Question about Garden
Snapper Zero Turn with 21hp kawasaki runs for a few minutes and goes dead and will not start. After setting for a few minutes it starts and runs fine for a while and then the cycle starts all over again.
    Scholar:
  • 108 Answers
That motor has a low oil shut off on it. As the motor warms up, the oil thins out and spreads through out the motor and if it's low or you have bad flow, the sensor will trip the motor off and then the oil will re-settle during down time allowing you to start back up. Had the same motor on my scag. If you haven't already checked the oil level, try replacing your filter. While you are at that, check your hydro level as well. You should change that at about 1000 hours, but check it's level. Check your air filter...For those zeros, follow mfg. reccomended maint. on them and it will save you headaches. I ran a lawn and landscape company and I did daily, weekly, monthly, quarterly and yearly maint on all my equipment. If you are just one to mow on weekends, you should still check over the machine each time you start it up and allow it to warm up for at least 5 minutes before taking off with it.
Posted on Oct 05, 2009
How do I engage the bagger on a zero clearance toro mower
That's should be something I imagine is covered in your owners manual. Why not try going on their website and downloading the manual in pdf format so you can learn.
Sep 27, 2014 | kawasaki 48'' Toro Com Zero Turn Lawn...
How do I engage bagger on zero clearance
That should be covered in your manual. I'm not sure what a zero clearance mower is actually, are you assuming and making up a name for it?
What can I try next? My husqvarna RZ4623 wont start. Nothing when the key is turned.
Is the small wire, coming from the Ignition Key, Getting 12V to the Relay when you turn the Key? Were Mice chewing on your wires?
Jun 25, 2014 | Snapper Husqvarna RZ4623 46" 23HP Kohler...
Snapper diagram belt replacement
Your owner's manual should have a diagram.
Jun 21, 2014 | Snapper 7800765 Riding Lawn Mower, Zero...
Dash board goes dead
1) check and see if your car has a good earthing cable.
20 it could be a loose terminal or fuse.
Mar 15, 2014 | Winnebago 2008 Voyage 32H
My Snapper 48" zero turn is running batteries dead. I just replaced the battery cut my yard once and the battery is dead. What are some possibilities?
The charging circuit is faulty and is not charging the battery when the engine is running. Best case is a bad connection or frayed cable, worst case is a faulty alternator.
Oct 29, 2013 | Briggs & Stratton Snapper 5900748 355Z...
I need to find out what the voltage output and the miliamp output is on a toro z4220 mower my battery keeps going dead i have replaced it once already Thank yoy
You should have around 13.1 volts at the battery as the engine runs. If its 12 volts or lower - check or replace the voltage regulator. To check the regulator, stop engine, remove regulator plug, get a ohm meter and put the black lead to any ground,and touch the red lead to all the terminals one by one on the voltage regulator - you should get 3 readings - one lower than the other. If you dont get any readings - the regulator is definitely bad
Don in Baltimore
May 02, 2011 | kawasaki 48'' Toro Com Zero Turn Lawn...
Bike cranks and runs fine, then for some reason the battery goes dead, I jump it with a quick jump and it starts and runs, I can run it for a few minutes, turn it off and back on starts great, battery may...
Sounds like an alternator or charging problem.
Check to see if you are getting around 14v on your battery with the engine running.
If not you will have to investigate your alternator etc.
Please dont forget to vote this answer was helpful.
Many thanks
Feb 22, 2011 | 2003 Honda VTX
Garden Logo
88 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
