Question about RTO Gas Motor Scooter 50cc
Is the 17MM nut to replace drive belt removed by
Is the 17MM nut to replace drive belt on 50CC scooter removed by ratching clock wise or counter clock wise ?
  • 43 Answers
I think only a TNG is backwards. You will need an impact driver, turning counter clockwise.
Posted on Dec 31, 2009
How do i replace the temperature thermostat on 2002 bmw 530i show dieagram
the fan nut is LH thread. Means turn right (clockwise ) to loosen.
Jun 24, 2014 | 2003 BMW 5 Series
How to remove clutch lining
Hi, Sharlon13_bc counterclockwise for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.GY6 150CC CV Belt Removal Clutch Replacement Springs
EASY Scooter Clutch Nut Removal
DOWNLOAD BAJAJ CT 100 SERVICE MANUAL
http://www.marutibajaj.com/pdf/ct100.pdf
Bajaj Auto Ct 100 2015 User Manual
Feb 10, 2013 | 2005 Bajaj CT 100
How do i change the serpentine belt on my 2001 corolla ce?
use a long ratched and socket, apply force clock wise and remove belt by water pump firts, note belt routing, intall new belt on all accesories leave water pump at last until compresing tentioner, it is a litle tricky good luck
Jul 05, 2012 | 2001 Toyota Corolla
I have the new serpentine belt on my 1996 Cadillac Sedan deVille, but am having trouble tightening the tension.
the tensioner should move counter clock wise to place tension on the belt clock wise to remove belt there is a bolt in the center of the tensioner that bolts it to the engine remove this bolt to detach the tensioner from the engine reverse to install the tensioner will place the correct amount of tension against the belt hope this helps
Sep 12, 2011 | 1996 Cadillac DeVille
Is bolt on tensioner for s belt left thread
DRIVE BELT TENSIONER BOLT LOOSEN COUNTER CLOCK WISE TIGHTEN BOLT CLOCK WISE.
Jun 26, 2011 | Ford Mustang Cars & Trucks
How do I remove serpentine belts (2) on 2000 lexus ES300? 1 article says to turn belt tensioner counter clock wise. I don't se a belt tensioner on this model. Thanks
located by alt. just put 1/2" drive breaker bar in it then turn clockwise u not breaking bolt but removing tension from belt more pressure on breaker bar less on belt
Mar 16, 2011 | Lexus ES 300 Cars & Trucks
Turn the right or left to remove the nut
all most every blade mount bolt turns out in a counter clock wise rotation facing the bolt head
Jul 31, 2010 | Honda Arnold 21" Mower Blade 490 100 ...
Fac clutch doesn't comefree
I cant remember counter or clock wise but doesnt matter I believe it comes off counter clock. The easy way is if you have a air compressor and a air hammer. Take the flat bit place on large nut lightly hit the nut until it breaks free. If not take the largest wrench that fits good and safely tap it hard with a hammer , fast hard blow will break it loose. hope this helps
May 25, 2009 | 2005 Chevrolet TrailBlazer
RTO Gas Motor Scooter 50cc Logo
918 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
