Question about Estate EGD4300TQ Gas Dryer
Dryer will not dry heat but low air flow
Dryer will not dry heats but low air flow
    President:
  • 1,922 Answers
Check the blower fan on motor shaft,then all vent piping then the vent hose to the outside for a restriction or lint plug
Posted on Oct 09, 2009
Whirlpool Tumble dryer low heat, taking three cycles to dry one load
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
Jun 21, 2012 | Whirlpool Dryers
Clothes dryer doesn't heat
Nov 26, 2011 | KitchenAid Dryers
No heat when drying
Well it's for us to answer if you provide the model number anyway if it's a gas dryer and if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Jan 26, 2011 | Kenmore Dryers
My gas dryer runs forever without making any heat. The timer doesnt advance at all. The air flows great just no heat. On a VERY rare ocassion there is a little heat but hardly ever.
Well if your dryer tumbles, but there is no heat then you may please check out the following -
Good Luck!!
Jan 26, 2011 | Dryers
Our Bosch Ventless AXXIS Dryer system is overheating causing the sensor to sound. It is not drying properly either. Can you troubleshoot??
Overheating is most probably caused by low air flow past the heating element. High air flow would not allow the air to overheat. Check to be sure the fan is rotatingn freely and then check the heating element/wires for dirt or other obstructions. We were having "burning" problems that were revealed to be an errant latex glove that excaped from my wife's pants pocket during an earlier drying cycle. When it hit the elements, it began to cause a scortching smell and partially melted. In this instance, the air flow about the element was restricted and the reamining air overheated and the sensor sounded. When the sensor sounds, heating ceases and you will get non-uniform drying. I picked off the pieces of the glove from the wires and except for an unrelated drive belt breaking, we have not had problems.
Jan 22, 2011 | Bosch Axxis WTA 3510 Electric Dryer
Dryer is not heating up to dry the clothes
Good Luck!!
Sep 10, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The dryer doesnt get hot enough to dry clothes
Pull the dryer out and remove the lint hose . Turn on the dryer and feel if there is good air flow and if you feel heat . If there is good air flow and heat , dry a load of clothes , to see if they dry normally .
If there is not good air flow , then the blower wheel is probably stripped and needs to be replaced . If there is good air flow and heat , then the problem is in the vent ducting , between the dryer and to where it vents to the outside . Dryer could be pushed back too far , causing the hose to " kink " , restricting the air flow to the outside .
Remember , a dryer either heats or doesn't heat . If no heat , then a dryer problem exists . If heat , but dryer does not dry , then a vent problem is the cause ( except for maytag , which the blower wheel sometimes strips out ) .
Nov 08, 2009 | Maytag PYE2300AY Electric Dryer
Gas dryer quit heating
Good Luck!!
Nov 01, 2009 | Whirlpool GGQ8831L Gas Dryer
NO HEAT WHEN CLOTHES ARE ADDED
Check to see if vent hose is not restricted. If it goes up inside wall, it could have lint clogging it. Most dryers regulate heat with air flow. Wet clothes can restrict flow even more if vent is clogged or pinched. Air flow is crucial to heat cycle. If the vent is resrticted, heat will rise quickly, but not cool down fast enough to allow heat thermostat to cool down and turn on heating element again. It may seem hot inside dryer but if no air flow it will increase dry time or not dry them at all before timer shuts off. If vent goes up inside wall, buy a small chimney brush and try cleaning out vent from attic if you can.
Jul 24, 2009 | Maytag MED5800TW Electric Dryer
Warm heat..clothes not drying
john there is only one heating element.ither it works or it dosent.when acustomer complains of low heat or long dry times 99out of100 its the venting or the dryer is blocked with lint.remove the dryer from the venting and try a load.if better clean house venting.you .........if not better you should have a great air flow leaving the dryer so if not drying well with venting off.take dryer apart a clean all araes that air is moving,where lint can block that flow.god bless .tom
Jan 01, 2009 | Roper REX3614KW Electric Dryer
Estate EGD4300TQ Gas Dryer Logo
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
