Question about LG Vu CU920 Cellular Phone
What does emergency dowload mean - LG Vu CU920 Cellular Phone
  • A Miller May 11, 2010
    that is a great question ... I give up ... whata does it mean?
Where is the emergency flasher located on a 1997 Pontiac grand am
You mean the button to make it turn on? Should be on steering column. Your mean the flasher itself? In the fuse block. Should be two, one for the turn flasher, one for emergency.
Dec 15, 2014 | Pontiac Grand Am Cars & Trucks
My phone screen is saying emergency calls only
Emergency calls only usually means the company has cut off your service, usually for non-payment. If it was another problem, like no signal, you wouldn't be able to even make emergency calls. Call your provider.
Sep 30, 2014 | LG CE0168 Cellular Phone
What does ice mean and how do you use 911
Adding ICE ("In Case of Emergency") to your phone is a clever means by which emergency personnel can locate your next of kin when something goes wrong. This simple idea was developed by a British paramedic, Bob Brotchie, who recognized the need for speed when emergency personnel are trying to locate next of kin during disaster situations. Here is the simple way to keep your loved ones informed. 1.Open your cell phone's address book.
2. Program ICE - "In Case of Emergency" - with the name of your emergency contact into your speed dial. For example:
  • - ICE Bob
  • - ICE Mom
  • - ICE Mrs Crabby
  • 3. Let other family members and friends know. Alert family members that you have done this and encourage them to do so as well. This will help speed up responses from emergency personnel when they have to decide who to call in case of your injury.
  • To call 911, you dial 911 on your phone
Sep 27, 2014 | Kyocera Contact - Prepaid Phone Paylo by...
My thermostat has both auxillary and emergency light on,both are green,what does that mean?
Aux light; This turns on when the auxiliary (second stage) heating is in operation
It turns on 1-6 F below first stage and is user adjustable
Emergency light; This light turns on whenever the emergency heat is manually selected
(Mode switch is in the EMER position)
While in the emergency Heat mode, the heat pump compressor is off,
and the emergency heat (same as the auxiliary heat) maintains the
set point temperature
Jan 22, 2014 | Computers & Internet
I was charging my lg phone on my laptop so i decide tu download some music i unplugged the phone and then plugged it back and a window on my laptop appeared to dowload and lg site so the computer can...
You have bricked your phone by disconnecting it while it was updating. Emergency mode is the safe mode of phones, you should never disconnect your phone while it is updating or transferring files.
Apr 28, 2011 | LG GT540 Cell Phone
My mobile take emergency call its meaning
It means you can only dial emergency numbers such as the police (911 in USA).
Mar 10, 2011 | Computers & Internet
NO POWER TO MY OBD PLUG CANT BE EMMISH TESTED DONT KNOW IF IT IS A FUSE OR RELAY
It is most likely the ecm,this is the problem on the emissions test failure most likely.
Jun 03, 2010 | 2003 Ford Windstar
File Download problems
it,s mean ur download r not complet to resolve ur problem u can download again these driver.
Mar 20, 2010 | Computers & Internet
Emergency brake
look under the front of the rubber boot that covers the bottom of the park brake handle, u will see a nut on the end of the park brake cable, tighten it until u reach the proper adjustment.
Feb 27, 2009 | 2004 Kia Rio
LG Vu CU920 Cellular Phone Logo
90 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
