Question about Texas Instruments TI-83 Plus Calculator
My Calculator has many horizontal lines that cover my entire screen while I am trying to perform calculations
Buy anothernew one.
Posted on Oct 05, 2009
My TI-84 Plus Silver Edition Calculator is missing pixels or lines in the middle of the screen. If I press 2nd then + sign, i get menu to reset, but three lines are not visible. This happens in the...
this happand when you dont use the Calculator long time
try the 2nd and Arrow up make the screen dark for 15 to 30 min
keep puse any key until will pass the 30 min
if it will not help than it could be the screen or the connection on the mainboard
Oct 13, 2010 | Texas Instruments TI-84 Plus Silver...
My screen is blue when ever i change my batteries, So I Press the 2nd button and make it lighter. But the pixels dont lighten all the way And when i go to some type of menu like for Zoom, there are...
Try to reset everything to see if that helps. If it doesn't , you can try to upgrade your operating system on the calculator to see if that helps to make it go away.
If that doesn't help try this:
"Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message."
Let me know how it goes.
Aug 20, 2010 | Texas Instruments TI-83 Plus Calculator
When I try to turn on the calculator, nothing but a straight horizontal line appears on the screen.
Hi
the HP 48g+ is similar to TI83 Plus
the same problem also in the TI its an hardware failure
if you want to fix the calc let me know
ecrdn@yahoo.com
Jack
Aug 07, 2010 | HP 49g+ Calculator
My TI 86 is 6 years old and I have taken careof it well.
Try pressing (lightly) on the bottom border below the screen. If there is no change, try the top. If there is still no change, the power for your LCD may have become disconnected or shorted. There are external displays for these calculators intended for overhead projectors. If your school has one, you could try hooking it up to make sure the calculator itself still works.
In either case, it would be better to purchase a new calculator.
Good Luck!
Feb 05, 2010 | Texas Instruments TI-86 Calculator
My screen has a horizontal line across the screen
Make the calculator perform a self test: Part of the test is the display of some line patterns. You will be able to see if something is wrong with the screen.
TO PERFORM A SELF TEST (No I am not shouting, but I cannot use Bold fonts nor underlined)
  1. Turn calculator ON
  2. Press and HOLD the ON key
  3. Press the "E" key , the key with an E to its right
  4. Release the ON key
  5. Tests will be performed cyclically until you execute a SYSTEM HALT
TO PERFORM A SYSTEM HALT
  1. Press and HOLD the ON key
  2. Press the and release the "C" key key with a "C" to its right.
  3. Release the ON key
  4. You should see the empty stack.
If you need to repair it, google FixThatCalc.
Good luck.
Jan 23, 2010 | HP 48gx Calculator
One horizontal line across the screen
Read this article for troubleshooting.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-83 Plus Calculator
My screen on my t1-83 has gone really dark and i don't know how to make it brighter
This means both your Xscl and Yscl values are too small. Fix this on the WINDOW screen, as explained under My screen is covered with horizontal or vertical lines.
Thanks
Fame !
May 04, 2009 | Texas Instruments TI-83 Plus Calculator
Casio fx-570ES calculator inner screen cracked
the difficulty of finding a replacement LCD maybe would cost more than having a new one. and even if can find a replacement, installing it would again be very difficult! circuit to LCD connector is fixed, once remove, there'll be no guarantee that it would still function normally! try to disassemble your calculator and see if you can manage to disconnect and reconnect the LCD itself!
Nov 05, 2008 | Texas Instruments TI-86 Calculator
Screen not displaying whole letters because of horizontal and vertical lines
I've had the same problem. A temporary fix that I have found is to turn up the contrast all the way (press [2nd] then hold down the up arrow) until the screen becomes mostly black. Then turn the contrast back down (press [2nd] then hold down the down arrow) until it is at a normal level. If you can get rid of all the white lines when you turn up the contrast the screen will be back to normal. Unfortunately this does not permanently fix the problem because I cannot get rid of all the lines and it seems to be getting progressively worse each time it start up the calculator.
Oct 24, 2007 | Texas Instruments TI-83 Plus Calculator
Horizontal lines obstructing the second half of the ti 83 calculator screen, anyone know repair tips?
I had the same prob with vertical lines on the screen, and getting messed up when there was lots of numbers on the screen.
Solution: Change your batteries. Put some freshies in then adjust your contrast until you see the little black box. If you still have a problem with the lines, darken the screen until it's black (2nd up repeatedly) and let it sit for a couple minutes. Lighten your screen back to normal (2nd down) and turn off then turn her back on.
Jan 17, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
90 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
