New tv, connected to new satellite receiver, connected to Bose serge protector - tv randomly turns off, then on, repeatedly until unplugged from wall. you can view a few minutes or a few seconds. this is the second tv to do this, replaced old tv with this new one. replaced old receiver with new one. tried with and without serge protector, tried another wall outlet on different circuit. music system plugged into same serge protector, works fine. been going on for 5 days. help! thank you
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If you have checked everything then the only thing left is the power cable or the in house fuse which is not getting it to work. If all this has also been checked then you need to get this new one replaced as the unit itself could be faulty.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks Rylee
Posted on Oct 05, 2009
My tv is not 'seeing' any of the hdmi devices plugged into it.
surge protectors do not work very well. They dont really stop mildly high voltages. If you can plug the Directv receiver into another TV and it works, then you have a bad digital board in your TV.
Aug 15, 2015 | Toshiba Televison & Video
I have sound from satelite box through bose 321 but no picture on tv
First, you need to run the coax cable from your satellite dish to the "cable in" input on the back of your satellite receiver, not the Bose. If your satellite receiver has an HDMI OUT, and if the Bose has an HDMI IN,run hdmi OUT from the rec. to the Bose IN, then keep your HDMI connection from the Bose OUT to the TV IN as is. Make sure you've selected the correct input on the TV menu. As it is right now, you're not delivering any video signal at all to the TV!! -only audio(red and white). There are a couple other ways, but they won't give you the same quality. I assume this is HD, right? If you CAN do it this way (i.e. if you have enough HDMI ins and outs), it's the best possible hookup and you won't need the composite (red, white and yellow) at all. By the way, it's the yellow connector that carries the video signal; the red and white are audio left and right. If you can't hook it up all HDMI, disconnect the "separate cable" (I'm not sure what that is or what kind of cable or what it's for)and plug in the yellow connector into video IN on the Bose.
Feb 08, 2015 | Bose Av321 Series Ii Media Center For 321...
How to use Bose Acoustimass 5 speakers with new 5.1 receiver
Receiver Front L& R speaker sockets connect to Bose L& R IN.
AM5 satellite speakers connect to Bose Front L& R OUT
Set AV receiver to that Front L&R are LARGE
That's it. Then run the AV Receiver's set-up mic wizard if it has it.
Aug 27, 2014 | Audio Players & Recorders
How do I eliminate the humming on my Vizio VHT-510 system
see this instruction and fix it. God bless you
    • 1
      Disconnect the coaxial cable at the back of the satellite receiver or cable box by unscrewing the coupler on the cable end.
    • 2
      Attach the cable to the RF IN jack on a surge protector and tighten the coupler clockwise.
    • Sponsored Links
    • 3
      Connect a second coaxial cable from the RF OUT jack on the surge protector to the input on the cable box or satellite receiver. If this stops the hum, congratulations: You're done.
    • 4
      Unplug the subwoofer's electrical cord from the power strip or wall outlet if it is connected to the same circuit as the AV receiver. The amp in the AV receiver and the amp in the subwoofer are in conflict over the grounding of the electrical circuit.
    • 5
      Plug the subwoofer into its own surge protector and connect the surge protector to a different wall outlet than the AV receiver uses.
    • 6
      Disconnect the subwoofer cable from the back of the sub and the AV receiver if all other measures fail to stop the humming. Reverse the plug connections so the plug that had been connected to the receiver is now connected to the subwoofer. Turning the cable around may solve a problem known as ground-loop hum by reversing the shielding wire inside the cable.
Read more: http://www.ehow.com/how_6979184_eliminate-sound-home-theater-subwoofer.html#ixzz2ZdzrgBSa
Jul 20, 2013 | Vizio Vht210 2.1 Home Theater Soundbar...
We just got a new Dish HD/DVR Receiver and need the remote code for the Bose remote control to operate it.
Here is what I did for my Bose Solo Tv to work on the Bell 9242 receiver.( see page 17 of Bell 9242 guide) 1. Hold down the aux button until all lights flash. 2. Press 2 to ensure Aux is set to audio. 3.Enter code 761 and press the pound (#) button. Now to have the satellite remote default volume to Bose Solo do the following. 1.Press and hold AUX 2.press # pound 3. Press the + side of volume 4. Press 0 5. Press pound ( AUX button will flash 3 times) 6. Press SAT mode 7. Test the volume on Bose Solo. (see page 22 of Bell 9242 guide)
Jul 05, 2010 | Bose 3 2 1 GSX System
HOW TO INSTALL BOSE 321 SERIES THROUGH TV AND SATELITE RECEIVER
Hi! It would just be easy. Just prepare RCA cables and connect the cables to the tv and satellite receiver. Link the TV and satellite audio output to the BOSE audio input. Good luck and have a good one!
Apr 13, 2010 | Bose 3 2 1 GSX System
Power is no long working
try pushing the reset button on the serge protector it my be turned off...
Apr 13, 2009 | Televison & Video
RCA 27F524T Power comes on But no Picture
i want to know who wants to sell me their rca t.v?
Jan 21, 2009 | RCA 27F534T TV
Home theater reception
you need to unlpug your set and reconnect everything over and see what it does.if that does not work have a tech check your system.your sony recviever is the culprit let that be checked.good luck
Apr 05, 2007 | Sony KP-53XBR45 53" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
