Question about Acer Aspire 3680 Laptop
Acer frezzing up on turn on stuck on acer page press f2 nothing happens
    Genius:
  • Acer Master
  • 1,144 Answers
Run a hard drive diagnostic tool seems your drive is froze or corrupt.try opening up safe mode see if itll let you in/
Posted on Oct 05, 2009
It is stuck on the " acer empowering people" screen it gives me options at the bottom to press F2 for setup and F12 to change boot order but when i press either of these nothing happens ive tried...
try restarting and push esc a few times should go to boot option screen ,,set it to boot from hdd,,or jus put ur cd that came with or windows disk and repair,,,,,check acer website also
Nov 03, 2010 | Computers & Internet
Turns on but wont go pass the startup screen
Try to put an operating system boot disk in your drive then turn on laptop.
When the screen says press any key to boot from cd/dvd press a key.If it is vista when you do boot from cd it will give the option in the lower right corner to repair-click on this-select repair startup option.if that fails try a re-install of your op sys.
May 31, 2009 | Acer Aspire 5610 laptop vista combo with...
ACER Aspire 5570z won't start
Check your memory card, reseat or clean it with soft eraser its edge connector. But first shut it down fully, battery disconnected and no other power source connected to it before doing so.
If this does not come on test with a spare ram. Before checking on another fault.
May 08, 2009 | Acer Aspire 5500 5570-2609 Laptop
My acer laptop won't boot pass the acer logo sign.
Try this - go to BIOS (while you see ACER logo press F2 (or other key, it should be shown below the logo)) and select setting called something like "Restore Defaults" or "Load System Defaults" or "Optimal Settings". When it asks "Are you sure", pres Y then Enter. Tell me what happens.
Mar 15, 2009 | Acer Aspire One PC Notebook
My laptop acer aspire 3100 crashed. it was fine before i turned the laptop off, but when I tried to turn it on again it got stuck starting windows up, I have Vista. I waited for some time but after 30 min....
Hello rijotomas,
First you can try to pull the battery out and unplug the power adapter for a minute. Then plug the laptop back in without the battery. Then try to turn it back on.
Feb 23, 2009 | Acer Aspire 3100 Notebook
Freeze
Sounds like the OS is currupt and you will need to boot with your restore cd which you received with your system, and set everything to factory default.
Good Luck.
Jan 31, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer aspire 3690-2900
tried to remove the harddrive and boot and press f2.
if this is working, it's look like your harddrive is dead.
but if this isnot working (still same problem), remove the dvd, wireless card (from the back of the unit) and try again.
if still not working, Motherboard is bad.
Jul 23, 2008 | Acer Aspire 5500 5570-2609 Laptop
My Acer Aspire 3000 has a blank screen
I suggest you check the settings of your bios. Normally this happens if your Hard drive is unreadable. Change the settings of the boot function to first boot on Hard disk and try to disable all other bootable hardwares like CD or network card.
Hope this helps.
Apr 22, 2008 | Acer Aspire 3690-2196 Notebook
Acer 3003lci will not boot up.
sounds like locking up on boot, hence why nothing happens when you hit F2, try tapping F2 as soon as you push power button, if still hanging, you may need to take it to get looked at, could be a number of things causing it to lock up
Dec 11, 2007 | Acer Aspire 3003LCi Notebook
Acer Aspire 3680 Laptop Logo
96 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
