Question about Meade Polaris 114mm Equatorial Reflector Telescope
Meade Electronic 114mm--Question--when the motors are locked finger tight (or tighter) should the telescope move at all in the horizontal or vertical when gentle pressure is applied? When I try to view and my eye presses gently against the eyepiece the telescope moves off target? thanks walt
    Genius:
  • 1,027 Answers
Yes, the clutches are designed to have some slip to avoid damaging the gears.
Posted on Oct 06, 2009
Looking for a operation manual for a Meade 114EQ-DF4 with Electronic Drive
All of Meade's manuals are on this web site-- find your telescope:
http://www.meade.com/manuals/index.html
Nov 01, 2010 | Meade 114EQDH4 (36 x 114mm) Telescope
Motor tries but cannot move on the horizontal. Moves fine on the vertical. Usage only in Alt/Az mode. Only have the electronic controller that came with the scope.
You did tighten the AZ clutch? You did start from the HOME position? (turn the scope Counterclockwise to the hard stop)
Then you will either have to send it back to Meade for repairs, or open the bottom of the base, and look inside and see if the AZ worm gear is actually meshing with the motor. It could have come loose.
Meade customer service:
http://www.meade.com/support/index.html
Oct 08, 2010 | Meade ETX-125EC (500 x 127mm) Telescope
I took apart the vertical support arm and need to insure that I am putting it back together properly as it will not currently move vertically, horizontal is ok
Here is the manual-
http://www.meade.com/manuals/TelescopeManuals/Reflectors/DS2000%20manual.pdf
If the motor does not work it can indicate-
A broken wire inside
A broken altitude motor
A broken motor control circuit board
Only the first one listed above can be fixed by you. The scope must be returned to Meade for either motor or electronic repairs.
Here is Meade's customer service web site:
Jun 27, 2010 | Meade DS-2114 ATS (325 x 114mm) Telescope
Motors won't turn
Are the batteries FRESH? if they are you may have a bad motor. Contact Meade customer service:
It sounds like BAD batteries. Try new ones first before sending it to Meade.
May 15, 2010 | Meade 114EQDH4 (36 x 114mm) Telescope
Motors won't turn
Check for shaft locks being engaged, and for motor bearing issues.
Mar 28, 2010 | Meade 114EQDH4 (36 x 114mm) Telescope
MEADE ETX 125 Motors have stopped
The ETX125 is notorious for bad motor control. Weasner's Mighty ETX web site has links to repair centers that are more reasonable than Meade. They also have a QA section to assist with diagnostics.
Jul 23, 2009 | Meade ETX-125EC (500 x 127mm) Telescope
Horizontal moter problem
This is probably not what you want to here but it most like needs to go back to Meade for repair. There website is here: http://www.meade.com/.
You may want to also check here for further support: http://www.weasner.com/etx/menu.html. Mike Weasner is quite knowledgeable about the ETX line.
Good Luck!
-jodair
Jan 30, 2009 | Meade ETX-90EC (325 x 90mm) Telescope
Won't move vertically
Make sure the DEC clutch is tight enough.
Oct 25, 2008 | Meade ETX-90EC (325 x 90mm) Telescope
Meade 114EQ-DH$ Manual needed
114EQ-DH4 same as 4504. Manual on Meade website
Mar 29, 2008 | Meade 114EQDH4 (36 x 114mm) Telescope
Meade Polaris 114mm Equatorial Reflector Telescope Logo
46 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
