Question about Maytag Ensignia 3.3 cu. ft. Top Load Washer
The water continues to run into my Maytag Ensignia after the cycle is complete
  • 4,059 Answers
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Posted on Oct 05, 2009
My Maytag Ensignia washer ihas started dripping water into the tub area. It had completed its cycle, but contuies to drip. Right know no evidence that its leaking outside the tub area.
Part 2...
Watch the video... halfway down the page.
https://www.bing.com/search?q=maytag+ensignia+water+valve+replacement&form=EDGEAR&qs=PF&cvid=cc208ffd8bb94ec8937beadc9b940d64&pq=maytag%20ensignia%20water%20valve%20replacement&PC=DCTE
Parts houses... Most all have assistance lines, chat, videos and difficulty assessments (requires model number).
Sears has some pretty good on-line documents... but the get pretty EXPENSIVE on their parts
You are looking at the SAME PARTS EVERYWHERE...
Suppliers:
appliancepartspros.com
repairclinic.com
easyapplianceparts.com
partssellect.com (there are more)... and last...
Sears
Water Filters Lawn Garden Appliance Parts
Search Over 2 1 Million Appliance Parts
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Find Your Appliance Parts
http://partssellect.com/
Jun 17, 2016 | Maytag Washing Machines
Maytag ensignia top load washer will not fill with water at start of the cycle?
The drain hose has to be at least 30 inches above the floor or gravity will drain the machine. Also: If the water hose is jammed into the drain a siphoning affect will occur in some instances.
Aug 04, 2012 | Maytag Ensignia MAV2757AWW Top Load Washer
I have a Maytag Ensignia and the water will run but the tub will not fill.
You may have to just raise the drain hose up higher. It sounds as if the water is going out the drain hose as it tries to fill.Drain hose should be up as high as the top of the washer.Hope this helps.
May 28, 2011 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag ensignia makes a great deal of noise during rinse cycle
"If you dont have a noisy spin cycle and the noise you hear is only on the rince cycle, dont be worried, as this is totally normal. Water sprays onto the drum while the spin cycle is in progress and rewets the clothes to allow any existing soap to be desolved. This noise is in effect the water hitting the drum during the rince part of the cycle.
Sep 03, 2010 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag washer stopped working at the rinse cycle
do you have the machine set for cold water rinse? if so, the solenoid that allows the cold water to come into the machine may be malfunctioning. try to see if it will fill in the rinse cycle with hot water? if so, you need to change the water inlet valve.
Oct 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
The washer doesn't always fill up when we turn it on
Hi, Dose the water fill the first time you start it but, then will not fill in the rinse cycle? Does the water continually try to fill but never gets to the top?
I want to help.
Thanks
Vic
May 12, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Water fills the tub then nothing happens.
it does not aggitate? Thats the cycle that allows the water to wash the clothes. It may be broken, I have had that happen a couple times. I would take the aggitator off and see if the teeth in the groves are worn out, It happen's when used alot. Commen problem and easy to replace.
Apr 05, 2009 | Maytag Ensignia MAV2757AWW Top Load Washer
Clothes are still wet after spin cycle
possibly not a machine fault. if drain is connected to sink plumbing, remove the drain hose and see if it pumps out into a bucket.
Mar 25, 2007 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag Ensignia 3.3 cu. ft. Top Load Washer Logo
249 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
