Question about Canon PowerShot A80 Digital Camera
Says replace battery pack even with new batteries. Have tried several sets of new batteries. Other functions not working - just a blank screen with replace battery pack message.
My samsung transform ultra shuts down for no reason.. replaced battery. Even replaced phone.. new one does it too. I won't even be using it when it jus shuts off.. why? How can I fix it?
Could it be the screen saver is activating, blanking the screen, so that it reduces battery consumption? Try going into your phone settings and adjust the screen saver.
Nov 03, 2013 | Cell Phones
EReader EBA 701. Turned it on for the first time and picked an included book from the library. Got to page 3 and screen froze. Device had plenty of battery. Would not recognize any commands or keys....
Sounds to me like either the battery pack is defective, or the power supply is. I would go get new battery for it , Best Buy carries them, and see if that works. If you replace the battery, but it still doesn't work, then it is most likely the power supply that is faulty.
Jan 19, 2011 | Computers & Internet
Left computer running with charger connected. Screen went blank and light showing power connected was no longer lit. New charger did not solve it. New battery (with some charge) worked. Still no charge so...
If your charger is working properly and the laptop is as well, then the laptop should work without a battery in it at all. If your new battery worked and laptop worked with it until the battery died, then the charger or charge port is damaged.
If it does not work with charger plugged in without a battery, then your charger(s) or the laptop charge port itself may be damage or broken. Or worse, the laptop may be dead.
If the laptop does nothing even with a good battery with charge (no fans, no boot, nothing on-screen, no noises) you're laptop could be dead; likely a burned motherboard or processor. It may have overheated or something along those lines.
Jun 13, 2017 | HP Compaq 6730s Notebook
The LCD monitor setting was lost after changed battery pack
Take a picture with the new battery pack. Is the picture also blank? Are the menu selections still visible in the LCD? Have you tried pressing the DISP button on the back, but the screen still remains blank?
If the answer is yes to these three questions, this sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Dec 19, 2009 | Canon PowerShot SD110 / IXUS IIs Digital...
My lcd screen is blank but the camera acts like it is taking a picture. Cannon PowerShot S3 IS
Had the same problem with my S3 is and couldnt find any help other than to junk it and buy another camera. WAY too expensive to repair (out of warranty)
I found a post and this worked for me...just fixed it about an hour ago. Mine would show a blank screen on the LCD nothing thru the view finder other than the menu screen. Found out the shutter was stuck and that seems to be a common issue with these cameras. This is how I fixed mine.
1. set the shutter speed to the longest setting you can. I put mine on the TV setting.
2. close the flash and set turn off all of the functions you can to conserve the batteries.
3. take a picture and within 5 seconds open the battery door. Then close it back and repeat. Your trying to interrupt the shutter reset process thereby "unsticking" the stuck shutter.
4. If this fails then try LIGHTLY tapping the camera against a piece of wood, again to unstick the shutter.
Sounds like a bad idea but considering I had tossed my camera in a drawer and already replaced it, I didnt really have much to lose. I was pleasantly suprised to see that after about 15 resets (steps 1-3) and a couple of light taps, the camera is working good as new again.
Good luck, hope it works out for you!
Jul 11, 2009 | Canon PowerShot S3 IS Digital Camera
Front screen is blank
Some times phones just do this, they malfunction.. my chocolate did it many times. take it in to a verizon store they will give you a new one. Hope it all works out! =]
Mar 05, 2008 | LG enV VX9900 Cellular Phone
Screen is blank
You tell me that you tried new batteries. Have you tried a set of NiMH batteries? They are the best for digital cameras. Please try a set, preferably ones rated 2200 or higher. If this doesn't help, the lens could be jammed. Hang onto the batteries though, because they are rechargeable and can be used in anything that takes AA batteries.
Apr 14, 2007 | Olympus FE-115 Digital Camera
Canon PowerShot A80 Digital Camera Logo
152 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
