The picture has shifted to the right and has an area of black on the left where the picture should be. There is a line of distortion where the top two-thirds meets the bottom third of the picture, which is normal. Otherwise the TV works fine. Is there a bad component or board that I can replace. The TV is a Sony Trinitron KV-35V35. See less
  • 448 Answers
Use the screen adjustment button on the TV to adjust the picture on the TV screen.
You may also pressing the Reset button on the remote when the TV is in Video settings mode to reset the video settings to the factory default.
If the issue persists then the problem may be related to the board.
Posted on Oct 05, 2009
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Distorted picture
You have a convergence problem.On this model you can change the convergence amp board which has the convergence IC's on it making it an easy repair.
Oct 06, 2007 | Samsung HC-P4752W 47" Rear Projection...
Black vertical line on the right side of screen. Color distortion on the right of that.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Screen shots to defective panels to LCD TVs are given. You can see and compare it to that of your TVs'
Mar 13, 2014 | Mitsubishi LT-40148 40 in. LCD TV
How doI take pictures with my Mac laptop?
To take a picture of your current screen:
Press the Command-Shift-3 combination.
To take a picture of a certain area on your screen:
Press the Command-Shift-4 combination.
Then drag your cursor from top-left to bottom-right around the area you would like a snapshot of.
Aug 31, 2013 | Apple MacBook Pro Notebook
Picture distortion
I have a vs 8087 good working condition
$700 you pick up Chicago area
scott_kehoe@sbcglobal.net
Jan 11, 2009 | Mitsubishi VS-8087 80" Rear Projection...
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Coulor distortion at the top left of the screen
Hello jordan ashe,
This is an indication that the green CRT is having a convergence problem. This might be caused by the convergence amplifier or by the CRT. Does the rest of the picture look OK? and in addition can you supply a picture of your TV so as I can see what you are seeing and develop a proper diagnosis?
Thank you,
Shuttle83
Sep 28, 2008 | Hitachi 53UDX10B 53" Rear Projection...
32Inch Flat Screen SDTV - with picture distortion
If you have a TV shop at all any more in your area, any tech working on them will know where to look. This is a pretty common problem although you are getting it too early.
Since it will require a certain type of instrument (capacitance meter) to verify the problem part, I don't want to go into detail concerning a 'do-it-yourself' repair since it may be a little difficult to order these in single quantities and a decent shop should have the right value on hand.
It shouldn't cost too much.
Jun 28, 2008 | Philips 30PW633R 32" TV
Green semi-circle of lines on Samsung 55" HDTV (projection)
I believe i have the same problem myself. When my TV is on any of the Component Inputs without my DVD player turned on i usually get the normal green screen. But now that is a dip in the green at the top of the screen from the top left to almost the top right and black pushing down on the dip. Almost like a green curtain was sagging at the top and you can see the black behind it. It does this on every input and distorts every picture you see. The distorted picture has all the green slightly off from where the rest of the picture is and where the dip at the top of the screen is there is somtimes purple instead of black.
I know the basics of how the picture gets onto the screen and its my guess that the Green "gun" for lack of a better term and somhow come loose, or been missaligned to a great extent. I would love to find an answer to this problem, and anyones best guess as to how much a repair man will charge, just so i know the ballpark.
Jan 31, 2008 | Samsung HCN653W 65" Rear Projection...
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
