Question about Husqvarna Viking 1
Need to find a combined foot pedal power cord item 411-79-50-19 for an older machine (960). Any advice?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
Your best bet is to simply get on the phone and call Husqvarna Viking dealers that have a repair shop in their store. Be prepared for the cost. Those were about $120 or so at the end of their production. But alot of dealers hold onto used ones when old machines are thrown away, so a deal on a used one might be an option.
Posted on Oct 08, 2009
Testimonial: "Thanks, found the pedal and power cord (used) at a local dealer. Lucky break!"
What would cause my Kenmore sewing machine's light to turn on but the motor seem to have no power?
The wiring for the older Kenmore is simple. The light switch completes the connection to the light. If the foot pedal has failed or connection loose where the wire attaches from the foot-pedal the motor will not run.
Also if the brushes in the motor are worn or failing to contact the motor internally the motor will not run.
With light on and pedal partially depressed attempt to activate motor to determine if brush connection are faulty. If the motor reacts at all the brushes will likely need to be replaced.
No success borrow a foot pedal from a friend or sewing center to determine if the pedal control is faulty.
Hope this helps?
Oct 15, 2016 | Kenmore Sewing Machines
Want a spare foot pedal control to run the sewing machine model Husqvarna viking emerald 122/118/116
You would have to check this link out but this might be a solution: http://www.sewingpartsonline.com/foot-control-w-cord-universal-033770217.aspx
Feb 06, 2015 | Husqvarna Sewing Machines
Need cord foot pedal to machine Artista 180
They can be purchased thu Bernina as a separate item.
Cheers
Mar 21, 2014 | Bernina Artista 180
Brother serger slows down
it could be the motor or the power cord or the foot pedal,
check to make sure the power cord and the
foot pedal are connected correctly to the machine.if they are
then the machine and power cord and foot pedal need to be
checked
Nov 13, 2012 | Brother 1034D Serger Sewing Machine
How to set up
  • Remove your Janome sewing machine from the box, placing the main machine on a hard surface appropriate for sewing and the accessories and smaller items to the side. Unwrap all of the wrapped items. Remove the tape used to protect the machine during shipment. Set aside the power cord and foot pedal.
  • 2
    Attach the power cord to the machine. The power cord plug-in area is located on the lower right side of all Janome sewing machines and has a series of metal prongs and a power switch. Fit the female end of the power cord onto the metal prongs and push it gently until it no longer moves.
  • 3
    Attach the foot pedal to the machine. The foot pedal plug-in is also located on the lower right side of all Janome machines, right next to the power cord plug-in. Press the foot pedal plug-in into place gently until it no longer moves.
  • 4
    Turn the power switch on. The power switch is located in the same area as the foot pedal and power cord plug-ins and is a rectangular black switch. Press this button. The sewing machine light will turn on.
  • 5
    Place a spool of thread on the spool pin, located on the upper right top side of the sewing machine. Place the thread so that the thread unwinds in a counterclockwise motion, with the thread coming off the back of the spool.
  • 6
    Insert a needle into your machine. Consult your owner's manual for the appropriate size and type of needle. Turn the needle clamp screw, located above the needle area, toward you to loosen it. Turn the needle so that the flat part of the upper shaft area faces the rear and slide the shaft of the needle up and into the needle area. Turn the needle clamp screw away from you to tighten the needle and lock it into place.
  • 7
    Wind the bobbin and insert the bobbin into the bobbin case. This procedure may vary depending on the model of your Janome machine, so consult your owner's manual for specific instructions.
  • 8
    Thread your machine according to the directions in your owner's manual. Like the bobbin, this procedure can vary widely depending on the model of your Janome machine.
  • 9
    Set your tension, located on the front of the machine, to halfway between three and four. The tension may be a dial or it may be computerized and located on the LCD screen, depending on your model. Consult your owner's manual to find out how to set the tension.
  • 10
    Place a piece of scrap fabric in the machine and sew a test seam before you start to work on a project to make sure all of your settings are correct.
    Things You'll Need
    • Janome sewing machine
    • Owner's manual
    • Needles
    • Thread
    • Bobbin
Jan 11, 2012 | Janome Sewing Machines
Foot control will not work machine just stoped mid stich
Try using the Start/Stop button instead. It works just like the food pedal. You might like to bring the speed down first or else it will take off like a rocket when you press the button! You hit the button again when you want to stop. Sounds like you might need to replace the food pedal - unfortunately an expensive item. Try taking it out of the machine, coiling up the cord, uncoil it and re-insert being sure to push the plug in firmly. Check along the length of the foot pedal cord to see if there are any cuts in the cord. If there are, it will definitely need replacing.
Jun 02, 2010 | Husqvarna Designer I
Shark Euro Pro X model 384
Go to the Euro-Pro website and call them. They will eventually send you out what you need. I received this machine as a gift and it came without a foot pedal, power cord or manual. I have since received the power cord and foot pedal (after a year!), but now can't pull the manual up on their website. It's so frustrating. I'm thinking of selling this darn machine as soon as I have everything. I have owned it for a year and a half and haven't even used it!!
May 05, 2007 | Euro-Pro Shark 60 - 384
Sewing Machines Logo
143 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
