Question about Canon EOS Rebel XSi Digital Camera
The image in my viewfinder has gone fuzzy
The image in my viewfinder has gone "fuzzy", while my pics still turn out ok (usually)
  • hurford2000 May 11, 2010
    I take it you are talking about the View finder and not the LCD screen?
    If so there is a small wheel to the right side of the view finder which
    change the focus point of the view finder to your eye.
    To set use the Auto focus on a set point around 2 to 6 meters away then
    move the wheel up or down till the view is in focus and all the
    metering spots are clearly visible.
  • adele_caroli Apr 01, 2013
    Thanks you1 you saved my life!!!!
  • 797 Answers
Complete information is lacking.
By viewfinder, are you talking about the LCD or the view finder on the camera?
Something is out of focus in the internal adjustments.
You can try to go to the menus and set all to factory defaults.
Then try it.
If this continues, the camera needs repair.
Here is a link for Canon Repair call the 800 number and ask for the repair dept.
Also Canon has a trade-in program for re-furbished cameras for a reasonable price when you trade in your broken camera.
Posted on Oct 05, 2009
4 Suggested Answers
cyrylthewolf
  • 143 Answers
SOURCE: blured viewfinder
Look at the viewfinder on the camera.
Now look on the LEFT side of the viewfinder; just above the swivel-screen.
You will see a little thumb wheel there.
That is the focus for the viewfinder. Move it up and down to bring the viewfinder into focus. (Don't forget to do this while you are looking through the viewfinder so you can see what you are adjusting.)
Easy fix. :)
Posted on Nov 15, 2007
  • 10 Answers
SOURCE: No image on viewfinder Nikon D300
You just need to press the play button which is situated above the menu button and simply has a white triangle on it.
Posted on Feb 10, 2010
  • 52 Answers
SOURCE: Canon 50D. Hi, When I
The focus screen might be loose.
Here's a video about focus screens. Maybe you can adjust it.
Happy Shooting!
Posted on Mar 06, 2011
No view from screen or viewfinder
Hi, have you tried another memory card in case the other one is faulty ,if the original card is ok then you will have to put into a fuji repairer to inspect. If you are still under guarantee the contact fujifilm.
Dec 17, 2015 | Fuji FinePix S5700 Digital Camera
Nikon coolpix p60
The viewfinder on the Coolpix P60 appears to be a small monitor that links to the main image sensor that is the same sensor that the lens uses. If the purple is on the images when they have been downloaded from the camera to another device, then the sensor is bad. If it is only on the viewfinder and the rear LCD, then the problem is in the connection from the circuit board to the monitoring devices.
Either way, it is probably cheaper to replace the camera than to have a non-warranty sensor or circuit board replacement.
Jul 14, 2013 | Nikon Cameras
Memory Card claims ''no image'' and LCD black and wont take pics
first reformat memory card to FAT file system with computer, then reformat it with camera. this usually is the solution
Aug 10, 2009 | Canon PowerShot A590 IS Digital Camera
When switched on, display reads "In synchronized monitor mode"
Cycled through display options, still couldn't get viewfinder image. Checked images already on card, and they showed OK, so screen operating properly. Went back to viewfinder mode, got lots of horizontal lines across screen. Realised I could do no more, so took camera to shop it was bought from, who checked it and said it had an electronic problem that needed professional repair facility, so camera has gone for an estimate of repair cost.
May 07, 2009 | Ricoh Caplio R4 Digital Camera
Nikon D40 will not focus
on the right side of the view finder there is a little bar. Make sure it is all the way down. If it is in the up position then it will make the viewfinder, shouldn't make the images blurry though. Also make sure it is in AF not MF (auto focus and manual focus).
Oct 21, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Diopter adjustment and viewfinder problem
Hi
I would not attempt to open the camera for any sort of fix. It has weather seals in place and would recommend sending it in to Canon. If you have any warranties left it would void these. Lastly this is a high proformance bit of kit and you want to get is seen to by an Authourised Canon Dealer.
As for the diopter adustment. To be able to see through the view finder and see your subject clearly, take of the lens cap aim the camera and turn the little dial until the screen inside the viewfinder is clear it should not be fuzzy. You are only looking at the screen/gring and not the image beyond. This does not affect your image but does effect how clearly you see your subject through the viewfinder.
Hope this helps
Regards
Jun 03, 2008 | Canon EOS-1Ds Mark II Digital Camera
I see nothing in the Viewfinder...
The camera has a mirror lock up feature for cleaning the CCD sensor. You may have engaged it. Check your manual about this function
Dec 27, 2007 | Nikon D40 Digital Camera with G-II 18-55mm...
Is my canon eos 400d broken?
This is a Digital SLR With SLR cameras you can only use the viewfinder because the image comesi nto the lens and up to the viewfinder via a mirror. When to take a pic the mirror flips up[usually with a crash] and the image goes to the CCD- afterwards you will get an image briefly in the LCD.
Sep 20, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Viewfinder Blank but shows information
From your description it would seem that the shutter component in your lens has failed. Although it is a little strange because the two symptoms you describe are not usually seen at the same time. The fuzzy pictures with streaks on them is a result of a shutter that doesn't close properly, the black screen with just the camera system text on it is a symptom of a shutter that is not opening properly. As for what caused the problem - possibly corrosion or contamination. Was the camera exposed to excessive humidity in the time it was unused? The shutter components are extremely delicate and can easily become stuck or sticky. This is what I believe has happened to your camera. It may not have failed completely but it may be sticking open or closed such that it is not performing its intended function. This will require full disassembly by a professional. David Millier Advance Camera Repair
Feb 23, 2007 | Nikon Coolpix 5700 Digital Camera
DSC-F707 viewfinder black
This same thing happend to me awhile back. Camera seem to be dead for several weeks until one day I tried turning on and then off the night vision. The was the usual click inside the camera and all was well after that. I still use the camera.
Sep 12, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
Canon EOS Rebel XSi Digital Camera Logo
547 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
