Question about Garden
I have a Bolens 4.5hp push mower and it runs but the engine sounds like its going to cut out. Why?
  • 472 Answers
YOU PROBLEY HAVE TRASH IN YOUR CARB YOU MAY WANT TO CLEAN IT OUT AND INSTALL A KIT IN THE CARB
Posted on Oct 08, 2009
Bolens 11a 074e065
Empting the gas tank and filling with fresh gas may take care of the problem.
Sep 28, 2013 | Mg International MasterCut 20" 123cc Push...
Bolens push mower Briggs mower when pulling fo start and running pushes gas out of the ventholes of the fuel cap.
I think that you have a defective gas tank lid that is not venting properly which could pressurize your system and cause problems. Invest in a replacement and hopefully this will solve your problem. The cap has a small breather vent cover [it sort of looks like a small mushroom], this allows air to enter the tank, but keeps air/fuel from going out of the cap. Some mowers use a pressurized system, and I am not sure if Bolens is one of them.
Sep 21, 2013 | Garden
I have a Bolens Model 13AM762F765 38inch cut 15.5 HP twin blade lawn tractor. It runs like a champ as long as I do not engage the blades or put it in reverse. It will stall if either of these two things...
Sounds like a safety switch. Just as there is a safety switch under the seat that shuts mower off if you get off seat while engine is running, theres also safety switches for, pto, drive, reverse, etc. I would get a multimeter and look for switches under chassis and test with meter for continuity.
Aug 08, 2013 | Mtd Garden
One year old bolens push mower, 550 series B&S
How is your compression? If it is low, your piston rings and/or the cylinder walls could be damaged and pulling oil up to the combustion chamber, which will burn oil and foul the plug. If you overfill the oil you could possibly get this also. When was the last time that you changed the oil and/or put oil in it? Do you currently have proper oil level?
Sep 06, 2011 | Briggs & Stratton Garden
I have a bolens 4.5 HP/22" cut mower thats sputtering and sometimes stops working. Other than that it's not a bad mower but I need it to stop cutting out.
Check the air filter. Often people forget about that and when they get clogged the engine runs really poorly. If that checks out, check the spark plug and the quality of the spark. After that I would look to debris in the carburetor.
I hope this helps get you going soon.
Aug 17, 2011 | Garden
ENGINE STALLS ON MY BOLENS BRIGGS AND STRATTON PUSH MOWER AFTER RUNNING FOR A FEW MINUTES EVEN WHEN I'M NOT CUTTING HIGH GRASS.
The ignition coil may be going bad, especially if the motor will not restart for a while after it dies. This is located next to the flywheel. You are going to have to remove the shroud to get to get to it. You can use a business card as a spacer from the flywheel when you put a new one in. If you need to figure out how to get the part you can reply and I can tell you how to find it.
If this is really helpful, please rate.
Jul 13, 2011 | Garden
Motor runs, but will not go forward or rever
if you can push mower by hand ? there is a shuttle valve that may have got turned on , its a little handle in the back of the mower that turns off the hydrolics so you can move the mower without the motor running
May 21, 2010 | Garden
What is the spark plug gap on a 4.5 HP 21" cut
With out the model # of engine or plug not 100% certian but 99% of those mower engines run a .8 or .9mm plug gap you will be preety safe setting it at that
Regards
Brad
Feb 05, 2010 | Mtd Products Yard Machines 158CC Tiller
L have a Bolens 12 Hp ride on mower purchased new 1992 l have not used the mower for the last 7 years due to update to a larger mower.L'd like to have the bolens as a spare mower. What is missing from my...
Bolens is now owned by MTD. Find parts for your machine at http://www.bolens.com/webapp/wcs/stores/servlet/topcategory_10151_15953_-1 or your local MTD/Bolens dealer
The bigger challenge you will have is getting the engine running again unless you have maintained it the past 7 years. My free advice is get the motor running and make sure the tractor still functions before you start adding accessories. Once you have driven it around the block once or twice, then get the parts you need to operate the deck. I think these parts will be a little pricy.
I say these things because of a similar experience with a International Cub I got. I spent a lot of money to get the mower running before I got the tractor running, reliably. I didnt get my fair value from my $ as a result. I then bought a geenuine Troy and have never looked back. (MTD owns the Troy brand now also.)
Good luck with your project
Thanks for using FixYa.com
Please vote
positive comments appreciated by volunteer question catchers.
a
Dec 12, 2009 | Radio Communications
Garden Logo
670 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
