Question about Maytag Washing Machines
How do you take off the aggitator
How do you take of the housing of the Maytag top load washing machine
The agitator is off and so is the drum. The spindle is off and now I can't take off the housing. How do I get the housing off?
    Problem Solver:
  • 18 Answers
Go to RepairClinic.com. They have several posts that describe in detail how to perform major disassembly.
Posted on Oct 05, 2009
Agitator is not moving
You have stripped out the Aggitator or the Bolt came loose. Pop the Top on the Aggitator. There is also a chance that there is SOAP build up inside that is causing a problem depending on the machine...
Apr 12, 2013 | Maytag Centennial MTW5800TW Top Load...
Trying to remove aggitator from maytag atlantis I removed fabric softener part need to get the shaft of aggitator off trying to clean my softener keeps leaking out after wash is done
i believe all you have to do is put your fingers underneath the bottom of the agitator and pull up and the whole agitator pops up to remove it out of the tub.
Apr 08, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Washer was filling but not aggitating,
remove the dispenser in the top of agit . under it is a bolt. remove bolt. it holds it down . if it won't pull by hand then we use a ( agi tamer. this is a split inner tube type/very flat with a split in it . slide under agit and add water and up it comes . 5 min. .. i don't think something is under the agit I belive the trans is failing . but you need to look . . agit needs to be removed to repl trans anyway ..mm
Dec 12, 2009 | Maytag PAV2300 Top Load Washer
Maytag Legacy Series Top Load Washer model SAV515DAWW splashing
the agitator dogs are likely broken.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Maytag Legacy Series Top Load Washer
Maytag washer mavt546eww..will not get up to full speed
Hi, this is transmission failure. the clutch has been damaged. I recommend replacing the transmission and agitator assembly as well.
Jun 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Drum doesn't lock when it aggitates
Your brake has malfunctioned. You will need a repairman to fix this. Sorry.
Jun 02, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Aggitator is stripping out
It's easy, your agitator dogs are bad. They are little teeth that sit inside the agitator. If you remove the top of the agitator you will see 4 small gizmos that sit inside there. They have teeth that catch the teeth on the agitator and stop it when it agitates. The teeth on the agitator dogs are just worn out. They cost around 7 dollars from your local appliance repair shop and are easy to replace. Just pull out the housing for the dogs and replace them. You buy them in a set of four. Let me know if you have any other questions and let me know if this was helpful. Good luck and have a great weekend.
Jan 24, 2009 | Kenmore 24032\24036 Top Load Washer
Drum doesn't pin Model LAT8234AAE
It possibly the switch timer is defective.
Feb 24, 2008 | Maytag PAV2300 Top Load Washer
Maytag Top Loader Washing Machine Legacy Series
The drum should be on center. It sound like a damper pads issue. The damper pads are located beneath main support housing on base's machine. Check that they are on place and not broken. Good luck !
Jan 22, 2007 | Maytag Legacy Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
