Question about Samsung SCX-4828FN All-In-One Laser Printer
I have connected mac to it and can't get the scanner to work`
I tried to use the scan option on the machine but it can't find the local computer, what should I do ?
  • 56 Answers
Kindly install the scan driver and software to your locla computer, if you connect its as a netowrk printer kindly install the network devices cd in your local machine and add the network scanner.
Posted on Oct 27, 2009
Driver for mac os 10.7.5
The last Mac OS X version officially supported by that scanner is Mac OS 10.4 Tiger. You *MAY* be able to get it to work under Mac OS 10.5 Leopard or 10.6 Snow Leopard but otherwise there is NO way to get it to work with 10.7, 10.8 or 10.9 since these are Intel only platforms (the scanner software is PowerPC PPC.) Your only option is to run a Windows XP virtual machine inside your Mac and to it that way. I can assist you with that if you like.
Jan 06, 2014 | Minolta Dimage Scan Dual III Film Scanner
HP C309a will not scan on Mac 10.7.5
So, why would that surprise you? Mac is much different than Windows!
May 12, 2017 | HP Photosmart Premium C309A All-In-One...
HP Photosmart C5280 No computer connection
mail or call to the technicale support team of hp for that problem and get the folloups from them every day, i cant say much more becouse its realated to mac and for mac there is too less data available on hp sites.
Jun 13, 2012 | HP Photosmart C5280 Printer
I have a canon MG5220 printer and unable to scan properly the messages I receive are saying Scanner turned off, disconnected from LAN, code 2,145,50. Printing pictures and all other printing jobs work...
Regarding the Cannon scanner error 2145,50. I note you have tried to fix this, but failed. The actual problem is that the scanner will not communicate with the computer correctly if it is connected through a USB hub. A direct connection to the computer cures it.
I know, I had that problem. I am a retired elctronics design engineer.
Mar 07, 2011 | Canon Pixma MG5220 InkJet Printer
I cannot get the scanner option on my 5610 to work with my mac book pro. I've used the install cd for macs. Not sure what else to do.
This issue when we try to scan from the all-in-one, once try to scan from the all-in-one software, make sure that the software is inatlled properly because we can scan from the all-in-one only when the full feature software is installed in the computer. If we are able to scan properly from the computer then check whether digital imaging monitor is running or not in the taskbar. If it is not running reinstall the all-in-one software
If still can't get scan to work. Printer states "no scan options". If you have windows vista and it comes up with the "no scan options" don't press the button on the printer, go to "start" then "accessories" then "paint". This will open up the windows paint program. Go to "File" then click on "From scanner or printer". It will then scan the document.Thanks
Feb 01, 2011 | HP Officejet 5610 All-In-One InkJet...
I have an Agfa snapscan e20 and would like to use it from my Macbook. The scanner is an old thing. Is this possible and can you give me software to download? Thanks
First thing you should do is after you have connected the scanner to your computer, go to Finder, navigate to Applications and then double-click on the "Image Capture" icon. Press the "Scan" button on your scanner. The Image Capture application will recognize the connected scanner and will display a preview of the picture. Select any special options you want for the scanned picture and click "Scan" in the lower-right corner of the preview window. A scanned image of the picture will now be saved to the "Pictures" section of your user folder. I am advising you to try this as your MAC OS might recognize the scanner without the drivers.
If that doesn't work, try the drivers from Agfa website for SnapScan E20. Website doesn't specify for which MAC OS version they are. In addition, here's a link to th manual.
Dec 16, 2010 | Agfa SnapScan E20 Flatbed Scanner
No scan options
Did you install the full software before connecting the all-in-one to the computer? If the printer not scanning to the local computer or a networked computer? Were you trying to use the scanner buttons?
If this is a local problem (USB connection) uninstall any generic driver (these only drive the printer) and then unplug the data cable. Next download and install the software from http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=439491& (select your OS from the list). Connect data cable when prompted to do so. Try a new data cable if the problems persist (scanners require bidirectional communication and will fail when the printer works).
Try a direct connection (no USB hub or print server).
If the computer failed to respond to scanner button press, make sure that the monitoring program is running. You also need to set up the scan destinations in the HP Solution Center for the buttons to work.
If the scanner program isn't running, you can launch them manually. Computer > Local Disc (C:) > Program Files > HP > Digital Imaging > Bin (double click on each of the above drives/folders). Find either Hpiscnapp.exe or Hpqscnvw.exe and double click to launch the HP scan program.
XP, Vista and Win7 can acquire scans without the HP software but the scanner buttons will not work. All three can acquire scans with Paint (File > Import from Scanner or Camera > New Scan). Vista and Win7 also have Windows Fax and Scan (New Scan).
Since you need to set the destinations, you should use the HP software to launch scans first. This lets you get a feel for the defaults that will be best to put into the destinations.
I hope this helps.
(If the unit is networked, I do not know how the software connects.)
Sep 09, 2010 | HP Photosmart 3310 Printer
How to scan with mac
    1. Connect a compatible scanner to your computer. A list of compatible scanners is available in technical document 107203 "Mac OS X 10.2: Scanners Compatible With Image Capture "
    2. Install any necessary software drivers that came with the scanner.
    Note: Not all scanners require the installation of additional software drivers.
    3. Turn on the scanner.
    4. Press the scan button on the scanner. See the documentation that came with the scanner for specific instructions. Image Capture opens automatically and a preview scan appears.
    5. Select the area of the image you want to scan.
    Figure 1 Preview image with area to be scanned selected
    6. Click Options in the toolbar to adjust settings specific to your scanner.
    Figure 2 Options icon
    7. Adjust any settings in the drawer that appears.
    8. Click Scan.
The scanned image is saved in your Pictures folder in your home directory and opened in Preview.
Note: These are the default options. They can be changed in the Image Capture toolbar.
Jul 16, 2009 | HP Photosmart C6280 Printer
WorkCentre C2424 Scanning Mac OS X.
Well I haven't necessarily scanned often, but i do know if you open up a program such as word, Excel, PowerPoint, Photoshop, Corel, etc... You are given an option to scan. That way you can scan information, images and such to that program in which you use. C2424 wont give you any support because its a primary printer but the drivers should include drivers for the scanner and the computer to interconnect. If you have any photo like software on your mac. Try looking at the options at your top menu for an option or "import"
Many times it will give you the option to scan from a device.
To scan to computer its software based. Also on the Panel on the printer you should be given an option to scan. If printer is connected by USB it will be easier to detect scans from panel, but if your printer is connected via Ethernet it will be different.
I hope this helps. Try using a program that you can use to edit pictures or display. You should be given an option.
I hope this helps. Let me know what you do? and possibly i can mirror what you do on my own mac
Oct 16, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
SCAN STOPS MIDWAY
Are you getting an error/ red light on the scanner button when its on? when scanning from Paint ( File, then from scanners and cameras) does it freeze as well? or only when using epson scan? make sure cable is directly connected from the scanner to your computer, no hubs or anything.. keep me posted.
Have a nice day!!
Jun 12, 2008 | Epson Perfection 4990 Flatbed Scanner
Samsung SCX-4828FN All-In-One Laser Printer Logo
151 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
