Question about Canon PIXMA iP90 Mobile Printer
Black printer nozzle is not working. Cleaning does not help. Printer sat unused for 2 years.
  • 3 Answers
Http://www.fixya.com/support/t3137100-seems_work_paper_comes_out_ink
sounds like most of the issues on here about this printer, hope my reply to this problem helps, it did take a while for it to flow properly after i cleaned mine
Posted on Oct 11, 2009
Blocked nozzle
Sometimes a printer that has been unused for too long will require 2 or 3 cleanings to fix a nozzle. What brand and model is the printer? We can look up to see if the printheads are replaceable or not.
Nov 18, 2011 | Office Equipment & Supplies
Printer worked fine until yesterday changed ink cartridges now black wont work tried all options
Hello
well changing the cartridges will not effect anything to the printer but the duration taken for replacement will. As in epson if you leave the printer without cartridges will clog the head nozzles. Did you remove the cartridges and turned off the printer and left idle for sometime? if yes then follow the instructions below
1. Print nozzle check test print to know which nozzles are not working
2. Head cleaning from the printer software.
3. Perform step 1 again to see the difference after cleaning
IF NO
Then you have to take the print head out of the printer and clean the nozzles by using hot water in the Syringe and blowing the derbies out of the nozzles.
Jul 17, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Printer sat unused for one year while my husband and I were both away on military duty. Returned to find that despite replacing all of the ink cartridges the black ink will not work. I performed self...
midway between the two holes that plug into the printer, there's an opening. evidently, the printer senses ink level thru the little piece of plastic.
with printer OFF, take all ink cartridges out. cut small pieces of duct tape, small enough to cover the hole but not pass the catridge edge. use a small screwdriver or tip of a knife blade to work the edges of the tape into the slot, covering the little plastic window.
insert back into printer. worked for me. it's simpler than it sounds.
Jul 22, 2010 | Brother MFC 240C All-In-One InkJet Printer
I have an Epson Workforce 600 printer that won't print black ink. I have replace all the cartriges with new and still no black ink. I've done nozzle clean several times. Only a very faint line on test...
You may have to clean your HEADS. I found this on the Web. Hopefully this will help. Pls rate me.
Good Luck
Found this on the Web:
http://www.fixyourownprinter.com/forums/inkjet/14116
Epson Stylus Head Cleaning Solution Plus
Re: Epson printer problem
You will want to press the button that you use to change the ink cartridge (the 3rd button). Once the carriage is in the "cartridge change position" you can unplug the printer. Then you are ready to flush out the heads. Click here for cleaning instructions http://www.wesesweb.web1000.com/printhead.html
The instructions are fairly easy to follow. If you need the head cleaning solution click here .http://www.fixyourownprinter.com/kea0.html
Repairs: All Epson Stylus printers (except for the C64-C86, CX4600-CX6400 series) which don't print, or print choppy in black or color. For the other printers, as well as Canon BJCs, use the other repair kit.
Description:
  • This is the same chemical used by Epson in their service department
  • Easy to use, no disassembly required
  • Gently dissolves even the most stubborn clogs and restores output to dried out print nozzles and clogged printheads
  • In our testing on an Epson 600 that sat unused for several months, it 100% restored a head that had no output, with one application (Individual results may vary)
Note: This is not alcohol or Windex; it is an ink-specific solvent that has proven to be safe and effective for use on Epson printheads. Do not use alcohol or Windex, they will very likely ruin your printer.
Kit Includes:
  • 1 oz bottle Epson Stylus Head Cleaning Solution (enough to fix several printers)
  • 1 syringe applicator for dispensing solution
  • Simple directions for use
Price: $9.99 order form on link below
http://www.fixyourownprinter.com/kits/Epson/K89
Feb 25, 2010 | Epson WorkForce 600 All-In-One InkJet...
Printer is not printing text
If the printer was unused for a week or 2 the print heads are clogged with dried up ink. You can use the maintainance tab for the printer for cleaning and nozzle check or the program below. I have been using it for several years.
This is a utility to manage your ink. Gives an accurate count of how many ink shot are left in each cartridge. The printer just told me I need a new magenta but this program says I have 13% left. It also has sepparate routines for cleaning the black and color (unfortunately not individual cartridges) and a powerful clean cycle when they are really cogged.
http://www.ssclg.com/epsone.shtml
Jul 17, 2009 | Epson Stylus CX4600 All-In-One InkJet...
ESP-7 won't print black ink
go to main menu,go to maintenance and then clean printhead go for deep cleaning .. and then caliberate printer from main menu.. ur printer will be working fine.. if not call kodak all in one printer support, they will replace ur printhead.free of cost
Jun 18, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printing one colour.
Given the age of the C87 it's likely that you haven't used this printer in a while and/or it's just slowly become clogged over time.
The ink in the C8x series printers is a resin based pigment ink which is very prone to clogging so it's not exactly unusual.
The best way to resolve this is to follow this procedure:
  1. Press the ink button once to get the printhead into the "exchange cartridge" position
  2. Pull the power cord out of the back of the printer
  3. Move the printhead over to the left out of the way
  4. Using a suitable inkjet ink cleaning solution soak the parking pad area where the printhead usually sits (This is a small foam padded area to the far right that sits in line with the printhead).
  5. Move the printhead back over to the right
  6. Leave for 24 hours (Patience is vital... Just leave it alone - see below)
  7. Plug the printer back in and run a single (just ONE) cleaning routine and a nozzle check
  8. If the nozzle check is still showing no colours on the black, cyan and yellow, leave it for an hour then try printing something with a little colour in it. (Sometimes the printer just needs a little rest time to sort itself).
  9. If still not printing properly, repeat steps 1- 8 again (and yes, wait another 24 hours!).
The way this works is that cleaning solution is able to wick up into the printhead nozzles and break down the clog. However it does take time to do this, hence the "be patient" bit :-). Distilled water is not recommended for this printer as the ink is not a water based type so a proper cleaning solution will work much more effectively.
Using this technique I've been able to recover CX6600, C84 and numerous other printers that have been completely clogged and unused for years so it does work.
Hope that helps.
Jun 11, 2009 | Epson Stylus photo C87 InkJet Printer
Epson CX3810 prints black but won't print colors
Hi, I am assuming your PC is relatively new. You have had a working printer, installed the new printer and ran the installation c.d. If you have marked the new printer.... (go to programs, control panel, printer and open) when open...note the little check on one of the icons. Is your new printer the default printer? To change...right click over the icon, look for the "Set as default printer". Left click this. Now......as for color.....when you place your cursor over the new icon....right click. The box which opens will show printer preferences. Left click this. When this box opens, go to the color tab. Left click this. Look to see if printer is in Color options or Grayscale. G.S. will prevent this new printer from color access.
I hope this helps.....Thank you for coming to Fixya and let me know.......there are some other things to look at if I'm on the wrong path..
Jan 16, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Color, getting primarly blue in my printed photos
Try cleaning the nozzles of your printer. If it sat unused for awhile, some of the ink may have dried and clogged the nozzles.To clean your inkjet nozzles, open your printer's Properties screen and look for a tab labeled Maintenance, Services, or something similar. If you can't find it, look under Printer Preferences on the General tab. It may take a few times of cycling through the cleaning process to get them unclogged. Check the progress after each cycle by printing a test page.
Jan 10, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Canon PIXMA iP90 Mobile Printer Logo
126 people viewed this question
old marine
old marine
