Question about HP LaserJet 3390 All-in-One Multifunction Printer
HP 3390 scanner error 6
After changing the X49 cartridge on our HP 3390, I get a scanner error 6 message with the instructions to turn off then on. Didn't help. Putting an old cartridge back in looked more promising with a "enter white sheet" followed by "cleaning". After it spit the page out it went back to error 6.
ImWireless
  • 113 Answers
SOURCE: press enter to align cartridge
Please try this http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00657&cc=us&lc=en&dlc=en&product=60259&dlc=en&lang=en You may also be able to bypass this messgage by following the instructions on this link. Further, please check if the cartridges you are replacing are the correct ones.
Posted on Mar 01, 2007
SOURCE: remove and check color cartridge error
i was woundering are these new cartages or refiled ?
cause our wont work with refilled caratages
so this is how i found that out !
Issue After you install a print cartridge, the scan, copy, and fax lights begin to flash at the same time. The printer will not print. One of the following error messages may display on the control panel:
  • Color or Right Print Cartridge is not compatible
  • Incorrect Print Cartridge(s)
  • Print Cartridge Problem
  • Incorrectly Installed Cartridge(s)
  • Black or Color Cartridge(s) Failed
Solution Follow the steps below until the above issue is resolved. All of the following steps may not be necessary to resolve the issue. When the lights stop flashing, the issue is resolved. NOTE: Either one or both of the cartridges could be causing the problem. Step one: Remove, inspect, and reseat the problem cartridge The print cartridge may not have full electrical contact with the printer. Removing and reinstalling the cartridge may help. NOTE: HP cannot guarantee the quality of remanufactured or refilled cartridges.
  1. Make sure the printer is on. Press the Power button if it is not lit.
  2. Open the printer cover, and then wait until the print cartridge carriage is idle and silent.
  3. Press down lightly on the end of the problem cartridge to release it. Figure 1: Removing the tri-color cartridge c00838141.gif
  4. Slide the cartridge out and inspect it. CAUTION: Do not touch the copper electrical contacts or the ink nozzles. Figure 2: Electrical contacts and nozzles c00838142.gif 1 - Copper electrical contacts 2 - Nozzles
    • Check the electrical contacts for debris.
    • Make sure all the clear nozzle protective tape has been removed. CAUTION: Do not attempt to remove the copper electrical strip. Figure 3: Removing the clear nozzle protective tape c00838143.gif 1 - Protective tape
    • Look at the number on the print cartridge label and make sure it is compatible with your printer. Compatible print cartridges are listed in the Printer Reference Guide supplied with your printer.
  5. If the cartridge is compatible, reinstall it in the printer:
    • Color cartridges go into the left carriage slot.
    • Black cartridges go into the right carriage slot. Figure 4: Sliding cartridge into place c00838144.gif
Step two: Clean the problem cartridge contacts If the steps above did not solved the problem, follow the steps below to clean the electrical contacts on the print cartridge and in the carriage in the printer.
  1. Gather the following items to clean the cartridge and print carriage:
    • Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water may contain contaminants which could damage the cartridge.
    • Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
    • Sheets of paper or paper towel to rest the cartridges on during cleaning.
  2. Open the printer lid and wait until the print cartridge carriage stops moving.
  3. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up. NOTE: If you are removing a print cartridge, try to clean the contacts quickly enough that the cartridge is not outside of the printer for more than 30 minutes. The ink can dry and clog the nozzles if the cartridge is outside of the printer for too long.
  4. Unplug the printer.
  5. Dip a swab in the clean water, and then squeeze it to remove most of the moisture. The swab should be only slightly damp.
  6. Clean the print cartridge contacts. The illustration below shows the contacts. Do not touch the nozzles. Figure 5: Electrical contacts c00838145.gif
  7. Clean the contacts in the print carriage, inside the printer. The illustration below shows the carriage and the contacts.
  8. Either let the cartridge sit for several minutes to allow the cleaned area to dry, or use a new swab to dry it.
  9. Reinstall the cartridge, plug the printer back in, and close the printer cover. Figure 6: Print carriage contacts c00838146.gif
Step three: Repeat reseating and cleaning steps If the problem is not solved, repeat the reseating and cleaning procedures above.
Posted on Apr 07, 2008
SOURCE: Changing cartridges
I just turned on my hp psc 750 and an error message appeared. Incorrect black cartridge installed
I just used it yesterday, what is wrong???
Posted on Aug 24, 2008
SOURCE: When I change the black ink cartridge, the
I just had the same issue (align page not detected).
We had just re-installed the empty color cartridge back into the printer (long story but basically we knew we could only print B/W).
The align page printout had a lot of empty spaces around the black lines. This is apparently where the color lines are supposed to print.
Without those color lines, the printer would not detect the align page as color is part of the alignment being done.
