Question about HP Photosmart M425 Digital Camera
The power button on my M425 is stuck and now wont
Dropped my camera and now the lens won't retract back in. When I press on the screen says lens error M425-12 (7f80). Can this be fixed and should I take it to a camera repair shop? Thanks
It could be one of two things, you bend the lens when dropped or the pins in the lens has become loose and are stuck.
You can try:
Taking the battery out for about 5 minutes and putting it back in to reset the camera. Also you can try hold the power button down and the ok or select button to to reset it. Also can hold the power and the menu button to try and force the lens out to dislodge the pins. If not,
The funny the is that I would have you drop it again on a carpet but on the opposite side to see if you can dislodge the pins from being stuck, try and have it land flat on its back from a decent height.
If the lens in bent you will have to bring it to a repair shop to have it fixed but it usually costs as much as a new camera.
Sep 06, 2011 | HP Photosmart M425 Digital Camera
Camera wont charge. Was for a while but now displaying batteries cannot be charged.
sounds you may have to replace the batteries, but try taking out the battery from the camera and press the power button for about 10 seconds. Keep it turned off without the battery for 5 min then reconnect the charged batteries
Dec 08, 2010 | HP Photosmart M425 Digital Camera
The on/off switch is stuck in the housing and is not working.
I just had this happen to my HP Photosmart M425 camera this weekend while on a campout -- very frustrating! Anyone have any suggestions on what to do?
Aug 15, 2010 | HP Photosmart M425 Digital Camera
M425
Download a free copy of Quicktime from Apple.
May 22, 2010 | HP Photosmart M425 Digital Camera
M425-12 lens error
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 29, 2009 | HP Photosmart M425 Digital Camera
Lens Error M425-12 (7F80) on HP M425
Try taking the SD card out and restart the camera. Also, make sure the batteries are fully charged. There is also a firmware upgrade indicating a problem with the lens getting stuck.
May 13, 2008 | HP Photosmart M425 Digital Camera (5MP,...
I dropped my camara and lens is stuck on the outside
Dear pat123456,
If you dropped your camera and now the lens won't retract back into the camera, and it won't power on it sounds like you have internal damage. You need to have it looked at by an authorized service technician.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Apr 07, 2008 | HP Photosmart M425 Digital Camera
Mar 01, 2008 | HP Photosmart M425 Digital Camera
HP Photosmart M425 Digital Camera Logo
18 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
