Question about Olympus Camedia C-2040 Zoom Digital Camera
My olympus camedia c-2040zoon all of a sudden stopped focusing. can i fix it
bmwrider
  • 215 Answers
SOURCE: olympus camedia c-300 zoom auto focus
I've changed about 30 Olympus lenses and not once have I had to calibrate anything. Software won't fix it, there isn't any such program and never will be. If you use the Optical viewfinder to get focus it's possible you've put that back together with the teeth missing the guides. Are you sure you replaced that tiny piece of glass (filter) between the lens and the CCD. Is the CCD locked on correctly? What is it you're using as a reference for focus? If it's the LCD and it's OK then the lens etc must be OK and the fault lies after the LCD. It certainly sounds like you missed something unless the second lens is faulty as well. As for not being able to fix a faulty lens it's definitely possible, just bloody time consuming. BMW
Posted on Jul 28, 2006
IB4G2008
  • 3587 Answers
SOURCE: Olympus Camedia C-740 Focus Problems
check batteries please?
Posted on Mar 16, 2008
  • 919 Answers
SOURCE: Memory card for Olympus Camedia C-3000 Zoom
https://emporium.olympus.com/innards/emp.asp?val100=100&step1=615&step2=0
This is the link to the Olympus website online store where you can purchase replacement smartmedia cards.
Posted on Jan 14, 2009
  • 11967 Answers
SOURCE: Olympus camedia c 5050 turns on and off upon
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 22, 2009
itls
  • 17 Answers
SOURCE: How do I download photos from my Olympus Camedia
PLUG IN YOUR CORD AND USB TO COMPUTER AND TURN YOUR CAMERA TO THE GREEN ARROW.. THEN SEARCH FOR THE FILE K:\DCIM
THAT WILL OPEN UP WHERE ALL YOUR PHOTOS ARE!!!
FOR THE C-4000Z
Posted on Jan 06, 2013
I am not getting any audio when i record a movie with the Camedia D-425
Records movies. As the focus is locked while recording, be sure to keep the distance between the camera and subject constant to avoid losing focus. Audio recording is not available.
Dec 27, 2008 | Olympus Camedia D-425 / C-170 Digital...
How to disassemble camera?
Not exactly for your problem but a illustrated manual how to fix the mode dial problem and how to disassemble the 5060: http://www.wrotniak.net/photo/c-wz/c5060-dial.html
May 30, 2008 | Olympus Camedia C-5060 Wide Zoom Digital...
Not Focussing
sir,i think this is not focusing problum, u see any optic mois or finger prints ?u first clean this
Mar 04, 2008 | Olympus Camedia D-425 / C-170 Digital...
Camedia C5060 Focus Problem
Hi I have the same focusing problem, the camera was fine until it was switched in to Super Macro, since then the camera will not focus either manually or auto
Jan 18, 2008 | Olympus Camedia C-5060 Wide Zoom Digital...
Camera won't take picture
A quick question. Are you using an xD card that is larger than 256 MB? If so, I contacted Olympus about this very issue. The maximum capacity of xD cards my camera would recognize was 256 MB. According to the Olympus rep. the camera does support up to 512 MB, but required a firmware upgrade and needed to be sent in for this. My wife's Canon camera had no such limitations and even has better quality.
Sep 25, 2007 | Olympus Camedia C-50 Zoom Digital Camera
Olympus camedia c-300 zoom auto focus
hi, really surprising, how could you fix the problem, it will be fixed only by replacing the lens assy. so just go to olympus shop. good luck....
Jul 28, 2006 | Olympus Camedia C-300 Zoom Digital Camera
Focusing distance in macro mode
The Macro Mode operating range is 8 inches to 20 inches. This means the camera must be between 8 inches and 20 inches away from the subject for a picture to be in focus.
Aug 31, 2005 | Olympus Camedia D-395 Digital Camera
Olympus Camedia C-2040 Zoom Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
