Question about U.S. Robotics Modem: U.S.Robotics 56K V.92 Performance Pro Modem (FM3CP5610B)
I own a USR5637 which worked fine with everything
I own a USR5637 external modem which worked fine with everything until my power went out one night and now when I plug it to a phone line I get no dial tone and I can't use Dial up internet. How can i fix this?
EricZollman
  • 9 Answers
SOURCE: Modem not recognized
This could be one of many things, but my first suggestion is this.
Open up your Device Manager:
Right click My Computer and select Properties - click on the hardware tab - click the Device Manager button.
Inside your Device Manager check to see if your Modem has a yellow or red icon next to it...
If so open the properties for your modem and click on the resources tab. This page will tell you if the devices IRQ number is conflicting with any other devices.
If the IRQ number is the problem try changing it, then re-booting your computer.....
Posted on Feb 22, 2008
SOURCE: No Dial Tone
yes
Posted on Apr 17, 2008
  • 2920 Answers
SOURCE: How do get a dial tone when using the data fax modem?
try bypassing their modem and see if you get a dial tone,,,if you do then you know thats where the problem is
Posted on Feb 26, 2009
  • 40 Answers
SOURCE: Modem connects to internet but I have no dial tone to make calls
I have personally seen this issue before and with an Arris cable modem the issue you are having means that there is a over current issue with your phone line. What this means is that your phones are either getting to much or to little voltage. Usually this is caused by a crossed phone wire/staple through a phone line or possibly corrosion on your line. The first step into troubleshooting this would be to check where your phone lines tie together at and make sure nothing has come loose or broken. Also if you any of your lines run outside to a phone box go in the customer side of that and check to make sure there is no corrosion. This can also be caused by a phone going bad. Go around and unplug your phone lines 1 at a time from the phone line and see if it starts responding correctly. You made need to power cycle/reset your modem when you do this to clear the error. The final way that you can tell if it is in your phone line or not is to unplug the modem from your house line and plug a phone straight into the modem. This should make at least that one phone start working correctly.
Posted on Apr 09, 2009
  • 31 Answers
SOURCE: Can't get modem to work
Do this
  1. unplug modem from computer
  2. uninstall drivers
  3. reinstall drivers first then
  4. install modem
  5. check for updates at moto site as well microsoft.
  6. swap USB cables if its a plug and play device.
  7. check phone line swap for a cat 3 RJ 11 cable not all modular cords are the same
  8. Cheapo dollar store or made in china labels on mod cords are decieveing, poor quality as well construction . Buy a Qulaity cord.
  9. check phone jack if you own a puppy or kitty the love to mark and green corrosion will mess a jack up. replace if its green ans well the mod cord may be green don't waste time in cleaning it. key word RESISTANCE !
as a CET in electronics and I have been around a long time, ignore some unprofessional advice less stress that way.
Posted on Apr 16, 2009
My Belkin N750 DB intermittently drops my internet connection to both wireless and ethernet connected devices. I POR it and it works fine until the next time it quits. Is there a fix or is this just an...
Some people turn everything off at night and then when they turn things back on everything starts powering up. If you do this, it may be the problem because you have the modem and the router starting up at the same time. If the router finishes before the modem then it will drop.
Just make sure that you turn your wireless router on after the modem had booted up. This problem also happens when you have a power outage in the house and they both boot up at the same time.
When ever you are experiencing drops, just go unplug the wireless router then plug it back after about 30 seconds.
Jun 03, 2012 | Belkin N750 DB Wireless Dual Band N Router
I plug my router into my modem and it just doesn't want to work with me. Everything was working fine, and then last night my connection gradually got worse until I lost the Internet. I plugged my computer...
There must be a small reset button on your router. Hold it down for 30 seconds. Release it. wait for one minute. Now unplug the power and plug it back in. Wait for 1 minute.
Once you reset the router, it will come back to factory default settings.
You will need to reconfigure the router form the start according to your Internet service provider.
Click here for step by step instructions
Sep 26, 2010 | Linksys Wireless-G WRT54G Router
Internet Connection problems
If you want the public IP Address assign to your computer, setup your modem into Bridge then create a broadband dialer to your computer. Through this dialer, you have to type in your username and password which will allow you to connect to the internet.
Jun 09, 2009 | Computers & Internet
U.S ROBOTICS 56K FAXMODEM DRIVER SOFTWARE REQUIRED(EXTERNAL MODEM
hi
here is the link
http://www.usr.com/support/product-template.asp?prod=5686e
May 20, 2009 | U.S. Robotics (USR5633A) Modem
Airlink AR670W connection issues
You need to power down the modem, router and computer then turn them all on in the order - modem first, then router, then computer... Doing that and barring anything else that should work for you!
Apr 03, 2009 | Airlink AR430W Wireless Router
Black Screen after sitting for awhile
Might be that the graphics card is overheating.
Nov 08, 2007 | Acer Aspire 5100 Notebook
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
U.S. Robotics Modem: U.S.Robotics 56K V.92 Performance Pro Modem (FM3CP5610B) Logo
233 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Michael Galve
Michael Galve
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
