Question about Whirlpool Washing Machines
How to remove rhe spanner nut - Whirlpool Washing Machines
    Problem Solver:
  • 18 Answers
Buy or rent a spanner wrench.
Posted on Oct 05, 2009
How to remove basket from drive hub after spanner nut has been removed
You have to rock it side to side if that doesn't work since it is all metal and probably stuck with detergent heat it with a propane tourch wont do any damage
Aug 27, 2014 | Whirlpool Washing Machines
Tip
Whirlpool / Kenmore Washer - Drive Block
Whirlpool / Kenmore Top Load, Direct Drive Washers.
A number of the diagnostics and repair procedures for these washers require you to remove the agitator(s).
In order to get the agitators out, you need to remove the "Spanner Nut" and "Drive Block".
Many instructions call for a special spanner wrench to remove the nut.
However,
You don't need a special spanner wrench. (About $20 retail)
I've used a short 10" pipe wrench (About $9 also good for cracking walnuts) hooked around one of the tabs on the spanner nut and tapped the handle with a hammer to loosen it.
Also, don't directly hit the drive block with a hammer (it's soft metal). Put a short piece of wood under the drive block and tap it up with a hammer.
on Dec 01, 2009 | Washing Machines
How do i remove the nut spanner from a new Whirlpool top loader washer (is it a right hand or left hand threading)
The spanner nut is standard thread to loosen/remove it turn it to the LEFT,you do need a spanner wrench like the one pictured here oldtech2332_37.jpgPart number for that spanner wrench is TB123A It can be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apdepot.com
midwestapplianceparts.com
apwagner.com
Aug 21, 2011 | Whirlpool LTE5243D Top Load Stacked...
How do I remove the spanner not from the shaft on my kenmore 110.9228110
Right hand threaded nut holds tub in place is direct drive, top loading washing machines. To remove the spanner nut you will need a spanner wrench
May 31, 2011 | Kenmore Washing Machines
Can,t remove nuts for trailing arm rear end.
Use a de-greasing spray like WD40 , apply for some time and then use a good set of BOX spanners or ring spanners with the correct size to wrench free the nuts. If jammed use a double end spanner with a hammer but with caution , not to damage the nut or allow it to be rounded off.
Mar 21, 2011 | 2006 Mitsubishi Galant
Where do I get the tool for Spanner Nut / Whirlpool top-loader washer.
You don't have to buy a special spanner wrench ($20) to remove the spanner nut. I've used a short 10" pipe wrench (about $9.00 also good for cracking walnuts) hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
Nov 30, 2010 | Washing Machines
Spanner Nut removal
I had my wife hold the drum while i used a large pair of channellocks and got it off!
May 16, 2010 | Washing Machines
WHEN FAAUCET COMPETE SHUT DOWN AND STILL LEAKING
Delta Single lever? Remove handle by loosing the allen screw . Tighten the spanner clockwise. If that doesn not fix problem, turn water off, remove spanner nut. Remove whole assembly. Take to plubming supply and latch us for rebuild kit.(two rubbers, two springs,. a spanner wrenchand an allen wrirenc and maybe a new spaner nut) Install same.
Mar 10, 2009 | Plumbing
Changing the disc
There are two methods in changing a disk.
somewhere on the machine you will see an arrow showing you
the direction the disk travels when being used, the nut that holds the disk
on always undoes opposite to this.
normal method
unplug grinder, use the 2 spanners supplied with the grinder.
one will look like a normal spanner but thinner, this goes on the nut over the disk.
the other spanner has 2 nodules which fit in the holes on the nut under disk.
whilst holding the disk stationary with the thin spanner, rotate the noduled spanner
in the oposite direction to the disk rotation when being used.
on some models of grinder, a button on top of the grinder must be
pressed in, this stops the rotation of the disk when replacing disk.
This button performs the same function as the flat spanner.
emergency method
If you cannot find or have lost special spanner(s)
pushing the palm of your hand firmly onto the disk surface and rotating
the disk with a sudden **** in the opposite direction to that when being used
may loosen the nut. if the nut is tight hold the disk firmly and use an old
screwdriver in one of the holes and tap nut loose with a hammer on screwdriver.
last resort........if possible break the disk using pliers and remove all pieces.
putting a new disk on is opposite to method that you used to remove one.
Oct 18, 2008 | Makita 9553NB 4" Angle Grinder
Washing Machines Logo
176 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
