Question about Electronics - Others
The computer will not let me write data to my flash drive saying it is copy protected but i do not have it in copy protect mode.
    Sniper:
  • 66 Answers
If you are using a cardreader, try different.
Posted on Oct 05, 2009
  • Anuj Bhatt
    Anuj Bhatt Oct 05, 2009
How to remove write protection
To remove write protection:
Open Start Menu >> Run, type regedit and press Enter. This will open the registry editor.
Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Double click the key WriteProtect in the right pane and set the value to 0
In the Data Value Box, press OK
Exit Registry, restart your computer and then re-connect your USB pen drive to your computer.
Jan 04, 2014 | Electronics - Others
How to do data write protection from removable disk
This is usualy handled by 3rd party software. The problem is you are at mercy of them. Any problems and you may find yourself locked out of your own data.
Dec 24, 2012 | Electronics - Others
I have A-data my flash 8GB usb which write is protected please tell how i can Fix it ,,when i try to format the usb it say windows was unable to complete to format
The problem isn't with write protection. The file system has become corrupt and unreadable, or at least a section of it. If you can't reformat it then it's likely dying or dead. At least you should be able to recover some of your data however...
Go here and get a FREE copy of USB Flash Drive Data Recovery Software:
http://www.easeus.com/resource/drive/usb-flash-drive.htm
May 15, 2012 | Electronics - Others
I CAN NOT COPY OR DELETE THE FILES OF MY USB
Your USB flash drive is either infected with a Virus or your Drive is Write Protected.
Scan your flash drive for Mal-ware and Viruses using an Up to date scanner.
Be sure to check that the drive is not on Write Protect mode.
However under Write Protect mode you should be able to copy file from your USB flash drive.
Also try the drive in another computer just to be sure it's not the drive that faulty.
damnor01 out!
Apr 06, 2011 | Computers & Internet
Device media is write protected
To disable writing access to USB drives and make all USB drives has only read-only access, follow these steps:
  1. Run Registry Editor (regedit).
  2. Navigate to the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
  3. Create a New Key named as StorageDevicePolicies.
  4. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
  5. Double click on WriteProtect, and set its value data to 1. write-protect-usb.jpg
Once set, all users on the computer is now blocked and prevented from copying, transferring or writing any files, documents and data to the USB disk drives, without the need to restart or reboot computer. Any attempt to download or copy files to USB drive will return the following error message:
The disk is write protected.
The media is write-protected.
Remove the write protection or use another disk.
usb-removable-disk-write-protected.jpg To revert and remove the blocked write access to USB drivers, just delete the StorageDevicePolicies registry key, or delete the WriteProtect registry entry, or change the value data for WriteProtect to 0.
For user who doesn't want to manually editing the registry, simply download the following registry registration files to enable or disable the write protection (block writing attempt) to USB removable drive. Double click the .reg file unpacked from the .zip archive to merge the registry key entries.
Download DisableWriteToUSB.reg
Download EnableWriteToUSB.reg
The trick works in Windows XP SP2 and SP3, Windows Vista, Windows Server 2003 and 2008.
Feb 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
When ever i try to copy a file on to my pendrive ,a file pops up saying that it is a write protected drive .how am i to remove this write protection?
try this one, hope it will work on your memory stick coz i tried this and i was able to format my write protected memory stick smile.gif
use a computer with XP OS.
right click 'my computer'
select 'manage'
then select 'disk management' to format ur memory stick. but sad to say, all data will be lost, am pretty sure you know it
Jun 10, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Write protected error
IN THAT FLASH DRIVE JUST CHECK FOR ANY SYMBOL DAT A LOCK MARK AND MAKE SURE THAT IT UNLOCKD BEFORE U PUT IT INTO YOUR COMPUTER
Apr 16, 2010 | Electronics - Others
Write protected problem
I checked it the website says its a virus attack. Pls download the software from this link. http://www.transcendusa.com/Support/DLCenter
Jun 18, 2009 | Electronics - Others
My usb pen drive has became write protected while i was copying some data
You can try to go to my computer ( with the pen in usb slot ) right click usb pen and then format the pen. This should clear it. It sounds like one of the files you transferred is write protected.
May 04, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Flash drive write protected can't move files
a small lock is presents in side of your flash drive ,u just change the current position of this lock
done,now try to copy or your work
regards prasanna
Mar 06, 2008 | Electronics - Others
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
