Question about Compaq Armada Cooling Fan Case Cooling Fan
Compaq armada 1573d charger
Does the armada 1573D have a built in charger ?
I have one here! There is no charger, just a cloverleaf connection on the back which plugs directly into the wall.
Compaq Armada 1537D Pentium MMX 233Mhz 32Mb RAM 3.2Gb HDD, 800x600 12.2" Screen.
Wow what a blast from the past., tis running Win95 better than some new machines run XP! Most impressed that it's still runnning at all.
Posted on May 07, 2009
  • 21 Answers
According to the owners manual on the hp/compaq website, that notebook has an AC cord that plugs directly into the wall. Therefore the notebook must have an internal charger to convert the AC to a DC voltage to recharge the battery. Here is the link to see the manual:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00139858/c00139858.pdf
Just copy and paste the above link into your browser.
Posted on Feb 11, 2008
Al encender mi computadora me pide de inmediato password y no me deja ingresar al sistema. Como puedo desbloquear la clave de la BIOS para poder entrar a trabajar en windows?
Fue alguna password que inseriste antes?
Algo que estuviste haciendo en la BIOS?
Puedes intentar apagar la memoria de la BIOS, retirando la bateria de memoria que se encuentra en el interior del ordenador.
Para eso tendras de desarmar el ordenador, retirar la bateria interna por 10 segundos, e volver a poner.
Nov 11, 2013 | Compaq Armada 1573D Notebook
Syndisue@cant conncet to wireless network,cant find wireless switch
The Compaq Armada M700 does not have a built in WIFI adapter. You must use an USB or PCMCIA adapter to connect to a wireless network.
Mar 04, 2011 | Compaq Armada M700 Notebook
o open the BIOS Setup screen:
  1. Turn off the computer and wait five seconds.
  2. Turn on the computer.
  3. When the first screen displays, immediately press the F10 key if your computer was built in 2006 or later (came with Vista or Windows 7). Press the F1 key if your computer was built before 2006 (XP or earlier). Press the key once every second until a BIOS Setup utility screen opens.
    NOTE: On some Compaq Presario computers (before 2002), press the F10 key at the logo screen.
  4. Use the keyboard to move through the menus.
  5. Then disable the Administrator PAsssword
Jan 20, 2011 | Compaq Armada 1573D Notebook
How do I reset the "Power On" password ? I
look for something at the bottom of the screen (e.g press F12) and it will take you to the BIOS go under a tab that may say "boot" or "security" and work from there
Nov 13, 2010 | Compaq Armada 1573D Notebook
Compaq Armada 110 works only, when AC adapter (PSU) is connected. I changed a new battery (refurbished) and now fully charged, but when unplug AC cable power will be lost. It was same behaviour with the...
OK, check the connection IN the laptop make sure they are actually making contact and are actually working. Now IF that is all in order, then I suspect, that your Battery Charger/Internal Power Supply, has faulted, the External and Internal supplies are separate, with exception for tap off to battery charger.
I have had this many times in my shop, you can most likely buy the Power supply sub board assembly and replace it.
Below is a service manual that will show you what to do and the part numbers. Most likely Ebay will be your best bet, or go straight to Compaq or Compaq dealer for the spare parts, or use the 'net.
http://www.eserviceinfo.com/index.php?what=search2&searchstring=Compaq+Armada+110
If you don't wish to DIY, then please get a "Quote" from a Compaq repair Centre
Oct 15, 2010 | Compaq Armada 110 Notebook
My laptop Compaq Armada 1573D dosnot see the added memory that i have put in it is with in the spec ie 64meg
Are you sure that the new memory is fully seated? Did both side clips click tight into place against the memory chip? If this is does not solve the problem move on to step 2. Remove the original memory, keeping the new memory in place. Restart the computer. If there is nothing wrong with the memory, then i should recognise the new memory w/out any problem. If you can not boot due to "no memory present" or some similar error message then the memory chip is no good or unrecogisable by your laptop. If the chip is good and the computr starts w/no problem, then reinstall the original memory chip and restart the computer. If the problem persists the two memory chips are incompatible.
Here is what crucial.com says you can install in you compaq armada.
http://www.crucial.com/store/listparts.aspx?model=Armada%201573D
Please let me know if this solves your problem, you can contact me at johnkariotisjr91741@yahoo.com
John Kariotis
Oct 28, 2009 | Compaq Armada 1573D Notebook
Compaq Armada e500 will not turn on
hello
After reading your problem i think that your charger i malfunctioning as it is not charging the battery when it is plugged in..
The message you have mentioned comes only when your battery crosses the lower limit of charge..and your charger is not charging so it ran out..
Thank you
Aug 19, 2009 | Compaq Armada E500 Notebook
Compaq armada 500 (touch pad not working)
look at the ribbon/connector again, make sure it's not broken.
Sounds like a broken ribbon or bad connector.
May 23, 2008 | Compaq Armada E500 Notebook
My compaq armada m700 is having problem
this may be because the battery is dead so you may have to keep the charger attaached to the laptop for power. if this does not work then this means that the battery is no longer good so u will need to replace it.
please rate me. thank you,
May 23, 2008 | Compaq Armada M700 Notebook
Compaq Armada Cooling Fan Case Cooling Fan Logo
189 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
