Question about Panasonic PT-51G44 51" Rear Projection Television
Blue bulb out of alinement
I have a pt51g63w panasonic rear projection tv and the blue bulb is out of alinement and leaves a double image. The blue light still works how do i get it back with the other two...
    President:
  • 788 Answers
Your symptom sounds like a damaged convergence IC.
This is a common failure for this particular television. The power light might be blinking indicate a short in the power supply, this will happen soon if you do not repair the set before the STK's short out.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
asnowman
Posted on Oct 07, 2009
We have a Panasonic PT-56wx53 projection TV that has a double image problem. We have tried to fix the issue with the convergence feature, but the blue color will not line up, red and yellow working fine. ...
Does this problem happen all the time ? What I mean is , if your watching the local news thru your cable/sat box does ot happen, or just when using aux imput. Either way, double image, or shadowing, is usually caused by a defective wire. Troubleshoot each unit, unplug everything and start from scratch.
Mar 06, 2011 | Panasonic PT-56WX53 53" Rear Projection...
I have panasonic rear projection tv. There is
The PT53WX53 convergence repair kit available at www.tvrepairworld.com should repair that issue. The repair kit contains the parts and the CD with instructions.
Oct 15, 2009 | Panasonic PT-47WX53 47" Rear Projection...
I have a Hitachi 43 " projection tv. There was double image in green and purple. I was able to fix it manually. The auto focus would not work. Now the problem is the appearance is curved at the top and...
Pull front bottom panel off of TV on convergence board where ICs are in Front of board is a setup switch Small blue contact switch Press and hold untill convergnce Pattern appears Now aline convergence, you must have you hand unit that came with TV.
Oct 02, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Double Image blue color
Need to have the convergence board repaired it will require 2 ICs and various resistors, expect to pay around $300 Julio milleniumtvsvc@gmail.com
Jul 22, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Blue shadows on my philips projection tv
You have possibly contaminated fluid in your blue picture tube if it has a hazy look.Blacks and whites look bluish and whites have a blue bloom to them.The other problem could be bad convergence amps.This would be double image around letters on the screen.
Jan 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Toshiba 43A10 projection television
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 04, 2007 | Toshiba 43A10 43" Rear Projection...
PT-47WX, Blue streaks across the screen?
It is not a bulb. It is a picture tube. If there are thin blue lines across the entire screen, not just the edges, and the picture itself looks too blue, it means that the blue picture tube is being driven too hard. This could be because the blue screen voltage is too high, the boost voltage on the blue picture tube is too low, or the video output is leaky or shorted. If the picture has what looks like blue arcs and double images on one or more sides of the picture, it means that one of your convergence IC's has burned out and needs to be replaced. These are things that should be tested and serviced by a qualified tech, so allow an experienced tech to handle it for you.
Sep 07, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-51G44 51" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
