Question about Campbell Hausfeld Air Tools & Compressors
Remove the bearing on a 5hp 110 volt 28 gallon oil less compressor
    President:
  • Campbell Hau... Master
  • 1,388 Answers
This is very hard to do but not impossible. The problem is the rod journal is pressed on the motor shaft. You have to remove the coils / rear end of the motor and carefully place the rotor in a vise. Use a steel rod and hammer to gently force the crank off the shaft by hitting crank from rotor side thru vent holes of front motor housing. It will not be easy and you could easily damage shaft, crank or rotor. (but what the heck, it does not work anyway) If your are successful and able to replace bearing, press the crank back on using loctite then drill 1/8" hole thru crank into shaft and drive in a roll pin. Good Luck!
Posted on Oct 18, 2009
Looking for manual for sanborn B51-A24-80V1 model
PDF]Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1
intrigante35hindu.strictlyyouth.org/rzsatzo_sanborn-black-max-5hp-air-...
Jul 16, 2015 - Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1 ... Black Max Portable Air Compressor - 5 gallon Item #: 81527 ' Model #: BS0880504 ...Compressor Manual: $4.95: Buy Now: B51-AT24-80V,B51-A24-80V1.
Aug 28, 2015 | Air Tools & Compressors
Pressure switch 120 volt compressor how to bypass pressure switch
Un-plug the compressor and remove the cover to the pressure switch. Inspect wire connections for burned /discolored wires. If not burned, look for button to manually trip switch (switch has on /off lever, place in on position). Test with ohm meter for continuity. Switch is normally closed and contacts are usually visable to evaluate condition. Some compressors use a very small sealed pressure switch that is also normally closed.
Oct 25, 2012 | Campbell Hausfeld 5HP 20 Gallon Single...
My compressor bogs out to the point it will stall the motor and blow a fuse. it happens on the third cycle at about 110 to 125 psi
change the run capacitor on the motor,its getting weak,there may also be another capacitor for the start circuit,replace them both
Mar 05, 2011 | Ingersoll Rand SS5L5 Ir Electric...
Can't get it to come on when it's cold.
Warm it up with a heat lamp, hair dryer etc. Release all air pressure from the tank first. Check your oil and use only compressor oil.
Dec 22, 2010 | Ingersoll Rand TS4N5 Ir Electric...
I ran my up-right 5hp compresser out of oil. will
YA YOU CAN DO YOU HAVE A OIL LEAK LD CK THAT IF YOU NEED PATR NUMBERS SEND ME THE MODEL NUBERS AND ILL GETEM FOR YOU AND TELL WERE TO GETEM
Oct 22, 2009 | Campbell Hausfeld 5 - HP 80 - Gallon Air...
My air compressor is running slower than normal and it won't build pressure above 45 psi even if it runs all day
hi mate there could be lots of resons for why it running slow as follows pump unit seizing up i suggest checking oil or replacing oil also check the full load current on the motor with a clamp meter if it is pulling more than 6 amps than what it should on the silver plate on the motor then this could be bearing problems in the motor so basically get a new motor or new compressor
Jul 30, 2009 | Campbell Hausfeld 5HP 26 Gallon Single...
Coleman powermate 27gal 5hp air supply line and regulater gets very hot and blowes off hose
Is a shroud of any sort been took of ? is there oil in pump assembly ? Is there a fan on this model? At what pressure does the compressor stop pumping (should be less than 135psi aroud120psi) are you using it over it's duty capacity ei:sandblasting....?
Jun 04, 2009 | Coleman Powermate 27 Gallon Air Compressor
Type of oil
Air compressor pumps can use different grades of oil depending on weather conditions and usage, however do not use engine oil. Some Ingersol Rand pumps use a synthetic oil available through WWGrainger on the web. (generally not model specific) If this pump is lightly used you can use the less expensive compressor oil sold at Lowes lumber made by Campbel Hausfeld. It sells for less than $3.00 a bottle. Generally speaking, under normal weather conditions and light duty use, do not worry about the weight of the oil; just make sure that it stays clean and at the right level. If your compressor is running hot, it may be due to other problems like the check valve, head gaskets leaking between cylinders or chambers or high usage. If, however you just want the best oil for your compressor, use the synthetic. It is usually colored blue or green. This oil is special formulation to prevent breakdown in high heat and will not allow carbon for form on parts or inside of the hoses. enjoy
Oct 30, 2008 | Ingersoll Rand Type 30 Reciprocating Air...
Air Tools & Compressors Logo
100 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
