Question about Kodak EasyShare P850 Digital Camera
What kind of lens would i need to zoom in on movings objects that are far away, how much zoom would i need.
No possibility to focus objekts
Your lens elements are not moving smoothly. Maybe gummed up.
Mar 01, 2012 | Konica Minolta DiMAGE Z10 Digital Camera
The problem is myself I don't know how to use it!!!!!!!!!! I have eos rebel T2i with a ef-s55-250 lens I took some photos of my grandsons doing a roof job and they look really far away,thought I had...
Practice, practice and more practice. With the 18-55 lens you are going to have to use your feet as zoom too. What you see in the viewfinder should be what you see in the final picture so if you can not zoom in close enough you will need to move yourself closer.
Don't be discouraged it will get better.
Jun 16, 2011 | Canon EOS 550D Rebel T2i Digital Camera
How do i the camera to take smaller pictures and if it is by using the zoom do I zoom in or out.. Thanks
Hi sportingnut4 ,
Thanks for the question ,
  1. If you mean by smaller pictures i.e. small in area you have to capture the images keeping the distance in perspective.
  2. If the distance between the image and camera is more , you would find the object being captures is small and if the distance is less , you would find that the object that has been captured is bigger.
  3. If you want to capture an object which is far away you can use the Zoom In function which would zoom your camera's lens in the object.
  4. If you have already Zoomed in , then to decrease the zoom i.e. to go away from the object as if you are increasing the distance between the object and the camera , you should Zoom out.
  5. Remember , Zoom out usually only works when you have already used the Zoom in function of the camera.
Hope this helps.
May 11, 2011 | Sanyo VPCE890 Digital Camera
I like to get up close pics of objects especially plants and scenery. The problem is when I zoom in the picture is always blurry and cannot focus on objects that are not far away. Is there anyway setting...
most cameras come with an option called macro,this setting is for close up shots.on your camera it needs to set at wide angle.when choosing the shooting mode move left or right and choose the icon of a flower.if you adjust the zoom, a zoom bar will appear at the top of the lcd.if you try to use a zoom not intended for macro shots the flower icon will gray out and the bar will appear yellow,if you take a picture with the yellow bar it will be blurry.if you zoom out a little until it stops you should be ok. if you use a flash in macro mode the images edges usually will darken.hope this helps.
Jan 08, 2011 | Canon PowerShot SX100 IS Digital Camera
I need instructions for minolta freedom zoom 70 exI want to know what macro does.
Hi. As a pro photographer, I can tell you what 'macro' does on all cameras or lenses. 'Macro' focusing is for focusing on close objects, say an inch or two from the lens to a couple of feet. It is for closeup shots, say ants, or a fly, or someone's eye, raindrops on glass, etc. Try it out sitting on a patterned countertop or table or tablecloth to give you an idea, focusing far away and up close.
As far as the manual, there doesn't seem to be anything on the official site unfortunately. Good luck and have fun.
http://gi.konicaminolta.us/index.asp
Apr 14, 2009 | Minolta Freedom Zoom 70 35mm Point and...
Which zoom lens to buy for my pentax zx-50
Two lens should be good enough. First one for closer objects, 28-80mm lens which covers wide angel to portrait shoots and 70-200mm for distance shootings. Bring the camera to the camera shop to try on. Some pawn shop should have good prices. makes sure to purchase with returnable guarantee if not satisfied. -Good Luck. -James
Apr 05, 2009 | Pentax ZX-50 35mm SLR Camera
How to achieve full zoom with a Nikon 55-200mmf/4-5.6G ED lens?!
1) What camera body are you using?
2) I do not understand your assertion that it automatically zoomed in. Zooming is a manual function. The automatic functions of your lens pertain only to focusing on of the subject so that your picture is sharp and ensuring that the correct amount of light is admitted so that you have a correct exposure.
3) Are you sure you were turning the zoom ring and not the f-stop ring? The zoom ring is labeled 200 on one end of the scale and 55 on the other. It is also the widest ring on the lens barrel. When you rotate it, the physical length of the lens will lengthen as you rotate it clockwise (viewed from behind the camera) and shorten as you rotate it counter-clockwise.
4) For reference, at 200mm the angle of view on your lens should be 10 degrees and at 55mm about 40 degrees.
Dec 27, 2008 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED...
Ricoh XR-10 35mm SLR camera
stevdan,
take the screws off the bottom cover. there is a small lever pointing toward the front of camera with a black screw on it. gently move it to the left, this will release the lock lever. Now advance the lever and the shutter should fire. if not, it is not repairable. no parts
Sep 12, 2008 | Ricoh XR-10M 35mm SLR Camera
Lens Problem
Mine was exactly the same. They seem to work fine, just give the camera time to focus. After a while, I tired of the slow pace of the C8080 and sold it, moved on to the Konica Minolta A2 which is a much more responsive camera. I've since pretty much stopped using it too: the Pentax *ist DS DSLR is a near perfect fit for the photography I love to do and works the way I want a camera to.
Sep 13, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
If you zoom to less than 12x
Sorry you're having such a problem with the fz1 w/b-macro. Here is a shot of the stock fz1 w/b-macro at full 12x zoom - resized only. Try practicing on still objects such as coins or jewlery. If you are beyond 10-12 inches you are probably too far away.
Sep 06, 2005 | Panasonic Lumix DMC-FZ1 Digital Camera
Kodak EasyShare P850 Digital Camera Logo
18 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
