Question about Kitchen Ranges
Our Whirlpool gas range does not stay lit. This is the first gas range and it is new and it constantly lights itself during cooking. Is this normal?
    President:
  • 1,304 Answers
This is called cycling and it is totaly normal
gas ranges have a plus or minus 25 degree swing to set temp
it will turn on at -25 degrees
and turn off at +25 this is what maintains propertemp
Posted on Oct 05, 2009
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
I have a whirlpool GW395 gas stove with a problem. When you first turn it on it lights, it will stay lit for about 45 seconds then the burner will go off , after you let it set for about 45 seconds it...
The usual problem with these ovens is the oven burner itself. the burner will click 3 times and usually lights but after a few minutes shuts down and will no light again until you reset the control. If this is happening then try replacing the oven burner. It comes as one unit the burner assembly and electrode. Part # 8191123. If this doesn't work then it coould be your spark module unit. This is about twice the cost or more.
Dec 01, 2012 | Whirlpool GW395 Gas Kitchen Range
HOW TO LIGHT OVEN WITH A MATCH
Look up product manual on internet.
Look at label located inside oven door, and add .pdf to search parameter to help find manual.
Then read section about lighting appliance.
If power is out, then pilot will not have any gas >> if gas control is electronic.
Many electronic gas controls require electric power to operate circuit board.
In old days, you removed the bottom tray on oven to access burner and pilot orifice. Then you pushed down switch to release gas through pilot tube, and put lit match into the gas stream to light pilot. Hold down switch until pilot flame heated tip of thermocouple which caused magnetic switch to stay open inside gas control. Release switch and pilot stayed lit.
Safety concerns and vast advances in manufacturing cheapness have changed gas appliances so they are more inconvenient for do-it-yourselfers during ordinary power outage.
Cook hamburger over metal bucket with newspaper, and grease on newspaper burns enough to cook hamburger.
People always buy generators and flashlights, but nobody suggest buying barbeque briquets and starter fluid as way to keep warm and cook.
Oct 29, 2012 | General Electric GE 24-Hour Power Strip...
I have a whirlpool accubake duo, super capacity 465 and when I try to bake something the oven wont stay on...how do I get the oven to stay on
What do you mean that it wont stay on? Does it turn off and on during cooking? Does it just go off and wont come back on? The oven thermostat regulates the heat in the oven and the oven element and the oven indicator light will turn off and on during cooking. If it stayed on constantly on full oven element power everything would burn.
Mar 01, 2011 | Whirlpool Ovens
Kenmore SF367.....Contantly relighting during cooking?
This is a normal function of your gas range. I own a similar model and it operates the same way. The gas is not required to be on continuously to maintain the oven temperature and will relight periodically when the internal temperature drops below the prescribed set level.
Jul 04, 2009 | Whirlpool SF367 Gas Kitchen Range
Top burners often wont light if oven is already lit
Hello and welcome,
If your range has electronic igniters, then you seem to have one or more bad igniters on top of the range if you have a pilot range then you have a gas restriction or clogged orifice tube.
Even if they make the click noise while trying to light they may not get hot enough to draw the gas on a constant speed!
This will need to be diagnosed hands on at your location.
But this is the fault!
Thank you for using fixya.
Huum
Please remember to leave a solved rating before you leave!
Dec 07, 2008 | GE Kitchen Ranges
Whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
Sep 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Oven light
I'm Neil
No problem
Call Thermadore you have a warranty!
Please rate my soloution
Aug 24, 2008 | Thermador PGR366 Gas Kitchen Range
Oven will not stay lit,
Sounds to me like a bad thermal fuse. Call a tech in to replace it.
Apr 11, 2008 | Whirlpool GS460 Gas Kitchen Range
Kitchen Ranges Logo
165 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
