Question about Vacuums
Vaccuum Burnout? Is there a reset button on the Infinity Shark Vaccuum? The vaccuum got plugged with a dryer sheet and the motor may be burned out but I'm not sure at this point. Can anyone suggest what to do? Cheers, Vince email: admin@vincetigator.ws
    President:
  • 1,673 Answers
Will the brush turn by hand ok, or is it froze up, some models have a reset on the back near the bottom, there could be a fuse, take the bag door off, near the top of the vacuum, there maty be a cover to remove, if there is a fuse it would be in there. The motor protector may be bad as well as the motor. Your vacuum will just have to checked over to find the problem.
Posted on Feb 17, 2008
I don't know which shark vaccuum i have . Question is .. my switch has 3 prongs ( 2 together and 1 by itself. the wires are 2 black and 1 blue. I don't know how to hook them back up ?
877-581-7375 thats the number for troubleshooting for the shark vacuum company. they should be able to tell you the brand and even show you where to find a diagram online to put it back together. hope this helps. good luck
Apr 03, 2018 | Shark Vacuums
What kind of batteries do I need and would work in this Shark Vaccuum???
Loree, Check the attached links,for your models batteries, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Shark Vacuum Battery eBay
http://www.batteriesinaflash.com/vacuum-batteries/shark-vacuum-cleaner-batteries
http://www.sharkclean.com/parts/tag/46/batteries
Euro Pro Shark Vacuum Battery Pack Xbp610
Apr 18, 2016 | Shark Vacuums
How do I get to the belt drive motor of a simplicity x9 vaccuum?
U will have to look for all the screws and take it all apart and look for the abject and remove it!
May 03, 2014 | Vacuums
I had to take apart my shark navigator vaccuum cleaner and clean it. I need a diagram to see where to put everything back, mainly the magnets.
The two long magnets (maybe about 2" and tapered across one long side) go in the housing in front of the brush. One fits on the right, the other on the left. The tapered ends point up. When you put the top cover back on, it will enclose the magnets completely. Took me 45 minutes to figure that out after realizing one magnet was still in place. Sheesh. Lol
Dec 02, 2011 | Shark Helmet Shark Navigator Bagless...
Smells like the motor is burning. observing sparks. It the motor cooked and is it just time for a replacement?
If you're observing sparks, then yes, just get a new one. With the low prices of good vaccuums its not worth starting a fire with your vaccuum. If it just smells like the motor is burning, check the belt and make sure its rotating freely and if you have an attachment, make sure the brush on the vaccuum is not being stopped while using the attachment. However, if you are seeing sparks,,,, definately time to junk it
Aug 20, 2009 | Sharp Twin Energy EC-TU2603 Bagged Upright...
Gen 3 model Kirby vaccuum won't start
Checked your bag if they are full, if bagless check your filter. If still not working maybe the protected temperature fuse blown out. You need to open it and replace the protected blown fuse.
Jul 24, 2009 | Vacuums
Dry/Wet vac is blowing instead of vaccuum
Check to see if the plastic ball is stuck . There should be a ball under the motor , make sure it moves freely. Make sure your vacum lines are not plugged . Best of luck Ed.
Jun 18, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
The brush stopped spinning on my Dyson upright
hi there'
common possible defective is that motor is not functioning,several factors can be check if you have a knowledge on electrical and motor
circuit you can easily diagnose your problem on your vacuum.
check the switch by your multi tester,if there is a continuinity resistance using multi tester.if no continuity replaced switch
check the carbon brush of the motor if worn out, replace two pcs. of carbon mounted inside the motor casing
you can check also the continuity of electrical cord and plug.replace if if plug and electrical cord is defective.
finally the motor has winding coil,at both end of coil of motor check the continuity,there are two coils of the motor.if burn out replace motor w/ two pcs. of carbon brush.
besure to unplug the vacuum before doing
this and this should be done by qualified technician on your service center.have a nice day.rate my fix.thank's a lot
Jun 10, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Possible reset on Thermal Cut-Off
This is not really expert advise but I have a vaccuum with hepa filters and if the filters get dirty My vaccuum acts like your what you are describing.
Jan 07, 2009 | Eureka Vacuums
Vacuums Logo
212 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
