Question about Kenmore 24032\24036 Top Load Washer
Wash and spin cycles work, but rinse cycle stalls.
The washer goes through the wash cycle just fine. when the spinning stops, it sounds like it's bottoming out, and I hear a click when the dial points at rinse. Then I just hear a faint buzz, and it sits there, it won't progress, and if I don't walk over and move the dial, it will sit there all night. It won't start working again until I have it past rinse, then it does its final spin.
I read another person's similar problem, and the solution to check the lid thing that tells the machine the lid is closed. that works fine. So there is somethings else causing the problem.
  • moonblade26 Oct 05, 2009
    I figured it out! I have it on warm wash and cold rinse, but someone never turned on my cold water. So I turned on the cold water (the faucet behind the machine) and lo and behold, it works! I hope other people can solve their problem by trying the water.
    Problem Solver:
  • 3 Answers
Replace timer
Posted on Oct 05, 2009
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
Fisher & Paykel Ecosmart will Wash but not Rinse/Spin
You have too many clothes in the washer. Take some out and try again
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 09, 2009 | Fisher Paykel EcoSmart GWL15
Wash doesn't go through full cycle
I have a Maytag model A490 clothes washer. It works fine up to the rinse cycle and then shuts down. When it reaches this point it has become necessary to manually advance the dial a short ways whereupon it will fill with water and complete the rinse and spin cycles. This happens on both the regular and the permanent press cycles. What needs to be done to fix this problem?
Jul 14, 2009 | Maytag Washing Machines
Will not spin on any rinse cycle
Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
If you will get me a model #, I can look this up for you and give you a better idea.
Vic
Jul 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Sep 21, 2008 | Whirlpool LCE4332P 2.1 cu. ft. Top Loading...
Maytag Washing Machine Stops after wash cycle...
sounds as if you have abad contact in the timer
advance the timer to a different spin cycle and see if it spins
then bo back to where it stops
if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
Apr 21, 2008 | Maytag Dependable Clean Top Load Washer,...
Kenmore 24032\24036 Top Load Washer Logo
182 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
