Question about Kenmore 24032\24036 Top Load Washer
Water is sperting like the pump is going out. Is
Water is spurting like the pump is going out. Is that an easy fix?
    Problem Solver:
  • 18 Answers
Remove the from panel and visually inspect the pump. It sounds like a loose connection on the pump discharge line.
Posted on Oct 05, 2009
I have a submersible Gould pump in a well. Recently air is getting into my system and coming out as irregular spurts. I replaced the water storage tank and the check valve, and the problem persists
Sounds like pump is not set deep enough and getting air. If the pump is as deep as it can go you may have to have to screen in the well changed or cleaned with acid pellets.
Dec 28, 2014 | Plumbing
Fisher & Paykel ecosmart GWL11 fill problem
Your diverter valve is cloged with lint and not fully closed and is letting wash water go down the drain.
Feb 22, 2012 | Fisher and Paykel GWL11 Top Load Washer
Pool pump not working properly. air in lines
The air gets into the lines on the suction side of the pump and the pipes and valves leading to it. I could write a pamphlet or chapter of a book on this topic. Anything that can let even a little air in can cause it. A quick way that can detect where the problem on about 50% of the time. When you get the water flowing as much as possible and then you shut off the pump while you watch the pump and pipes on the suction side then a spurt of water may be visible. When you fix it then less air should get in when you run the pump. Another trick is to shut off the pump and listen carefully for any sound as the slight suction in the pipes tries to draw the water back into the pool. Another trick is to use a hose with water to water the pipes, valves, pump, etc. and when you move it from place to place and if the air visibly decreases in the pump bowl then you may have found the leak.
I hope this helps
Sep 12, 2011 | Pool & Spa
Why does the pressure washer water come out in bursts?
Is your inlet water supply open fully, it will pump in spurts if the pump is not receiving enough inlet water volume and pressure.
Mar 27, 2011 | Garden
Just borrowed this pump - how do I hook it up?
if you look on the fitting area where the hoses connect to - there should be a arrow indicating water flow.
if there is no arrow -- take about a cup of water and pour it into one of the pump fittings and turn the pump on real quickly -- this will show you with a spurt of water what side is the out and what side is the in.
c...
Feb 22, 2011 | Flotec 1/2hp Cyclone Pump
I've just changed the bearings and seal, now it
Hi just read your posting.Now did you check all the wires were put back in the original places that they came from when you removed them from the motor ,pump,and rotor position sensor?When the machine stops filling do you get a beep from the machine and a series of lights turn on indicating a fault code?.If you do which lights are lit when it beeps?With the information on your posting the fault sounds like your out of balance switch is faulty or your rotor sensor is faulty.Was the machine leaking water and was the bearing rusted before you changed the bearings and seal?Please reply with additional information on the questions and I am sure I can help you further.
Jun 28, 2010 | Fisher and Paykel GWL11 Top Load Washer
WATER SPERTS OUT OF WATER DISPENSER WITH NO CUP PUSHING LEVER
HELLO,
The cup pushing release lever is most like loose, it could be easily replaced and then the water spillage is no more...:)
Sep 09, 2009 | Refrigerators
Water spurting from the water dispenser.
hold it in ad remove a a few quarts, you have air trapped in the line (normal after replacing water filter), large pitcher if possible
Feb 26, 2008 | KitchenAid KSBP25FKSS Side by Side...
Kenmore 24032\24036 Top Load Washer Logo
26 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