Since we only wanted black printouts, I pressed 'cancel' to stop the alignment process, and now we just hit the Black copy button and ignore the alignment prompt on the printer window.
The HP site (enter psc750 in product window) has some helpful ideas as to what the problem might also be. It could be the shipping tape is still on the new cartridge (and preventing the black or color from printing on the align sheets) etc.
Posted on Apr 02, 2009
  • 3278 Answers
SOURCE: can't install 3390 toner: door won't close and
Remove cartridge and reinsert. Be certain to insert until it is firmly in place. Hope this helps.
Posted on Aug 03, 2009
My hp 3390 is giving scanner error 6 message and this is following a power outage we experienced 02/09/2011. it wont scan, copy or send faxes though we can print and receive faxes. the scanner bulb moves...
this problem causes malfunction of CCD unit, observe that CCD unit moving both directions are not, its sensing the home position or not, even its crossing home position replace CCD, your problem will solve..Vinay...
Sep 05, 2011 | HP LaserJet 3390 All-in-One Multifunction...
My HP 3390 is leaving a line down the center of the page when I copy only How do I fix this. I have changed the toner cartridge thinking in may have been the toner but it is still doing it
Clean the scanner glass. I haven't worked on the 3390, but lift the scanner cover up and clean the glass and see if there is a narrow piece of glass to the left of the big flat bed glass. That is what's causing the line. Scrub it with a little glass cleaner. I bet you don't get the line when you use the flat bed single sheet scanner.
Sep 11, 2010 | HP LaserJet 3390 Printer
SCANNER ERROR
Message comes with Printer Scanner Error 6
Turn Off Then on
Jul 21, 2010 | HP LaserJet 3055 All-In-One Printer
HP 1005 Scanner error 6
dear Sirs i have HP 1005 did't work and have this message Scanner Scanner error 6
please if you can help me
Sep 07, 2009 | HP LaserJet M1005 Printer
Error messages 10 1000supply error for printer 3390
This error implies the print cartridge is not installed correctly.
The steps to resolve the issue: 1.Reinstall print cartridge. 2. Power cycle all-in-one. 3. If the problem is not solved, replace the cartridge.
Hope this helps!
Aug 31, 2009 | HP LaserJet 3390 All-In-One Printer
Hp2300 laser printer
52.x PRINTER ERROR alternates with To continue turn off then on Possible printer control panel error messages 52.0 PRINTER ERROR 52.1 PRINTER ERROR 52.2 PRINTER ERROR Description A temporary printing error occurred. The x can equal one of the following: 0 = Scanner error 1 = Scanner startup error 2 = Scanner rotation error This error can also indicate a problem with the shutter tab on the print cartridge. Action
  1. Turn the printer power off, and then turn on the printer power.
  2. If the message persists, check the print cartridge for damage.
    1. Verify if the shutter tab on the cartridge is broken or damaged. click on the below link. Shutter tab on the print cartridge
  3. 1 - Shutter Tab
  4. Replace the cartridge if damaged.
If the message continues to persist, then download the printer software based on operating system and reinstall.
HP Laser-Jet 2300d Printer Software
Regards
Chittaranjan
Dec 11, 2008 | HP LaserJet 2300d Printer
Error 50
Is that an error code "Cartridge Error 50C" ? If so, see below....
Cartridge Error 50C: Your print cartridge has shorted.
1. Power off your All-in-One and unplug it.
2. Plug in your All-in-One again and turn it on.
3. Uninstall and then reinstall your cartridges.
4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing - The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing - The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error: Complete the following instructions:
1. Power off your All-in-One.
2. Use both hands to lift up the scanner unit until the scanner support holds it open.
3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
4. Remove the color print cartridge.
5. Lower the scanner unit until it is completely closed.
6. If the error message reappears, replace the black print cartridge with a new print cartridge.
If it does not repeat steps 1-3 and then go to step 7.
7. Reinstall the color cartridge and remove the black print cartridge.
8. Lower the scanner unit until it is completely closed.
9. If the error message occurs again, replace the color cartridge.
10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
11. Lower the scanner unit until it is completely closed.
12. If you receive the error message again, replace both cartridges.
Nov 22, 2008 | Lexmark X5150 All-In-One InkJet Printer
HP Laserjet 3055 with "scanner error 6 - turn off and on" error
hp laserjet 3055 by scanner error 6
Solution: I found a very small piece of paper between the glass and the scanner housing. The lamp's seen that and sent the error message. Nobody find that little stucked paper and the "IT expert" sad: need to buy a new machine because he can't repair it. So, sometimes the solution is very easy just need some attention. :)
Apr 27, 2008 | HP LaserJet 3055 All-In-One Printer
Ink cartridge problem
Mar 18, 2008 | Lexmark X6150 All-In-One InkJet Printer
HP LaserJet 3390 All-in-One Multifunction Printer Logo
1,933 people viewed this question
Seeker5211
Seeker5211
