I have a ML250TPA propaneLP heater after lighting does not burn off where bricks glow red like there are flickering hope this make sence.Thanks
  • 41 Answers
This is normal,just ,if there is a tap close it a bit to decrease the quantity of gas,till you will see it ok
Posted on Oct 05, 2009
My mother has a 3 brick wall unit...two of the bricks burn with a blue flame now instead of the inferred...should she replace that wall unit?
Hopefully, Becca the unit won't have to be replaced at this time. It sounds like the burner(s) is clogged and and needs to be cleaned To do this, turn the pilot light OFF and allow the unit to cool. Remove the front of the heater cabinet to access all of the inside workings. Carefully remove the 3 ceramic plaques and set them aside, where they won't get broken.Using a vacuum cleaner that has a hose, brush attachment and crevice tool. Vacuum all of the interior of the heater that you can reach with the brush attachment and crevice tool. Then turn your attention to the burner(s), Vacuum them thoroughly using the brush attachment, then switch to the crevice tool attachment and vacuum all the little holes on the top of the burner(s) thoroughly. Before reassembling the heater, carefully vacuum the ceramic plaques on both sides using the brush attachment. Be careful not to drop them. Then reinstall the plaques and the front of the heater cabinet.
Light the pilot and allow it to burn for 2 minutes, before turning the control knob to ON. Watch the plaques and the flames to see that burn as they should after turning it ON.
If the above didn't solve the problem, depending on the age of the heater, it may be time to replace it.
I hope this helped you and thanks for choosing FixYa.
Aug 16, 2011 | Reddy Heater RLP100 Portable Forced Air...
My flame is above the guard on the heater in the middle flame. How do I adjust the flame to be lower?
this is happening because the bricks need cleaning. I imagine the flame is burning blue instead of glowing red in the middle brick. Contact your local propane or natural gas dealer about getting the heater cleaned. This type of problem causes a huge loss of efficiency and could be dangerous.
Oct 29, 2010 | Vanguard International Infra Red - Medium...
The power brick on my xbox 360 is red and is not overheating yet i smaell burning plastic from my xbox 360 console anyone have any tips?
A red light on the xbox 360 power brick usually indicates the Xbox 360 console has a short circuit. Here is how to be sure:
1. Try unplugging the power brick from the wall and from the xbox 360.
2. Wait about 30 seconds and plug the power brick into the wall power outlet.
3. Make sure the indicator light on the power brick is orange. ( If it's not orange then get yourself a new power brick and try again ).
4. Plug the power brick into the Xbox 360 console and try to power it on.
If your power brick turns red or you get an immediate three red ring error than you will need to have the console professionally repaired.
If your warranty with Microsoft has expired; the company I work for GATpro Repairs offers this service at a low flat rate and we pay for the return shipping.
Good Luck and I hope this has helped!
Michael GATpro Repair Technician
Jun 14, 2010 | Microsoft Xbox 360 Console
The brick does not glow red you see the flame all the time, goes up pass the brick. Is this repairable or dangerous? (Dyna glo gas wall heater -model RMI-70LP)
Both repairable and dangerous. The burner need blown out with a air compressor. This should take care of it. The unit not glowing red will create CO. Which will make you sick or even can kill you.
Jan 06, 2010 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Flame burns to high
I had this problem. From using the center brick most of the time, lots of dust bunnies build up in the gas chimney behind the brick.
Tie 2 pipe cleaners together with a small perpendicular circle at the top and carefully remove the dust bit by bit by twirling the cleaner.
The brick should fire like new if it is carefully cleaned out.
Jan 25, 2009 | Vanguard International Infra Red - Large...
Infrared Heater - flaming thru plaque
Jan 15, 2009 | Procom ML060HPA Heater
I was wondering where i could buy a replacement pressure regulator for a procom model ml250tpa
Try Procom Customer Service at 877-886-5989. Or call Kozy World at 800-776-9425 and tell them you have a KWP324 (same as ML250TPA).
Dec 27, 2008 | Ace Hardware ML250TPA Infra-Red Wall...
Heater doesnt stay on when the temp gets colder
Ventless heaters such as these have an oxygen depletion sensor that monitors O2 levels at the burner and shuts the unit off if it drops below a certain percentage (assuming that there will be carbon monoxide production). Check your owner's manual for any requirements such as a window or door needing to be open while this heater is in use.
There also is the possibility that there is water in the regulator of your propane line (if it is outside) that freezes and inhibits the regualtor's function.
Feb 06, 2008 | Ace Hardware ML250TPA Infra-Red Wall...
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
