I have a kenmore washing machine that is leaking water from underneath it
  • Washing Mach... Master
  • 8,220 Answers
That is probably a leaky pump. Pretty dang easy fix IF you knows the trick. HERE is an award winning short film on how to access the innards of this precious piece of machinery. After looking over the movie you might want to take a gander at the page title top loader blues.
Posted on Oct 05, 2009
    President:
  • 744 Answers
Hello, the most likely cause is the pump. Kenmore's are direct drive machines which means they do not have a belt. The pump is hooked up directly to the motor. To confirm this is the pump tip the machine back so that you can access it underneath. Make sure you wedge something underneath so it does not fall on you. Next take a look where the pump joins onto the motor shaft, this is where you will find the leak. This pump is a sealed unit so you will have to replace the whole pump. You can do this by removing the inlet and outlet pipes. Next with a screwdriver release the 2 clips holding the pump and remove the pump.....reassemble with new pump in reverse order. Good Luck!! If you have any further question's please feel free to comment. Mike
4 Suggested Answers
  • 1462 Answers
SOURCE: aeg washing machine
you may have blockage in pipe from drawer to tub but more likely the soap drawer is clogged. take it right out and clean thoroughly
Posted on Mar 21, 2007
jsrock516
  • 5911 Answers
SOURCE: washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
Posted on May 12, 2007
  • 864 Answers
SOURCE: kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
Posted on May 31, 2009
My kenmore elite topload washer is leaking underneath washing machine leaving a puddle whats causing this?
depends. first and foremost, I would fill the unit up about halfway with water, with tub being empty of any clothing. Tilt the machine back where you can look underneath it real good. see if you see any leaks with it half full of water. If you don't see any leaks, put the unit back on all fours, and put it into drain/spin. After tub empties of water, tilt unit back again and check for leaks near the drain pump and hose. If you need any further assistance, look for me on 6ya
Nov 27, 2015 | Kenmore Washing Machines
My washer is leaking from underneath the machine. What is the cause?
It could be a few things, a hosehas a hole in it, the water pump is leaking , or the cenbter seal on the transmission is leaking. Best way to check is to put some water in it, have someone help you lean it back and look underneath to locate the leak. If the water is leaking only in the agitate cycle and not as its filling then its your center seal.
Nov 03, 2010 | Kenmore 23822 Top Load Washer
Washer kenmore leaking water out bottom
Its very possible it could be one of the tubes that run to the fabric softener or detergent.
Dec 30, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Leakage of water from underneath when filling machine up
it's prabably your pump it has two metal strips that snap on from the motor to the pump un-snap them and undo your hoses and get yourself a new pump
Apr 03, 2009 | Washing Machines
Water leak
Replace the water pump. They will leak.
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 seeping water from under machine
look underneath the washer.there sould be a hose there.sometimes an unbalanced load can cause the hose to rub up against sharp metal when the machine vibrates.mine had a zip tie that held the hose to close to the edge of the machine which had some sharp metal and it put a small hole in the hose.hope this helps.
Dec 19, 2008 | Kenmore 22422 Top Load Washer
Washing machine is leaking
you can remove the front panel(3 screws across the very bottom lip) from there you wil gain acess to view the underneath, as the macine is operating to pin point where the leak is coming from
Nov 23, 2008 | Kenmore Washing Machines
Water is leaking from the underneath, at the front of the machine
The drain pump is located at the front, underneath. The drain pump has probably failed and will need to be replaced.
Jun 04, 2008 | Kenmore 22422 Top Load Washer
Washer leaking water from underneath
May 11, 2007 | Kenmore 44042 Front Load Washer
Washing Machines Logo
89 people viewed this question
Top Washing Machines Experts
