Vulcan Quasar 40 wall furnace - electronic display problem
Just moved into a hosue with Vulcan Quasar 40 wall furnace. The pilot is burning, however the heater is not working. The electronic display clock is not set, does this need to be set for heater to work. And does the electronic panel need to be on? I have downloaded the manual but it isn't much help - the clock on the LED doesn't seem to be working properly.
  • 53 Answers
Have a gasfitter bypass the clock. The clock is the source of the problem. You will then have a manually operated heater.
Posted on Oct 08, 2009
  • 3 more comments
  • netvivat May 30, 2011
    Here is an illustrated guide how to fix the clock for $8 in parts. http://www.startrade.org/vulcan/Vulcan%2...
  • 7gerard7 Aug 28, 2011
    The link posted by netvivat doesn't seem to work. Any chance you can repost updated link? Thanks
    Link does not appear to ork. Can you please check & repost. Thx
  • netvivat Aug 28, 2011
    I posted the link some time ago and from my end it still works OK.
    When typing the address, try replacing %20 with (space), like.... / Vulcan Quasar 40 gas heater.html.
    Or send me mail to info at startrade.org and I will send you the link directly.
    Steven
  • netvivat Aug 29, 2011
    Correction: I posted the link some time ago and from my end it still works OK. When typing the address, try replacing %20 with (space), like.... / Vulcan Quasar 40 gas heater repair.html. Or send me mail to info at startrade.org and I will send you the link directly. Steven
Trying to locate replacement parts for my gas wall heater
http://www.enviro-friendly.com/bonaire-gas-wall-furnaces.shtml
Bonaire pyrox is the old Vulcan company
Standard Appliance Parts Sacramento California can get you anything you need as well.
Apr 05, 2015 | Vulcan Heating & Cooling
Where can I get instructions for removal of a disconnected Vulcan Quasar W/F gas wall furnace? I thought it would be easy to remove the unit from the wall but on inspection I can't see how to do it?
If it has truly been disconnected and you can;t figure out how to remove it from the wall, just remove that section of wall and replace it. If it is mounted on a standard stud wall, cut at least 16" out from each side. Remove the furnace and replace the drywall. That is, admittedly, the brute-force approach, but I am assuming that you have already looked up the installation instructions and simply reversing them didn't work.
Sep 15, 2014 | Video Cameras
Vulcan Gas Heating Furnace Pilot Light Goes Off
Clean pilot may be too small blow out with tube or air line , thermocouple not working try changing it
May 19, 2012 | Heating & Cooling
My father has to replaxce an 11 year old Vulcan Wall Furnace. He wants a Braemar Wall Furnace. He must tell Braemar what model his Vulcan is - there aren't any model badges. Can he determine if his...
Usually these numbers on most other untits are stamped on a metal plate which is located
or attached to the gas valve, which would also give the BTU Input/Output. Probably the
Model Number as well
Sep 01, 2011 | Heating & Cooling
Vulcan Quasar wall furnace, pilot will lit and burner starts but goes out after a few minutes. sometimes pilot will relight but most often fails to light till unit cools down. Any suggestions?
You may need a new thermocouple if you have been able to light it before.It is located above the pilot lite and needs to get hot to keep the gas flowing.You can pick up a universal thermocouple a the local hard ware store.Shut the gas off,unscrew the coupling nut and remove the old one.Bend the the new one like the old one and replace.Try not to kink the new one.Good luck and thanks for choosing FixYa.com.
May 15, 2011 | Heating & Cooling
Noisy pilot light Vulcan Quasar 40
Simply clean out the jet tube with a fine wire, the sound you hear is the gas blowing by the irregular edges, and swirling and not mixing and producing sound waves, (Bit like a flute) So, you need to clean the tube right out, and smooth off the end again, & sorta "Countersink", Flame the end too, at the end.use a very fine needle file, and make it look like new, that will sort your problem out. Then adjust so you have a good gas flow. Also check out it isn't blocked too.
Apr 30, 2010 | Cozy Enclosed Front Console Heater 20,000...
Error code f1 on vulcan basic deluxe
Ck and ensure there is a pilot light.No pilot light, no gas.
May 26, 2009 | Heating & Cooling
Pilot light won't stay lit
Look for dust and lint. Look for them in places where gas should be freely flowing. I had a similar problem with an Empire Corcho wall-mounted propane ceramic catalyst heater. First it was the pilot light, then the #2 ceramic mantle. After horsing around with the gas lines and pressure regulators and trying to re-aim the pilot, it all turned out to be dust and lint in the gas passages. A little dust bunny in the brass pilot tube gave me a pilot light the shape and color of a banana. One puff of compressed air, and I got back my razor-sharp pilot. And some dust in the chimney of the #2 burner kept it burning blue/yellow and blistering paint off the upper surfaces of the heater. A bit of cleaning with a shop-vac put that right. "Passive" heaters are very much prone to this sort of problem because they rely on convection currents (i.e. LOW velocity) to get the job done. Convection currents are notorious dust collectors, as in COBWEB CITY.
Aug 23, 2008 | Heating & Cooling
I have a vulcan quasar wall furnace. the fan no longer works
Perhaps the fan motor is bad. If not, you have an electrical problem.
Jul 23, 2008 | Heating & Cooling
Heating & Cooling Logo
1,802 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
