Question about Robotoolz Laser Level With Simultaneous Plumb + Square
Turn unit on and it flashes but it won't level
  • fixitj Oct 05, 2009
    did that but no difference still just blinks and tried turning the little screws but still no help do you know where I can get a manual for the unit or someone who will service it in Toronto Canada . thanks for your help
  • 285 Answers
Firstly, check batteries are fresh and new. Secondly, the unit itself has to be within 5-10 degrees of level before it will level itself out. If it is outside this range, i.e. pointing too far up or down, the lasers will flash toi indicate this. So just check the unit itself is sitting somewhere close to level to begin with, because the levelling gyros only have a small range in which to operate.
Posted on Oct 05, 2009
My alba telly won't turn on it glee ps flashing blue what should I do
Sounds like your power supply inside the unit is bad. What is the make and model?
Mar 11, 2013 | Televison & Video
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
Sony HCD LX20i audio shelf sysyem won't turn on. Standby light flashing. Disc stuck in it.
Check the speaker wires for shorts, if okay! suspect the audio output ic's, the protection circuit won't come out of standby because there is a short.
May 06, 2012 | Audio Players & Recorders
I have a 50 series w/ digital humidity level readout. Recently unit reads the room at 30% humidity so it shuts off unless preferred setting is set to continuous. Can the sensors go bad that measure the...
If the humidity level is at or lower than 30%, the unit won't turn ON, until the reaches 35 - 40%. It's rare for the sensors to go bad. Just keep in mind, the dehumidifier is reading the humidity near the floor, not up at say, chest level. Humidity levels change every season, so this really would not be that unusual. Make sure that your clean the air intake filter regularly. Cleaning and wiping down the coolant coils would be a good idea, too..
Hope this helped you. Please let me know.
May 16, 2011 | Frigidaire FDF50S Dehumidifier
Flashing green light stays on, unit won't start when you press the on/off button
I believe the unit needs to me reset to the manufacturer's default settings. To do this, turn the Master ON/OFF Switch to OFF and unplug the unit from the outlet for 10 - 15 minutes. Then plug the unit back into the wall outlet and turn the Master ON/OFF Switch to ON. The green light will blink until you change the humidity setting to below what the humidity level is in your home. If you set it higher, it will not turn ON or will turn ON only for a couple of minutes.
Also, check the position of the water collection bucket, to make sure that it's installed properly and has triggered the safety device.
To help you more, I have included a link to your Owners Manual that you can download and print for future reference, if you have misplaced yours. Take good care of your unit and perform routine maintenance regularly. As Danby has discontinued (retired) your model humidifier.
http://www.danby.ca/cms/uploads/products/en_manual/DDR4007EE2.pdf
Hope this helped you. Please let me know. Thanks.
May 06, 2011 | Danby DDR4007EE Dehumidifier
Why is my cabrio flashing Lf???
Thanks for using FixYa. Error LF means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore washer elite flashing LF...could someone please tell me what this is...????
Hi Rhonda,
Thanks
Rylee
Aug 23, 2010 | Kenmore 24032\24036 Top Load Washer
Flashing LF
Hi
Thanks for using FixYa. Error LF indicates long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 23, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Robotoolz Laser Level With Simultaneous Plumb + Square Logo
607 people viewed this question
Top Robotoolz Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Robotoolz Measuring Tool and Sensor Expert? Answer questions, earn points and help others
