Question about Panasonic PT-51G44 51" Rear Projection Television
I can see each seperate colour how can i align them together
Help
Posted on Oct 05, 2009
I changed the colour cartridge (the black might be a bit bad but it still has colour in it), even bought a second one since I thought the first one might be faulty, but it still says "alaign...
Take out the power cable from the back of the printer.
Press and hold the ok and Cancel button together , while plugging in the power cable.
It will ask you to alighn the cartridges- Do it and that will fix your issue.
Jul 05, 2011 | Office Equipment & Supplies
Picture is OK, but colors are off and there is a blue star background that shows on dark colors.
Hello, With most rear projections there is usually an alignment to do with the set up with your TV. This is so the red, blue and green projectors align together to give the correct colouring. This sounds to me what may be causing the outlining of the blue. This can also make it seem off colour. Look in the set up menu of the tv and see if you can find this alignment feature. Usually a cross will appear and you move a blue, red, and green cross with the arrows on your remote to align over the original white one. If this does not work, it may also mean that one of your projectors, that is the red, blue or green one may be failing causing the off colouring. Hopefully this alignment may fix it for you.
Oct 26, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Selection dial has come loose.
Found I could unthread the knob (counterclockwise), then removed the selection plate, and its adapter. Noticed that it was originally welded to the plate, via 3 palstic studs. I was able to determine that the two plates would ONLY align in one postion, and then was able to ReGlue them together, courtesy of No More Nails. All is well in Washerville again.
May 16, 2009 | Whirlpool Inglis IP4400 Washer
Samsung rear projection tv
It probably is see if you can align the convergence manually or auto if available, you can order just the convergence ic's or the convergence amp board, whichever you prefer. check pricing and availability. also check Blue crt for faded picture, usually dirty crt fluid, makes picture dark and discoloured. If it is you may need to replace the blue crt also. this gets a little expensive, again check pricing hope this gets you started RFT
Jan 06, 2008 | Samsung HCM4215W 42" Rear Projection...
Three colours don't converge
Shrink, the convergence circuit needs to be repaired, Until someone gets in there and takes a few measurements it`s hard to say what the cost will be, may just need to be re-soldered, good luck, BMW Rider
Dec 18, 2007 | RCA P46810LV 46" Rear Projection...
Ghost image when printing in colour.
There must be a calibration option in the printer's menus, dig around, might be in a maintenance or service menu. Could also be found in a program on your computer sometimes.
Dec 03, 2007 | Samsung CLX 3160fn All-In-One Printer
Sounds like your convergence power supply board is bad if it is a ctc or ptk 195 chassis. Located above the main board on the left and dynamic convergence board on right. Has two plugs and held down with quarter inch screws. Most problems on the board is the IC on the metal heat sink which is stk 730-010. whatever you can see the part number on it. Unsolder with solder wick and solder in new. If this doesn't fix a new complete board will do.
Sep 09, 2007 | RCA P46922 TV
Panasonic PT-51G44 51" Rear Projection Television Logo
60 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
