Apple iPhone Smartphone Logo
Posted on Oct 05, 2009
My iphone is stuck on zoom. It goes there immedietly after I sync it. It works fine as long as its not synced to my itunes:( Double clicking with 3 fingers up and down doesnt work
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
310
Points
9
3 finger double tap!!!
How to transfer photos from canon camera Sx530 to iPhone
You can export photos on canon camera to computer with SD card first. And then transfer photos from computer to iPhone. Just follow the below steps to learn how to transfer photos from computer to iPhone.
Using iTunes to sync photos with iPhone is also easy. As a media management center, iTunes helps you easily manage data and files (purchased and non-purchased) on your iOS devices (iPhone, iPad and iPod). You could easily sync data and files to iPhone with iTunes. But you should be very careful of the syncing function of iTunes because it is a double-edge sword. Once wrong click, you may lose data in your iPhone. You'd better back up your iPhone to iTunes before you try to sync photos to iPhone with iTunes. The following steps are going to show you how to transfer photos from PC to iPhone with iTunes:
1. Plug your iPhone into computer via the USB cable. Launch iTunes if it doesn't launch automatically. Make sure that you have the latest version of iTunes.
2. Click on the device icon in iTunes.
3. In the sidebar on the left side of the iTunes window, click Photos tab under your iPhone.
4. Click the box next to "Sync Photos". If instead you see "iCloud Photos is On", all of your photos and videos are already on all of your devices that use iCloud Photos. You don't need to sync them through iTunes.
5. Choose the app or folder that you want to sync from. If you choose to sync a folder with sub-folders, the first level of sub-folders will appear as albums on your device.
6. Choose to sync all photos and albums or selected albums.
7. Select "Include videos" to sync the videos from your app or folder too.
8. At last, click the "Apply" button.
You may need your Apple ID to start the photo syncing. If iTunes asks, type your Apple ID into the blank, and then the synchronization starts.
But as mentioned above, iTunes is a double-edge sword. iTunes has very strict content management system, and the software never allows users to transfer files which are not got from iTunes back to computer or iTunes Library. So when you are transferring photos from PC to iPhone, iTunes wants to sync with your iPhone. Once syncing with it, you may lose the files which are not got from iTunes.
For more details, check: How to Transfer Photos from PC to iPhone
Can I transfer pictures to ipad
Yes, there are lots of methods to transfer pictures from computer to iPad. Just follow one of the methods shown below.
For more methods, check: How to Transfer Photos from PC to iPhone
2answers
How do I sync my iPhone 5s with my desk top
1.Download iTunes to your Mac/PC
2.Plug in your iPhone to desktop
3.Open iTunes, it will find your iPhone
4.Click your iOS device
5.On the Summary tab, select "Sync with this [device] over Wi-Fi."
6.Click Apply, then disconnect the USB cable
7.Choose which items you want to sync, then click sync.
Sync your iPhone iPad or iPod touch with iTunes using Wi Fi
How to transfer photo from view nx2 to iphone 5
You can export photos on view nx2 to computer first. And then transfer photos from computer to iPhone with iTunes/iCloud or other tools. As for transferring photos from computer to iPhone, you can follow the below steps.
How do i sync photos onto my iphone
First of all, we would like to talk about the official solutions provided by Apple: iCloud and iTunes, both of which help Apple users to manage their data and files on iOS devices (iPhone, iPad and iPod) effectively. You could transfer photos from computer to iPhone with iCloud and iTunes respectively:
Using "Photo Stream" to transfer photos from PC to iPhone automatically with iCloud is pretty convenient. Go to "Settings > iCloud > Photos (Photo Stream on iOS 6)" and then turn on My Photo Stream. Then get your iCloud started on your PC. In the iCloud Control Panel, Check the "Photos" and then enable the "Photo Stream" option. After that, import the photos into the "Photo Stream" folder on your PC, and then you will be able to view the photos on your iPhone. Using iCloud to transfer photos from computer to iPhone is easy, but this method needs Wi-Fi connection. Only over Wi-Fi connection can iCloud sync photo on PC with iPhone. The following steps will show you how to transfer photos from PC to iPhone with iCloud.
Jul 09, 2011 • Cell Phones
1helpful
My iphone icons are enlarged
If the icons on your Home screen appear too large, the zoom feature may be enabled on your device. use iTunes to enable or disable any accessibility feature, including Zoom:
  1. Connect your device to a computer and open iTunes.
  2. Locate and click on the device under Devices
  3. In the Summary pane, click Configure Universal Access:
dmooney_eire.png 4, Select Neither to disable Zoom: dmooney_eire_0.png
  1. Click OK and then click Sync to save the changes to your device.
If you do not have access to a computer or iTunes, use the following steps to disable Zoom on the device.
  1. On the Home screen, double-tap with three fingers to exit zoom.
  2. Locate and tap on Settings > General > Accessibility:
Tap Zoom and turn off using the slider:
1helpful
3answers
How to transfer my ringtones in the laptop to my iphone
First you must be sure that your ringtones are in the correct format. Watch my YouTube video to see how you can create your own iPhone ringtone:
http://www.youtube.com/watch?v=mx5yVC_FEn4
Once your all done creating your own ringtone, simply sync your iPhone with your iTunes and all the ringtones you created will be transferred to your iPhone.
For more iPhone / iPod tips, click here.
646helpful
4answers
Iphone screen has everything enlarged so you can't see what you'
thanks, this is the solution I need. Use 3 fingers to double click the screen
3answers
Iphone ringtone
WHEN YOUR IPHONE IS CONNECTED TO YOUR MAC/PC UNDER DEVICES YOU WILL SEE YOUR PHONE THEN GOT TO RINGTONE TAB AND SELECT SYNC LL RINGTONES REMEMBER THAT YOU CAN ONL DOWNLOAD PURCHASED RINGTONES TO YOUR IPHONE.
FOR ANY MORE SUPPORT GO TO APPLE.COM/SUPPORT
13helpful
9answers
How to sync contacts from iphone to outlook 2003?
When you connect your iPhone to the PC that you always sync with, Go to Info tab, Check the box Sync Contacts with: and select Outlook. Then make sure that you check the box Put new contacts created on this phone into the group: and select a subfolder in your main contacts folder.
This way, all the contacts from your iPhone will be saved into another folder in your main contacts folder of your Outlook PST.
Let me know if you have any questions.
Thanks
Sandeep
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
