My Gemini DJQ 1500 turntable spins extremely fast (much faster than the 33 or 45 RPM selection). It used to work fine. Speed selector buttons and pitch adjust slider seem to have no effect; the start/stop button still works. No apparent physical damage to the unit. The previous time it was used (about a year before), it worked normally, and was not moved from its position and connections since then. If nothing else, having a service schematic for the turntable would be helpful, rather than trying to trace the entire circuitry myself.
  • 1,889 Answers
With no power applied; soak your slider switch(s) with alcohol; then: move the switch(s) back and, forth rapidly to clean them of dust/lint
let dry completely and, repower/test.The turntable should now work correctly.
Posted on Oct 05, 2009
Turntable spinning to fast
Clearly an electrical fault. Could be something to do with the power supply or the speed control circuit, or even the motor itself.
For the manual visit the Gemini website.
Apr 21, 2013 | Gemini PT-1000 II Turntable
Direct drive spinning to fast
Sounds like a speed sensor in the motor has opened up. You need a repair shop my friend.
Technics sl5200 turntable spins too fast
Make sure the turntable speed is on the appropriate level for each record (33 rpm or 45 rpm), then check the voltage selector and make sure it is appropriate for your housing electricity.
Mar 27, 2013 | Audio Players & Recorders
Gemini DJQ 1200 turntable not giving off sound (music). Just hears humming noise...
Bad connection to cartridge or a faulty cartridge. Disconnect wires to cartridge and with amp on, touch each wire end with your finger one at a time. You should hear a buzz on two wires - one for each channel. This proves that everything is working after the cartridge.
Feb 01, 2013 | Audio Players & Recorders
Spins too fast
Check that the belt [under turntable] is`nt twisted or the 33/45 speed button is`nt sticking on 45rpm
Feb 26, 2010 | ION Audio iTTUSB Turntable
GOING FROM 45 TO 33
I don't know if this model is direct driven or by belt. If it's belt driven then the belt could be fitted incorrectly, or faulty. Another possibilty is that there's a fault in the motor control circuit.
Jul 28, 2009 | Gemini PDT-6000 Turntable
LP audio recording seems to be at the wrong speed
1- The turntable is set to 45 rpm and the album is recorded at 33 rpm. Press the 33 rpm button the red light should come on turn the and be fine.
or
2- This turn table has a fast record mode where you can record a 33 rpm LP faster by spinning it at 45 rpm. If you are trying to use this mode you will have to make a software setting to tell the TTUSB10 digital converter program what mode you want to run.
Nov 29, 2008 | ION Audio TTUSB10 Turntable
Turntable 45rpm speed has stopped working
Check that the lever is actually making the contact with the 45 rpm switch position and completing the circuit as it would seem everything else works. The only other thing it could be is a break on the pcb, but that is unlikely.
Oct 17, 2008 | Philips Audio Players & Recorders
Plays too fast
I had this same problem. You can adjust the speed, although it is a bit of a pain. If you turn the unit over you will see two little holes on the bottom labeled "33" and "45". You will need a small (jewelers) flat head screw driver. If you put the screw driver in the hole you will encounter a rubber cover. Push the screw driver through the rubber and go down a bit further and you will feel a screw. Turning this screw to the left (counter clockwise) makes the speed slower. Turn the screw to the left to make the speed faster.
For a picture you can download the service manual:
www.eserviceinfo.com/downloadsm/24072/Aiwa%20Service_PX-E860.html
You can check the speed visually by downloading a strobe disc (I found one I like at http://www.extremephono.com/free_turntable_strobe_disk.htm). To actually be able to see the strobe you need to do this under a lamp with a single fluorescent light bulb (fluorescent bulbs actually flicker a little bit at the same frequency as the electric supply).
Oct 31, 2007 | Aiwa PX-E860 Turntable
301 people viewed this question
 Grubhead
Grubhead
