Question about Sony Cyber-shot DSC-S730 Digital Camera
My camera says pictures are locked - Sony Cyber-shot DSC-S730 Digital Camera
  • Dave Lundmark
    Dave Lundmark May 11, 2010
    Make sure that your memory card is not in the lock position or protect position.
  • Dave Lundmark
    Make sure the memory card is switched to write position and not the lock position. More information would help.
Card Locked!
on the side it ses lock you have to un lock it theres like a butten
Jul 16, 2010 | Samsung S860 Digital Camera
The camera says in the screen that the card is locked The memory card is locked and I cant figure out how to un lock it is in the set up or what do I do ? my camera is EXILIM 8.1 Mega Pixels
I've never fiddled with this brand of camera, but there will be the option to lock the pictures in the menu. In your manual, look for "memory", "locking your pictures", things like that. Also, some memory cards have a plastic tab that slides to lock the card- make sure that isn't in the lock position, if your card has one. Good luck, and hope this helps.
Jun 11, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
How to unlock a picture
Go to the playback menu and select it (you may have to adjust the circular option know to get to the playback menu). Once there, scroll to the picture(s) that are locked by using the sideways selection arrow buttons. Then select the up or down arrows, which will lock or unlock your picture. You can also erase any locked pictures, in case you want to, by formatting the xD card. Hope this helps.
Mar 25, 2010 | Olympus FE-210 Digital Camera
The camera file is locked
not sure what you are asking? but most cameras have a little key picture on settings or pback of camera, if you want to protect photos from accidental erasure you push that button and it locks the file, when you view photo on camera it will show a little key in upper right corner of the picture. just a shot
Dec 28, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
My camera says card locked
Your memory card has a lock switch, move the switch to unlock.
Jul 02, 2009 | HP Photosmart M447 Digital Camera
When i try to take pictures my camera says card locked.
It's the memory card or SD card you have in the camera. (it sounds like)
Try taking the SD card out and if you look at it closely there is a little switch/ thing you can slide. Slide it to the other side, put it back in your camera and try again. Hope that helps
Jun 02, 2009 | Samsung S860 Digital Cameras. 8-megapixel...
My camera wont take pictures says card locked
There is a lock on the SD card
Check this is good.
Regards
Richard.
Feb 02, 2009 | Vivitar ViviCam 3935 Digital Camera
Sd card not working
Check to make sure you didn't accidentally move the locking switch on the SD card to the locked position. There will be a switch on the side of the card. One side of the switch says locked, (or has picture of a locked lock) and the other side says unlocked, or has a picture of an unlocked lock. Try it out.
Dec 31, 2008 | Nikon Coolpix L11 Digital Camera
Unable to delete photo
check to see if theres a lock on the pictures or a lock on the memory card.
by lock i mean a stub that prevent writing to it.
can you save pictures? if so then you might have a lock on the picture that cant be erased.
Jun 03, 2008 | Kodak Easyshare M753 Digital Camera
Preview Picture - Locked Up
Eventually, the camera's battery will die. I suggest removing the battery and then wait for 30 seconds and put it back in. This should solve the problem.
Feb 29, 2008 | Kodak EasyShare DX6490 Digital Camera
Sony Cyber-shot DSC-S730 Digital Camera Logo
18 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
