Question about Sony Video Game Consoles & Games
Won't power on for more than a sec disc won't take nothing beeps goes off
  • 344 Answers
Watch the power light, if itr flashes from red to green to yellow to red, then you have a defective system. That is because you like many people received a faulty blu-raywon't power on for more than a sec - 2.gif laser . Call Sony support ASAP and they will repair or replace it for free if it is under warranty. If it is out of warranty, there may be a local tech that can repair it. Don't get scammed though. Make sure they have their own repair shop and/or a great reputation before you let them work on it.
Thank you!
Posted on Nov 05, 2009
BIOS Update was interrupted. Now laptop won't boot up.
basically your screwed , if the laptop is still under warranty I would return it without telling them u tried to flash the bios....ergo if they find out you will not be covered for warranty
the only other thing you may be able to try is inside of the laptop casing should be a small round battery usually wrapped in heatshrink or alike if you unplug that then unplug power source (main battery) and hold power button down for about 30 sec then replce both batteries and turn on it may reset bios to factory but is highly unlikely!!! you may need to contact the creator of the nios system!!!
Jan 25, 2013 | Intel Lenovo ThinkPad T410 2518F4U 141in...
My ps3 freezes on disc games but not on down loaded games.
Make sure disc are clean,,of dirt and smudge,,fingerprints,,thats usally the cause,,,and reset ps3,,,hold down power button till cutts off ,,repeat,,holding till u hear a beep,,keep hold,,,next,,2 beeps,,realease quickly,,connect usb on controller,,,do number 2 option,,should help,,update also,,,and clean and blow out ps3 of dust,,,use a disc cleaner,,good luck
Nov 12, 2012 | Video Game Consoles & Games
Won't boot up without primary screen.
2 Beeps sometimes refers to memory problems. Try re-seating.
Sep 28, 2012 | Acer Ferrari ONE 200-1799 Notebook
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Dear sir! my dell optiplex gx 150 won't start when i press the power button but power supply will be start and pc can't give any beep ?
try to remove the power cable on that product and then hold the power button for 8 secs. Reinsert back the power cable and press the power button. If it won't turn on, then the power supply is the main cause of trouble. Contact dell right away for repair...
Jun 22, 2011 | Dell OptiPlex GX280 PC Desktop
Acer aspire sa80-9b7z won't start up. Fan starts
Firstly check the monitor, if you get 8 beeps as it is starting up, this points to graphics problems. Trying another monitor. If the problem remains, swap the graphics card or use the onboard graphics card.
If this fails and, more importantly, you are not getting any beeps (single beep would indicate your CPU is ok), the problem is likely to lie with the motherboard.
To help you further, please repost with the number of beeps if any, you get as it tries to boot up
Jun 16, 2011 | Acer Computers & Internet
Ps3 will not play demos from menu and will not read disc
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 25, 2009 | Sony Playstation 3 (PS3) Console
Insignia nsr2000 on/off problem.
had the same problem... turns out the copper on my red and black speaker wire (on the speaker, not receiver end) was touching - causing my receiver to go to standby (self-preservation probably lol). i pulled the wires further apart so the copper ends weren't touching and that solved it.
Jan 20, 2009 | Insignia 200W Stereo Receiver
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Cyberhome dvr 1600 problem
The power supply needs improvement.The large capacitors need to be replaced with new ones with a 35 o 50 volts rating instead of 10 volts. Also,maybe some diodes and rectifiers in the power supply needs checking.After the improvement the addition of a small fan to keep the power supply cool is reccomended.
Good Luck!
Dec 05, 2007 | Cyberhome DVD Recorder - DVR1600
Video Game Consoles & Games Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
