Question about Home
Why would a toilet emit a big bubble of air from the bowl when flushed ?
  • 38 Answers
You mite have a cloged air vent. or if you have a septic tank it needs pumped. and a clog mite be at inlet of pipe. dig open inlet of tank pull lid, if you cant see the pipe where it enters tank, take a broom handle and stick in the opening. to see if you knock out clog. or call a septic service company,not a plumber. hope this helps. duane.
Posted on Oct 05, 2009
We put in the toilet on sat. Since then every time you flush there is a big air bubble in the bowl, the other toilet we took out did not do this, poured a 5 lb bucket of water down it and that did
The new toilet has more flushing volume than the old one. The system should handle this. The problem could be the vents on the roof are plugged or something in the line is obstructing the flow. You will need to contact a plumber
Jun 08, 2015 | American Standard Home
How do I fix a toilet that bubbles (small air bubbles from below) and flushes slow, and not completely very often?
Remove the toilet & have a plumbing company power snake
as much of the entire homes waste drain as possible
Maybe clogged inside the home on most runs & also out to
the street,have them do as much as they can, out to the street
Remove all toilets, so they can do good job & you can check &
clean them from under it
Have them run a camera down ALL drains & to the street
Jul 19, 2014 | Briggs Abingdon Ada Toilet Express
Why does my toilet belch water after flushing
Always the first thing with bad toilets. Take a big plunger and pump hard covering the entire bottom of the bowl. Blockages cause air breaks which cause the belching
Mar 19, 2014 | Computers & Internet
Vent on top is blowing bubbles and toilet pan is filling up with effluent
If you have a Saniplus model then the vent connection is on the top right side of the pump casing if you are facing the toilet with pump sitting behind. The vent pipe needs to be minimum 1 1/2" and must be vented to the open air so air can flow in and out at all times. To the left side of the vent connection is the discharge pipe which should be a 3/4" or 1" discharge pipe. You can try disconnecting the vent pipe and run it with the vent pipe open, also you can disconnect the discharge pipe and put a bucket at the end of the discharge elbow and flush the toilet into the bucket, it will free flow into the bucket and there are no restrictions. That way you can tell if the problem is the pump or the installation set up.
Dec 20, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Cant find any thing in bowl ,replaced air tank drain is clear and still does not flush replaced bowl and flushes this is the 4th toilet with same problem cant find anything in any bowl we changed
Try turning off the water to the toilet, then old the handle down until you hear that all the
water has drained out of the tank. Then turn the water back on. Then take a cup of water
and put water on to the plunger on top of the tank. Check for air bubbles, if there are bubbles
then that is the problem. The tank MUST HAVE a certain amount of air in the top of the tank,
or it will not work at all. You might have to remove the plunger assembly and put some vaseline on the big O ring seals. To remove the plunger, take the screws off the stainless bent rod that goes
over the plunger, then remove the rod, or just move it out of the way. The plunger can be removed
by sticking the jaws of a pair of chanel lock "pump pliers", then grab the handles of the channel locks and turn the plunger assembly out.
Sometimes all you need to do is drain the tank down, and the toilet might work for a long time.
It's such an easy fix, a person really doesn't mind draining the tank.
Hope this helps
LeRoy Wolff , North Dakota master plumber # 8401
Nov 01, 2010 | Sloan M-101526-F Flushmate?® Complete...
Leaks from tank into bowl and when flush as it
Change the flapper with a generic one that will fit that toilet... the OEM flapper is **** and it does not allow for a good flush either...
heatman101
Aug 03, 2010 | Eljer Toilet Onepiece Canterbury ...
Toilet when flushed makes a large bubble surface from the hole. Sometimes the toilet will not flush away a bit of tissue.... very frustrating..
Have you checked it out for any blockage in the toilet or drain line.
You could try a 6ft auger to try to remove blockage from toilet.
If it is a drain issue it is either blocked somewhere or the vent is not working correctly causing it to get air bubbles.
Check you tank for proper water fill level up to marked line. Also make sure fill line from fill valve is connected to overflow pipe to fill bowl up correctly.
Not enough water in tank will affect the flush.
Jun 11, 2010 | Home
I have a weak flushing toilet of this model. Water does not fill tank fast enough to create the weight of water needed to start a flush. I've looked in the tank while lifting the flap and see that as the...
From your description it sounds like the flushing orifices are plugged. The orifices are the little holes around the bowl or the big hole in the throat of some. A simple way to check if this is the problem is to get a bucket with aprox 2.5 gallons of water in it and pour it directly into the bowl and see if it goes right down. If it does, the orifices are plugged. Two of the most common causes of clogged orifices are hard water deposits and bowl cleaner cakes that drop in the tank. In the case of hard water deposits, we usualy acid clean the stool with muratic acid introduced through the flush valve. Be VERY careful when doing this, as the fumes are VERY dangerous and it can discolor colored porcilyn. May want to hire a plumber to do this. As for the cleaning cakes. You can pour some tap hot water through flush valve and dig into hole with wire hanger to remove as much as possible. I hope this helps.
May 19, 2010 | Pegasus Technologies Pegasus Elongated...
BRand new elongated Cimarron shoots water out of bowl durng flush
Is the fill line in the tank loose? Does it just shoot water into the tank itself? I had this issue until I realized the while fill tube is supposed to be pushed into the black cylinder/small plastic tube in the middle of the stopper assembly. After i pushed the line into the tube, the bowl would always only fill a little bit. Now it fills almost a 3rd of the way up the bowl and doesn't bubble during flushes.
May 09, 2010 | Kohler Cimarron Comfort Height elongated...
Home Logo
250 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
