Question about Black & Decker BDHF600T Heater
Why does plug on small sunbeam portable heater turn black?
  • 41 Answers
Nowadays nearly all materials are commercially made,when the plug turns black that means it was over heated due to loose connection,you will not know, so after of about 15 mins u have run the portable heater,and check if the plug is hot,if yes the plug and socket are not matched so by changing to a better quality you will not get this type of problem
Posted on Oct 05, 2009
Code ff on portable electric heater. What does code ff mean
If its a Sunbeam you need to check the electric cord an make sure it is plugged into heater an wall socket well. Really need brand an model to help more.
Jan 27, 2015 | Refrigerators
Heater wont turn on at all
could be thermostat or thermofuse.
Jan 28, 2014 | Sunbeam SLP3300UM Heater
Plug gets hot on my vintage sunbeam CG waffle maker
You can replace the power cord on these models easy enough, as the cord is actually attached to a small black, plastic box that can be opened to replace the cord. You can find cords at home improvement or hardware stores. Before going this route, make sure the wall outlet you are plugging the waffle iron into, is properly grounded. You can check this by using a small outlet testing tool that lights up green or orange if installed properly or improperly. It also checks for reverse polarity, in addition to bad ground.
Jan 13, 2013 | Sunbeam Cg-1 Vtg Waffle Maker Iron...
Sunbeam heater SQH310 keeps shutting off when it is on 2, what do I do?
If you have the same heater i do then in between the elements at the bottom there is a safety swith that bends when it heats up and breaks the connection Dont mess with it plugged in it will shock the hell out of you but if you bend it down it wont be able to lift off the circut and will stay running untill you turn it off
Oct 26, 2012 | Sunbeam Heating & Cooling
Get F2 error code on sunbeam heating pad model cat93, contrller sw404
Crimped the ends of the heating pad cord where it attaches to the pad a little then did the plug and unplug three times while holding down the on-off button and that did the trick
Jul 03, 2011 | Sunbeam 805810 HeatSense Heating Pad...
I have have my sunbeam electric heater model number sfh090 for a month now and it just stopped working and wont turn on or anything! i tried leaving it unplugged for a while then plugging it back in but...
Have you tested the receptacle that the heater is/was plugged into, to make sure it's working and a circuit breaker hasn't been tripped?
If not, plug a lamp into the receptacle to see if it works. If it doesn't, check your home's circuit breaker panel for a tripped breaker. If you find one, make sure there's nothing still plugged into the offending receptacle and reset the breaker. Then, plug the heater in and turn it on. Does it trip the breaker again? If it does, there's some type of short in the electrical system of the heater. If it doesn't trip the breaker, but still doesn't work, return it to the place of purchase for a replacement. However, you must have your Proof of Purchase Receipt to do this.
Hope this helps solve your problem.
Feb 17, 2011 | Sunbeam Heating & Cooling
I use a small portable propane heater that has 6
Carbon monoxide poisoning !! do not use !! Get it checked for clogged intake air, as well as have burner checked and cleaned. Obviously running too rich, and intake air supply is getting cut off somehow.
Dec 29, 2009 | Sta Rite Maxi Therm 400k Btu Propane...
E2 CODE ON SUNBEAM SCK14200DR
I just fixed this on mine one minute ago.
Take off the front panel.
You will see a black wire held onto the heat fins by a plastic clip.
This is the thermocouple that measures temperature.
Mine became unplugged from the circuit board and plugging it back in fixed the problem.
The wire goes into a steel box.
take off the screws on the bottom of the box, grab it by the lowed left corner and bend the metal up as far as you can.
The wire plugs into a small white connector on the circuit board.
plug it back in, bend the metal back down, screw it in, replace the cover, and you should be good to go.
-Alexander W MacFarlane IV Ph.D.
May 23, 2009 | Sunbeam Heating & Cooling
Malfunction heating pad
Same F2, quick off problem here. Then I noticed that the gray plug on the power cord was not completely flush with the connector on the pad. I shoved them together until there is no gap. The unit's worked perfectly since then.
Mar 24, 2008 | Sunbeam 805810 HeatSense Heating Pad...
Black & Decker BDHF600T Heater Logo
124 people viewed this question
Top Black & Decker Heating & Cooling Experts
paulcarew
Rob
Rob
John Aman
Are you a Black & Decker Heating and Cooling Expert? Answer questions, earn points and help others
