Question about Samsung L200 Digital Camera
When i try to charge my samsung L730, it wont charge
Sometimes an orange light flashes when it does charge
SOURCE: Samsung L730 stuck
Hi,i turned it on,then pulled the battery out(while still on)then turned back on and it came right...
Posted on Aug 04, 2008
SOURCE: I have a Samsung P800
I have the same problem
Posted on Sep 22, 2008
zohail
  • 1223 Answers
SOURCE: light on my samsung digtal camera charger is flashing orange and
pls checck the batt it is not taking the charge they are weaken and old pls ccheck it
pls rate me fixya for this if u like
Posted on Mar 09, 2009
SOURCE: samsung nv3 camera not charging
take out the batter and clean the copper terminals with a sharp knife, plug into the charger if still not working leave for 30 seconds and re-try, it took me four attempts.
Posted on Jul 02, 2009
SOURCE: Samsung L730 wont extend lens and dosent turn on right
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
Posted on Oct 10, 2009
Hello Sir / Madam, I've got a Samsung Camera L730, 7.2 mega pixel, the problem is while charging, 1st it showed red LED light ( as usual ), then immediately an orange light starts blinking (as per...
Do you have change a Samsung L730 battery and to see if it can be charged? If you charge the battery in camera. It seems something wrong with the build-in charger core. If the camera all are OK beside charge battery, you can charge your Samsung L730 battery with a battery charger, and if your Li-ion battery is over discharged for a long time, it's bad for it. As your camera has been used for 2 years and it maybe not in warranty. To change build-in charger core should be expensive.
Apr 29, 2011 | Cameras
I bought an untested Samsung L730 digital camera without a battery, I have bought a USB charger/data cable but the orange flashing light on the charger stays on. I am using Windows XP. Is it likely that...
You CANNOT charge a camera through a USB port there just is not enough power! you need to get an original wall charger and power up from that. Even the USB cable/wall charger will NEVER charge it up sufficiently.
The USB cable is for data transfer only.
Aug 07, 2010 | Samsung Digimax L730 Digital Camera
I have lost my usb charger cable for my samsung l730 camera does anyone no were i can get one..
contact to your retailer from where u bought your device.............try in any electronic shops...........
Jul 10, 2009 | Samsung Digimax L730 Digital Camera
The lens on my L730 digital camera does not open.
Hi, I had exact the same problem with mine Samsung L730. I opened it and took the 2 flatcables from the circuit board (to the lens-unit) out of there connectors. After I put them back in again, the camera worked. I geuss it was a bad electric connection of the lens-unit. Maybe this will solve your problem. If the camera is older than 1 year and has no warrenty, just try this. Good luck.
May 23, 2009 | Samsung Digimax L730 Digital Camera
Lens is out as though camera is on but screen wont come on
Try taking out the battery, give the connections a blow to free dust then try the on off switch.
Jan 13, 2009 | Samsung Digimax L730 Digital Camera
My samsung digital L730 wont turn on
Just fixed mine, if the lens is out that's the problem we had, it was jammed and not allowing it to switch on, we gently pushed it back in, then switched on, the lens came out a bit then jammed, pushed it in again & kept doing it until it cleared the blockage.
Works fine now!
Hope it works for yo
Jan 03, 2009 | Samsung Digimax L730 Digital Camera
L830 wont charge
it is possibly the battery itself. i have a two batteries for this camera one of them has this problem orange flashing light and doesn't charge and the other works fine. You might need to get a new battery. Good luck
Oct 11, 2008 | Samsung Digimax L830 Digital Camera
Samsung L730 camera not charging
try taking it to your local camera or electronics store and see if they can clean the contacts on your charging port and your battery slot and/or run a coninuity test on your charging port.
Jun 14, 2008 | Kodak EasyShare M853 Digital Camera
Camera just won't turn on!! :)
Katie take it back to where you got it places like best but some time will just give you another camera no questions asked.
Apr 19, 2008 | Samsung Digimax L730 Digital Camera
Samsung L200 Digital Camera Logo
75 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
