Question about Imation Computers & Internet
Imation apollo pro ux 500gb external hard drive was detected but not showing up in my computer. Try everything. Need help
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 05, 2009
Driver windows xp
Drivers for USB-attached external drives were built-in to XP.
Mar 01, 2014 | Imation 27614 Apollo UX Portable 500GB USB...
Imation Apollo M100
https://www.imation.com/en/consumer/external-hard-drives/ External Hard Drives
Jan 29, 2014 | Imation Apollo UX 2.5" USB Portable (250...
Driver windows 98
Hello
If you are trying to update the windows drivers in your computer then I suggest that you use RadarSync because Windows 98 drivers are hard to find nowadays. The software will look for the driver updates in the databases of the manufacturers so you won't have to find them one by one (time consuming).
David
Jun 06, 2013 | Imation Products - imation - Apollo Pro UX...
Apollo USB M250 HDD1TB once pluged in makes pc not responding have tried different pc and cables
Umm well i got a 1 tb Apollo M250 external hard drive an it has a green light.......is dis a problem
Jan 23, 2012 | Imation Products - imation - Apollo Pro UX...
Windows 7 gives a error 43 and does not recognize Imation Apollo Pro UX 1 TB USB Hard Drive
Try in another machine. Does not work?
Remove the drive from the case (only if there is no more warantee) and connect the drive directly to your system to determine if the problem is the drive or the enclousure.
Sep 12, 2011 | Imation Products - imation - Apollo Pro UX...
I need to install the driver information to a new computer for the Imation Apollo Pro UX external hard drive
What operating system are you using? There is usually no need for drivers on external HDD. The computer usually recognizes it and installs the necessary software for it.. Let me know if this answers your question and good luck..
Sep 09, 2011 | Imation Apollo UX 2.5" USB Portable (250...
Describe your Imation Apollo UX 2.5" USB Portable (250 GB) Hard Drive Problem
Please repost your problem, and enter a description of your problem in the textbox where it says "Describe your Imation Apollo UX 2.5" USB Portable (250 GB) Hard Drive Problem"
Aug 25, 2011 | Imation Apollo UX 2.5" USB Portable (250...
I have an PHDD 500GB apollo HD. it fall from my hand and now when i connect it only light appears, but no detection or further is happeneding please guide what can be done ..
Hard disks do not like being dropped, there is nothing that can be done to repair it.
If you need the data off this hard disk, there are companies that can recover data off damaged hard disks BUT it will cost you an arm and a leg for their services.
May 09, 2011 | Imation Apollo UX 2.5" USB Portable (250...
Hi.My Imation Apollo 2.5" 500GB
With any luck, it may just be due to a loose cable or connection inside. You need to open the unit and make sure everything is properly connected.
Mar 14, 2011 | Imation Apollo UX 2.5" USB Portable (250...
Computers & Internet Logo
2,014 people viewed this question
Top Imation Computers & Internet Experts
Raj Patel
Jax Planet
Jax Planet
carey w mason
carey w mason
Are you an Imation Computer and Internet Expert? Answer questions, earn points and help others
