Question about Dryers
My dryer has stopped working and it smells burnt. What could be the problem? Is it worth getting it fixed?
  • Dryers Master
  • 8,220 Answers
Look for lint blocking air flow in the vent or up in the DRYER
Posted on Oct 05, 2009
Is it worth getting my Beko tumble dryer fixed?
of course only 2 years old it should be .
Mar 12, 2015 | Dryers
Dryer only runs as long as the start switch is pushed and held. When I let go of switch the dryer stops.
Time for a diagnosis before something gets burnt beyond recovery. If you can fix appliances, there is a tech sheet hidden inside the unit somewhere behind the control panel. If not, an appliance repair tech can get you fixed up the same day if he has parts in his truck.
Feb 19, 2015 | Dryers
Thermal fuse blown....likely causes????
The thermal fuse trips out when it builds up too much heat. That is caused by the vent being restricted. Clean out the vent the lent trap and any lint build up in the machine. Hopefully this will fix you problem.
Feb 04, 2012 | Dryers
Neptune dryer turns on and works for about 10 minutes, then shuts off. When the door is opened it is very hot and has a burnt smell. The only setting that does not have a burnt smell is air fluff. All...
remove the front cover and drum and clean out all lint including lint filter blower wheel housing and all exhaust vent piping from inside dryer to outside discharge,if this is done and it persists,replace the cycling switch and high-limit thermostat as these may have welded themselves and can no longer control heat
Aug 23, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Our dryer is overheating, after 20 25 minutes then we smell a burnt plasticy smell, then we let it cool down, start again, it goes for awhile, then stops, then again overheating, then the smell again.
Firstly, you need to stop running your dryer before you do any further damage,
As you haven't specified your brand or model of dryer, I can only give general advice. It's likely that your thermostat has failed in the closed (on) position. The thermostat cuts power to the element when your dryer reaches the correct temperataure.
Most dryers also have a thermal fuse to cut all power to the dryer if they overheat. This functions as a backup safety device and this only usually trips when the thermostat fails. Your dryer is stopping because the thermal fuse is cutting power, but as you can smell burnt plastic, it's likely some damage is being done before the thermal fuse trips.
Stop using the dryer, and check/replace your thermostat.
Please rate this solution if you find it helpful. Thanks!
Oct 31, 2010 | Dryers
Dryer Wont Start - Smells Burnt
check for shorts and something holding the fan also look at breakers
Aug 11, 2009 | Whirlpool GEW9200L Electric Dryer
Dryer smelled of burning plastic, smoked stopped turning on
check the power cord itself, if you see on the back side of the cord a burnt or blackened spot then the cord is the issue
Apr 12, 2008 | Dryers
Denon Receiver flashed PROTECTION and stopped working after plastic smell
i just had the same thing happen to me what did you do to fix it?
Dec 28, 2007 | Denon Audio Players & Recorders
Dryers Logo
183 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
