inserted too low, and that will cause the upper thread from not being able to catch the bottom thread.
If you do that and it still doesn't catch, your timing is off and will need to be corrected by a technician; however, it does not have to be an authorized Singer technician; it's a very common adjustment that any technician can do. I believe Sears services all machines. The most common reason for the timing to go off is by turning the hand wheel repeatedly away from you. ALWAYS turn it towards you, and ALWAYS thread your machine with the presser foot UP.
Jul 12, 2014 | Singer Advance 7422 Electronic Sewing...
I have a singer 201k sews fabric perfectly but I wanted to do some leather I bought a walking foot attachment leather needles and heavy duty thread but the machine is not stitching properly very tiny...
Sounds like it is still not feeding smoothly, Try putting some clear tape on the bottom of the foot and tissue paper under the leather. Leather is tricky sometimes.
May 31, 2014 | Singer Sewing Machines
Bobbin thread keeps catching under the plate
Your needle may be new, but Is needle correct size for fabric you are sewing? If so, is needle all the way up as far as it will go in needle bar shaft, flat side in back & more rounded side facing you? Stretch knits and wovens, denims, and leather do not use same needle size. Jimmy
Apr 09, 2012 | Singer Quantum 9940 Computerized Sewing...
Globs up on bottom of fabric using a heavy thread and leather
I've had that same problem with vinyl. I was told not to use the heavy thread, rather to just use a strong thread like quilting thread and if needed, go back over it to restitch next to the first stitching. The bobbin on a regular sewing machine just can't handle the thicker thread, it won't slide through the bobbin case good. That worked for me. But I did find a lot of help on the web by googleing "How to sew leather" You might try that.
Nov 20, 2009 | Singer 3116 Simple
Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Aug 16, 2009 | Singer Quantum XL-5000 Computerized Sewing...
Sewing Machines Logo
49 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
